Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Range beeps and blinks F1 on display. Heats up on its own. ???????
  • 80 Answers
The f1 means there is a sensor that will need to be replaced.
John
Posted on Sep 28, 2009
What is error code F1
Here's a list of error codes for Whirlpool oven/range. Whirlpool Range Fault Codes
Sep 21, 2014 | Whirlpool Ovens
How to stop WB27K5040 from beeping F1 error code
Unfortunately, the F1 error means that either the touch pad has a short or the "clock" (electronic control unit) has failed. Sometimes the wire between the touch pad and the clock fails. To test for the exact problem, you would need to unplug the range and access the clock from the back of the range. Unplug the touch pad from the clock. Then plug in the range again. If the error does not recur, the touch pad is bad. If the F1 error and beeping repeat, the clock is bad.
GE sold the clock and touch pad as a single unit for the WB27K5040. Since this is an older model range, the replacement is not in stock. There are some places that offer to repair the clock. You'll need to remove the part (or get a service person to do it) and send it in. Your range will be unavailable for some weeks while this is attempted. Otherwise, you should replace the range when the issue becomes too frustrating.
I hope this helps.
Aug 28, 2014 | Ovens
Error Code F1 displays once in a while. What does it mean?
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
1. Disconnect power to stove
2. Gain access to the back of the clock (electronic range control or ERC).
3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
4. Make sure everything is clear and will not short out when power is turned back on.
5. Turn power back on to stove.
6. Watch for the F1 and listen for the beep.
7. If you get the F1 and beep, replace the ERC.
8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
* ERC - Electronic Range Control
NOTE: Some models incorporate the touch pad and the clock as one part.
Hope helps.
Apr 20, 2011 | Ovens
The stove just says F1 and beeps won't let me do
Hello with the limited information and no make or model I can only give a generic response to this one. Most manufacturers F1 code indicates a bad control board (EOC) and or a bad touch-pad. If you have any other questions please feel free to comment. Mike
Nov 03, 2009 | Ovens
F1 error code, beeping
  • Disconnect power to stove
  • Gain access to the back of the clock (electronic range control or ERC).
  • Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  • Make sure everything is clear and will not short out when power is turned back on.
  • Turn power back on to stove.
  • Watch for the F1 and listen for the beep.
  • If you get the F1 and beep, replace the ERC.
  • If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    N
  • OTE: Some models incorporate the touch pad and the clock as one part.
  • Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Aug 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
    Hi
    F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
    8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
    thank u
    rate me!!!
    Aug 14, 2009 | Maytag Ovens
    Range developed problem while cleaning oven
    Your electronic oven control is bad and must be replaced.
    The clock.
    Mar 15, 2009 | Ovens
    When using oven it beeps and displays f3
    Could be one of 2 problems. Perhaps both.
    Unplug the range.Access the control panel and unplug the ribbon connector from the control.
    Wait 35 seconds and re-connect it.
    If it continues to beep and code replace the temperature sensor.
    Mar 15, 2009 | Kenmore Ovens
    Error f1 and beeping sound when the oven is on. Heating non stop.
    Your digital panel may still be under warranty. It may be worth your while to have a tech look at it. Something else is going on here.
    Jan 12, 2009 | Kenmore 47783 Electric Single Oven
    "F1" DISPLAYED AND BEEPING
    F1-->Failed Thermistor Control Replace ERC
    you will have to replace the ERC or Electronic Range Control or the touch pad.
    Dec 18, 2008 | Ovens
    Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
    128 people viewed this question
    Top Frigidaire Ovens Experts
    Oloyede Monsuru
    Craig Butler
    Craig Butler
    Starnley Johnwells
    Starnley Johnwells
    Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
