Question about Siemens 12 Q115u 15a Circuit Breaker, Qp
240 w/60 a outside breaker with test switch wont'
I have a 240 w/60 a Siemens breaker with test switch for my hot tub.
I turn it off to drain my tub and turn it back on 1 hour later. I had no problems in the past, but now my tub wont turn back on.
I checked my main breaker, turned it on/off a few times, but still no power on my tub???
Is there a reset on this unit?
Thanks, Steve
  • 3,600 Answers
Inside the controller box is a red button to reset it but most likely the heater element is shorted out so replace the heater element first. Cost $100.00 at any pool or spa shop. Post here if you need more help.
Posted on Sep 28, 2009
Unit acts like it has received water then continues to cycle as if it hasn't, no water is pumped???
Symptom Check
Click on underlined items for further information Washer does not work and makes no noise Washer does not work but it does make noise No water is entering the wash tub
- or no hot water
- or no cold water The water fills the wash tub too slowly The tub does not fill with enough water
  • Test the water level switch
  • Check that the drain hose is positioned roughly as high as the top of the inner tub
The water overflows the wash tub Water drains out during the wash or rinse cycle
  • Check the drain control lever
  • Test the drain control coils
  • Check the cam bar
  • Test the timer control
Wrong temperature of water is used
  • Water supply hoses may be reversed
  • Hot or cold water supply valve may be turned off
  • Water supply hose may be kinked
  • Check water inlet valve
Water drains out while it is filling
  • Check the drain hose, it should be at least as high as the top of the wash tub, about 38 inches.
  • The drain hose must sit loosely in the house drain. Do not seal the air gap around the drain hose or a siphon will occur.
  • Check the cam bar
Water drips into the wash tub when the washer is off Water does not drain out of the wash tub Water is leaking onto the ground
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Agitator does not move Agitator movement is weak or moves in only one direction
  • Inspect the agitator
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the pump coupling
Drum does not spin
  • Test the lid switch
  • Test the centrifugal switch
  • Test the motor
Clothes are too wet after spin cycle This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
Spin:
  • Test the motor
Cycle does not advance
  • If the washing machine fills with water and begins agitating, but the timer does not advance, the timer probably needs to be replaced
  • If the timer does not advance while the washer is in a spin cycle, the timer probably needs to be replaced
  • If the timer does not advance during the rinse cycle, check whether water has filled the tub, if not, it is likely cold water related. Check the cold water supply valve, check the supply hose for kinks, check the filter screen and check the water inlet valve
Burning or electrical smell
  • Unplug the washer
  • Locate the source of the odor then read the instructions in the related section
Foul or stale odor coming from washer or clothes
  • Check that the drain line is clear
  • Check the drain hose for kinks or blockages
  • Check pump for blockages
  • Check for build up of soap in the outer tub
  • Check for article of clothing stuck in the outer tub
Noisy or vibrates too much
  • General tips
  • Balance the load
  • Level the machine
  • Inspect the water pump for a blockage
  • Inspect the coupling
  • Inspect the transmission
  • Adjust the drive belt tension
  • Check the motor bearings
  • Check the drum brakes
Goes out of balance too often Clothing is damaged
  • Inspect agitator for cracks or rough spots
  • Inspect for rust spots
Jul 11, 2015 | Washing Machines
Why wont hot tub heat with jets on losing temperature on 110 volt
My first question would be about the outside temperature. What is the outside temperature?
Hot tubs that are designed to operate on 115v only have 1.5kw heaters and if the outside temperature is below 50 deg F they tend to not keep up to 103 deg water while being used. They are also designed to not heat while the high speed pump is operating.
Does it stay up to temperature on a normal basis?
ROD
US Parts Center
Jun 08, 2014 | Qca Spas Dream Series Dream Master Hot Tub...
Circuit braker keep popping
Sounds like the heating element has gone out again. Once you reset the circuit breaker and the tub turns on it will start to circulate the water. This usually runs like this for about 2 mins and then the tub will recognize it is cold and send power to the heater. If the element is back at that point it will blow the circuit breaker.
If this circuit breaker pops as soon as you turn it on then you most likely have a bad circuit board.
