Question about Sony Playstation 3 (PS3) Console
I turn the sistem on and abaut 20 minutes it turn
I turn the sistem on and about 20 minutes it turn off by it self is a ps3 60 g just start to do that today when is on works fine for about 20 minutes i took good care of it
  • 344 Answers
Your system is overheating, clean the vents with a vacume so you **** the dust out, dont use a can of air, this will just push the air inside the unit and make matters worse in time. also you can buy intercoolers for the ps3 this would help you from overheating. (the system shuts off to preserve its self)
Posted on Sep 29, 2009
Testimonial: "thank that was the problem i let the sistem in stanby mode for more than three days probably that overheat the sistem good tip "
Is there a security sistem in a gmc ck3500 98
yes usually the 2 white wires break inside column that mount to lock cylinder assembly, try turning key on for 10 min than off than on for 10 min than off than on for 10 min.then try and start if starts and stays running will prob. need passlock sensor which is part of ignition lock cylinder
Feb 25, 2013 | 1998 Chevrolet Tahoe
I did the self clean on my oven, and now the oven door will not unlock (E1-F5-) pops up onto the oven screen.
Hi
Error E1 F5 means that the control has detected a problem with door latch switch. Switch off the power and unplug it from the mains. Check after 5-6 minutes whether the error has disappeared. If the error is still there then once again start the self clean cycle. Press the self-clean button to start the cycle. The panel becomes blank (---), then press the up arrow (^). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. After self cleaning is done wait for 15-20 minutes and open the door. Try moving the latch manually to unlock it. hope this helps...
Daniel
Aug 28, 2010 | Kenmore 92002 / 92004 Kitchen Range
Did the self clean and now the oven door will not unlock
Hi
Door is not unlocking as the control has detected a problem with door latch switch or the cycle was interupted in between. Switch off the power and unplug it from the mains. Check after 5-6 minutes whether you are able to unlock the door. If the error is still there then once again start the self clean cycle. Press the self-clean button to start the cycle. The panel becomes blank (---), then press the up arrow (^). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. After self cleaning is done wait for 15-20 minutes and open the door. Try moving the latch manually to unlock it. Please post back for any further assistance...
Daniel
Aug 28, 2010 | Kenmore Kitchen Ranges
Car wont star after a drive
YOU HAVE DIRTY FUEL INJECTORS.THEY ARE STICKING OPEN. FLOODING THE ENGINE. WHEN YOU TURN IT OFF.FILL GAS TANK UP.PUT A BOTTLE OF PRESTONE FUEL INJECTOR CLEANER IN GAS TANK.
Aug 01, 2009 | 1994 Buick LeSabre
Where do i find the jumpers for cmos reset on a L4S5M/DX+ - ECS Elitegroup
Dear asker, you can find a maual for the board here:
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=24&DetailName=Manual&DetailDesc=L4S5M/DX%20%20%20(V3.02)&CategoryID=1&MenuID=82&LanID=0
if you dont want to read, it is at the left of the battery , marked as jp1. usually the 1-2 pins are the normal operation, 2-3 pins to clear. Please notice that no power supply needs to be connected to the computer at he time of clear!
Bios clear takes abaut a half minute, then restore the jumper and power on the computer.
Hope this helps.
Mar 24, 2009 | Computers & Internet
1996 buick regal, put key in ignition,car wont start
will tace abaut 10 min to fix problem,sit on dreiver seat and turn key on only dont cranc ower weit 10 min or litlbrt more ,securiti leigth will strt flushing imidietly turn key off and start engine if dont work repit prosigure dhis will reset antyteft sistem in car
Mar 13, 2009 | 1996 Buick Regal Olympic Gold
Brand new Husqvarna 340e chain saw dies after 10 to 20 minutes.
Hi
Find out where is its airating sistem.It equalises the presure between the interior and exterior of the gas tank.Disassembly and clean it.
regards savumihai71
Dec 05, 2008 | Husqvarna Garden
Picture/sound goes out after 10 minutes of TV use
Rear projection hdtv, most likely damaged tubes. Don't repair this by your self get a tv repair man to do it before you injure your self.
Jun 24, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
To Self-Clean Using AUTO-CLEAN
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
desired self-clean cycle time.
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
4. When the self-clean cycle is complete and the oven cools,
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired self-clean cycle time.
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Sony Playstation 3 (PS3) Console Logo
81 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
