Question about Dyson DC14 Animal Bagless Upright Cyclonic Vacuum
I do not have any suction, to the base or the wand. My brushes also do not turn. The belt appears to be attached & in good condition and there are no clogs (that I can find)
    Problem Solver:
  • 33 Answers
Some times there is a pan beneath the vacume and an opening there, it may be clogged there, thats not real unusual, hope this fixed it,,
Posted on Sep 28, 2009
The wand on this vacuum has suction, but the base unit does not. I have checked all filters, the hose and connections for blockage, etc. The brush is rolling.
some vac's have a small slide that stops te wand suction when the wand sucks the other parts gets none
May 11, 2015 | Vacuums
We have a Miele Silver Moon vacuum that isn't
Hi dear.There are two type of attachments for this vacuum cleaners to pick up the pets hair,fluff & so on.They call it"Turbo & Power Brush".Turbo brush operates with machines suction & Power one operates with small electric motor which is built in the unit.They work with the same prenciple.There is a belt drives the rotary brush.OK.there are two small yellow screw underneath the unit.Please undo them,take of the cover & clean the rotary brush,check for the belts tension.It should be enough tight to drive the brush.If not ask for spare part from Miele in your country.After cleaning please put it back in order.To test it,attached to the vacuum.Turn the power on for Turbo brush,as long as suction starts,brush should start turning too.For the Power one,there should be power button on the handle to turn it on & off.Press it.It should work.On both of the unit,brush should spin good & strong enough to do the job when it's attached the surface you are vacuuming.Check the brush after each use,cleaned if neccesary. I hope that helps.Thanks.
Aug 01, 2010 | Miele s558 Silver Moon Vacuum
My daughter's S3765 bagless canister has good
That means that you need to replace the belt. Here is the belt you need for your model.
Hoover Windtunnel Canister Belt
Dec 20, 2009 | Hoover S3765-040 WindTunnel Bagless...
The brushbar is not spinning.
Even though the belts are intact they can still be stretched and will not turn the brush. Here is a link to the belts you need:
Dyson DC14 Replacement Belts
Nov 24, 2009 | Dyson DC14 All floors Bagless Upright...
No suction & brush will not turn when power
Check your belt. It is broken or stretched out. Replace the belt first. Should be your answer
Nov 09, 2009 | Hoover Elite Rewind Bagless Upright...
Suction only with attachments but none otherwise
Remove the brush roll and then fit everything back as normal. Then switch on. Put your hand to the sole plate - if you can feel suction coming through as you would normally vacuum then it could be a motor seizure. However if you can't feel suction then there's a clog between the main dust channel and the main hose pipe/where the hose comes out the back of the vacuum.
Once that's done then put the brush roll and belt back. You may find that the belt may have to be replaced if its broken.
Mar 27, 2009 | Vacuums
Dyson dc07 animal bagless
You probably have a blockage somewhere in the hose or in the base where the hose goes in. Remove the plastic tube at the base of the hose by simply unclicking it and remove the obstruction.
Nov 07, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction
If the belt is stretched, then it can't turn the brush rol under load, if you haven't chenged it in the last 6 months, then I would put a new one one. Also check the dirt inlet by the brush roll for a blockage.
May 30, 2008 | Riccar 8955 Upright Vacuum
Low suction on Eureka spinduster vacuum cleaner
The belt has stretch enough so as to not drive the brush roll under load. Try a new belt.
May 10, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Dyson DC07 Original won't pick up at base
Lie machine on its side pull back handle as if vacuuming & switch on (KEEP YOUR FINGERS & ANY LOOSE CLOTHING CLEAR OF BRUSH ROLLER)
Brush should spin if it doesnt ensure clutch control knob on side of machine is in drive position if it isnt rotate knob by hand to drive brush should now spin.
If it doesnt & your machine has A clutch either clutch will need replacing or belts will need replacing.
Manuals are available to replace belts & remove the clutch from this site http://dysonmanuals.llc.nu/index.htm
Apr 28, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC14 Animal Bagless Upright Cyclonic Vacuum Logo
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
