Question about Dell Dimension 2400 PC Desktop
LCD back light is off or very dim
I changed monitors and it works. Is there any setting on the monitor??
Its only about two years old.
  • 43 Answers
I changed monitors and it works??? What worked. Did the brightness appear? Is the monitor now functioning properly?
If not, monitors can have increase brightness by using the menu settings. The settings can be accessed by the buttons that are usually below the monitor screen on the front under panel. Adjust the brightness from there.
If that fails then change the monitor. That you are suggesting that the backlight is out, I am assuming that you have a flatpanel monitor and not a CRT. Either can be configured the same way using the menu buttons; however, the back light issues are different in the two types of monitor.
Good Luck
Posted on Sep 28, 2009
  • Dell Master
  • 32,281 Answers
There are brightness and contrast settings on all monitors. If you find that these are set to the maximum then :-
You could have a faulty inverter board or faulty CCFL lamp.
Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site. :-
www.lcdparts.net
Hp compaq le1711 too dark with image troubleshooting
what is that?
a very old LCD monitor
too dark
need help.
turn up the brightness , as the OSD menu
see those buttons. on front of Monitor. push them see OSD
then push brightness up.
if still dim the CCFL lamps for the back lamps are now old and DIM
as all do and are now BAD.
HP does not sell parts for this old of monitor. if bad.
this is your PS moduel in side
the lift jacks 1 runs the CCFL light tubes. for back lighting
all CCFL go dim and yellow with age.
Jul 26, 2017 | HP Computers & Internet
Dim monitor issu. I want it bright always.
it could be age-related but there is also a power setting in the OS. Alternately you can check also the monitor OSD and see if there is a setting for adaptive brightness enabled
Feb 26, 2016 | Compaq TFT5015 15" LCD Monitor
It has completely died, no power, no lights nothing!
Hi Avril
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 14, 2015 | Televison & Video
Circuit board.Monitor won't work.
you never said how connected, ?
  1. HDMI
  2. DVI
  3. or VGA with adaptor. (try them all? ) or new cable?
  4. or S-video ?
on the bottom rear right are 4 input ports, are all 4 dead?
power pack bad, (has none, its on the main PCB) seen below.
circuit board PCB bad. sure, or its 1kv CCFL power supply.
the first thing to consider, is, how old it is and what technology it uses for the back lamps. (LED new,. or old CCFL short lived tubes)
on your HP Lp2475w support page I read your spec,
it says 40k hour back lamps, in tech that mean CCFL. (the go dim at 40k hours life)
so step one is using a flash light, on the front glass.
connect PC, turn on PC, make PC work or go to PC bios
then monitor on, and use flashlight on the fact of the LCD
see DATA? yes, CCFL are dead, (them or there power supplies 1kv)
your monitor is old, 2010 ended the era of CCFL
yours is 2008 year, old.
mr, PCB, printed circuit board. power, no sure about data board.
light reading, read this and the 10second rule...(no sync)
http://h10032.www1.hp.com/ctg/Manual/c01517331
the users guide
http://h10032.www1.hp.com/ctg/Manual/c01517325
if the monitor has sync inputs, then it does show, no sync on screen
and if the sync is good, the Menu button works. put it inside
the 10sec rule can help see it,
also see if screen is dim as all old CCFL do, turn up the brightness to max , use dark room if too dim.
the OSD screens must work or do this.
seen here
http://www.pcdied.com/monitors.html#flashlighttest
Sep 17, 2017 | HP Lp2475w Widescreen Lcd Monitor
I have a HP1740 monitor and for some reason the settings on the monitor got changed. The font color has changed almost as if somebody took the bold off of the font. I know this is a monitor issue because...
Unfortunately you do not say what your OS
For Windows 10 Right click on a blank area of the desktop and select Personalise. When the Settings page opens type in the search window Change font settings
Take it from there
Nov 12, 2017 | HP L1740 17" LCD Monitor
Adjusting contrast and/or brightness
As a rule of thumb all settings should be done with your Monitor controls usually on the front or sometimes unerneath the front of your Monitor.
If you have a add on Card or one buildt into your motherboard the settings will be in the proterties or control section but first set the monitor controls.
You can also change settings in the control panel by clicking on the Display Icon. This should also tell you what kind of Card you have installed to run the Monitor.
I have a LCD Monitor only about 10 months old and the picture is getting dark. I have maxed out the Monitor Controls and the NIVIDIA card Controls. A new Monitor is in my future. This is my second LCD Monitor in two years. Not good for the new LCD/s since I have old Monitors around 20 years old that still work great.
Hope this helps.
Jan 25, 2011 | Computers & Internet
17" flat screen upper half is dark until "thumped"!
The inverter board that controls the lighting on the screen is dying. since its a 5 year old monitor and only a 17 inch. the cost to repair is greater than the cost of buying a new one. unless you know how to replace the part yourself. I think its best to just buy a new monitor
May 04, 2010 | Rosewill R900J 19" Flat Panel LCD Monitor
Screen very dim, but set on 100% brightness.
Good Morning! With the 8 years operations of your emachines monitor, some of its electronic parts might incurred cold solder joint connections from its circuit board & possibly some of its Capacitor parts are already worn-out. please try to get assistance from an electronic service technician which will surely diagnose & repair the problem. best regards.
May 04, 2009 | Computers & Internet
Notebook monitor not working
Turn out the room lights and see if have a correct, but real dim, display. If you do, then you have a bad inverter or back light. If you don't, then you have a loose LCD cable connector, bad LCD cable or bad CD.
Ron
Dec 16, 2008 | HP Pavilion dv9000z Notebook
Monitor gone dull
there is a key on the keyboard which controls brightness. on mine it is the second key on the right, of the bottom row. it has a small sun on it. Press this key at the same time as the function key (on mine, bottom row, second from the left, blue key marked Fn) - and the monitor will brighten up.
Apr 19, 2008 | Computers & Internet
Dell Dimension 2400 PC Desktop Logo
241 people viewed this question
Alun Cox