Rod
www.uspartscenter.com
Jan 30, 2013 | Jacuzzi Home
Breaker popped and wont reset yellow light on arc fault breaker after plugging in small humidifier unplugged but it wont reset
Hi, I don't know if this has been solved or not, but anytime these G.F.I. breakers trip, it is for safety because it is picking up a voltage leak from what ever appliance has been plugged in. If it does not reset, it must be a older breaker and you will need to run down and pick up another one. Home Depot is a good place to get one for around $20. With it tripped, no voltage will be present. Just take a flat blade screw driver to remove the wire from the breaker. Depending on the type/style, most just hook opposite the screw side. Just grasp the breaker where the terminal screw is and give it a pull straight out to you. When you install new one, just hook the right side under the lip, and push left side in place and reconnect hot and neutral coiled wire. You will be set! Always be safe when working around any high voltage source. Please rate me on my help to you. Thank you!
Shastalaker7
Jan 27, 2011 | Siemens Seimens Arc Fault Breaker
I have a 15 year old Hydropool Gold Series hot tub that I bought used a month ago. We got it all hooked up and working great but was told the timer never worked so it ran 24/7. Yesterday my husband turned...
If you can find the points on the timer try sanding them down. If they were burnt and stuck the spa would have run continuous. When you pulled the timer you may have broken them free but a burn would have kept them from making contact. I hope this helps, if not you might try reversing the leads coming into the timer or wherever you unhooked it to take it out. good luck.
Dec 05, 2010 | Qca Spas Paradise Hot Tub
Why is my 50 amp GFIC breaker tripping out? I have just installed a new hot tube.I had one there before(smaller 40 amp) so there was already #8 wire there.The new hot tub requires a 50 amp. #6 wire. I just...
There might be a few things here:
1) Big problem >> the #8 wire is a fire hazard connected to a 50Amp breaker
#8 is a 40 amp breaker
#6 is a 55 amp breaker
We put #6 on a 60 amp breaker
Are you saying you hooked the #8 wire to the new 50 amp breaker, and the hot tub called for #6 wire?
Upsize your wire and breaker to meet code
http://waterheatertimer.org/pdf/Wire-size-amp-rating.pdf
2) After putting the correct wire and breaker, you can still have a short in the circuit somewhere
We used to set equipment out in the field in early morning >> the grass was wet >> our equipment was fine, but the tiniest short would cause the GFCI to trip
I don't know where the problem is without a thorough checkout of every possible grounded surface. You need a good multi-meter
3) You better get an electrician over there to have a look before the place burns down or somebody wakes up dead in the hot water.
If I sound a bit scary here, it's because something doesn't sound right with your installation.
Oct 19, 2010 | Inline 60 Amp Circuit Breaker
My hot tub i dont no how too turn it on or turn the heat up
There should be an independent circuit breaker to control the tub, most commonly a 50 amp GFCI breaker. (Has a "test" button on the breaker itself) It is usually located either in the vicinity of the spa in a gray box, or in the main circuit breaker panel of your home. In rare instances, they may have used a "fuseless disconnect" either in the spa equipment compartment, or within the vicinity of the spa. (at least 6 ft. away from spa) The disconnect is simply a removable lever that you pull out to disconnect power to spa. I would advise you search for a breaker or disconnect. If you locate the breaker, switch it off, then back on. If you locate a disconnect, pull it out, ensure that it is inserted in the correct way, then re-connect it. If that doesn't work, check for a GFI on the equipment pack itself. It would have a "test" and "reset" button on it. Press the test, then reset button. You should hear a distinct "click" when the test button is pressed, and the reset button should stay in once pressed after that. If it does test and reset properly and the pump, etc doesn't work, then you have a problem in the control pack. (Either a fuse, or a component that an average consumer cannot diagnose or repair.) That being the case, you should call a qualified spa technician. Hope this helps.
Dec 31, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
GFCI alarm stays on
Open your drain valve under the unit to break any air lock that will have gotten there when you drained the tub.
Sep 30, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
How to turn on hot tub
Check at the plug in if it has a normal plug like in your home first. Should be a set of buttons there, called a GFI. One is test, and the other reset.Push reset to see if spa comes on. Most spas dont have an actual on button. Check breaker box for popped breaker also, maybe tub is having problems, and needs a service call. Also larger tubs ussually jave a gfi or fuse box outside, close to tub. Kirk
Dec 01, 2008 | Pool & Spa
Siemens 12  Q115u 15a Circuit Breaker, Qp Logo
514 people viewed this question
Top Siemens Electrical Supplies Experts
john h
Mike
Gene Haynes
Are you a Siemens Electrical Supply Expert? Answer questions, earn points and help others
