Question about Mitsubishi WD-52525 52" Rear Projection HDTV
IMitsubishi 62525 timer light blinks green and won't turn on
Power has been off for a while because of local flooding problems. When I tried to turn the Mitsubishi 62525 on the timer light blinks green continually and will not turn on.
The manual says that the timer light will blink green for a minute after power has been off and is turned back on and then it will go to solid green and the screen will illuminate. It has been blinking green for an hour or more.
    Genius:
  • 1,112 Answers
Try a system reset by unplugging the set and waiting for about 3 min then replugging it in. If this problems persists contact mitsubshi for technical support, I have replaced entire signal board chassis for this same problem, they will run you through a few common things to try using the front panel buttons.
Posted on Sep 28, 2009
  • 115 Answers
Problem is probly caused by FMT board or DM board - bolth are no longer available . -electrical chassis must be removed and sent in to mits. to be rebuilt. cost not including labor is 500$ . About half of then work when installed into the tv . Soooo the answer is call mitsubishi and complain until they give a real big discont on a newer model . Or find a local repair facility that is experienced with this model and will rebuild it themselves and warranty it for at least 90 days. i'd say its worth it if its only$ 500-$600 toltal!
Green blinking timer light on my WD 62525 tv
That symptom is almost always caused by bad capacitors that are known to fail through ou the five circuits boards within the chassis. Usually the DM board and The Power Board caps fail which can cause the non stop blinking timer led. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com which has the caps with repair instructions that will often repair that issue.
Oct 04, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Green blinking timer light, TV won't turn on
Common to mitsubishi dlp tv's,you have a bad signal ***'y (power supply,formater board) lots of bad electrolytic capacitors,
Mar 22, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Timer light blinking fast and is green, Tv will not turn on even after a reset, bulb is good
First mistake was buying Mitsubishi Model WD-62525
The DM capacitors need replacement contact a local Mitsubishi Model WD-62525repair center.
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
My wd 62525 has a blinking timer light and wont power on
do the timer come on at all whean you plug it in do you hear kind of noses? if not take it to a sevice shop
Nov 30, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Green Light on Mitsubishi WD-62525 keeps blinking
Fluke solution: Press and hold Menu+Enter on front of TV...
WD-62525: My Green Blinking Fix!!!
http://www.avsforum.com/avs-vb/showthread.php?s=eb9ba9017a86fd9993de5feb77ee5f25&p=17646001#post17646001
Jan 03, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
The TV wouldn't turn on...no power
sounds like you have a bad flyback in your set
Dec 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
255 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
