Question about Hitachi Computers & Internet
Trying to recover laptop hard drive data via HI-SPEED USB 2.0 Desktop says USB Mass storage available, but I don't see it in explorer
  • 32,281 Answers
Try connecting it to a different computer.
If this doesn't work, this program may solve your problem :-
Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
If nothing works then the hard drive may work again if it is fornatted, but you will lose your data. There are data recovery companies that can recover data from faulty hard drives, BUT it will cost you an arm and a leg for their services.
Posted on Sep 28, 2009
Recently, my laptop will not boot from the hard drive.
The Hard drive installed in an USB hard drive case do not need drivers when you connect it to the USB port of a working computer. If the hard drive is not faulty then the computer will see this external hard drive as an external (mass) storage device and you can dopy/download the data off this hard drive.
If the computer does not detect this hard drive then the hard drive is faulty.
There are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
Nov 20, 2012 | Gateway EC1440u Notebook
No connection to data on Iomega Desktop Harddrive Hi-Speed USB2.0
Try connecting Omega hard drive into another computer to recover/backup your data.
Jun 07, 2012 | Iomega Computers & Internet
I found my old U3 flash drive that is password protected but when I plug it into my pc it won't boot. I can see some basic files but none of my data. I can't get in to remove password protection. It ver....
http://majorgeeks.com/Dr._Freeware_System_Utilities_d6416.html Dr.Freeware System Utilities which includes data recovery software, data backup, password reset tools for Windows helps you to maintain your system. Dr.Freeware is freeware, you can download and use it for free.
Data Recovery/Data Backup: Supports Logical scan and Raw scan, Supports NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660 file sytem, Supports IDE/SATA/USB Hard Drives.
Data Recovery - Recover your lost data
Available in Live CD to run offline
Recover accidentally deleted files in your hard drive
Recover data from RAW Drive(partition table or file system is damaged)
Support NTFS, FAT, UFS 1, UFS 2, EXT2FS, EXT3FS, and ISO 9660
Support IDE/SATA/USB Hard Drives, memory cards,
USB Memory Drives
Drive Dumper - Backup your hard drive
Available to run on Windows
Support Windows 2K / XP / 2003 / Vista / 7 (Windows Editition)
For data rescue, backup, migration, or computer forensics etc.
Transfer important important data from damaged Drive(partition table or file system is damaged, has lots of bad data blocks)
Support IDE/SATA/USB Hard Drives, memory cards, USB Memory Drives
Windows Password Cleaner
This is a utility to blank the password of any user that has a valid (local) account on your Windows system.
You do not need to know the old password to blank the password.
Support Windows NT/2k/XP/Vista
Hope this helps
Apr 13, 2011 | Verbatim Store n Go U3 Smart Drive USB...
My WD element desktop was working properly but now when i connect to my laptop it is not recognizing not even on the bottom left corner of the desktop even sound is not there when connecting. My harddrive...
First things first. When you plug the drive in and power it on....does the drive spin up? If so, if you place your ear near the drive, you should hear a whirring sound of the drive platter spinning and the slight clicks of the drive arm moving.
If you don't hear this, it could be a power problem with the drive or the drive itself may be done.
If you hear the drive spinning, then most likely your data is safe. From there I would suggest trying to plug the drive into another USB port on your laptop, or even into another computer altogether. If it works there, then you most likely are having a driver issue, or perhaps a drive letter conflict.
(For instruction on how to resolve a drive letter conflict, see my response to this post: http://www.fixya.com/support/t8601787-need_driver_8gb_sandisk_cruzer)
Otherwise check the device manager in the control panel to see if you show a "USB Mass Storage Device" show up under your USB device drivers in the list. You may want to right click and uninstall it if you do see it.
If you DON'T hear the drive spinning, I would check the power first. Make sure it's receiving power (look for indicator lights etc) you might be able to remove the drive from the plastic enclosure and use a USB Drive adapter (Like one of these ) to recover data from your drive
(http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2329300&CatId=3770)
If the drive is not spinning and the power or drive adapter doesn't work, you may have a bad hard drive.
Good Luck
Mar 08, 2011 | Western Digital WD Elements Desktop...
When i insert the usb port in any machine it says the usb port has exceeded the power limits of it hub port
The is indication of an over storage data medium. Consider freeing up the data from the device to attain continue usage. Attempt to achieve connectivity from any available connection ports that may recognize the storage medium to allow for data freeing taking achieving regular functionalities.
Feb 02, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
I accedently deleted a photo
hi
recovery your lost data .
1:download and install recuva software
2:connect your mobile to the computer using datacable 3:and select "mass storage" and start the recuva software select deep Scan
4:click here to download Recuva
the software will recover your photo or any deleted data
Apr 01, 2010 | Samsung SGH-t239 Cell Phone
How you transfer data from laptop to desktop? Is there any utility available?
Hi
Thanks for using FixYa. You can connect the Laptop with your Desktop using USB cable or Memory Stick and transfer the data. You can also write the data on a CD and then transfer it to desktop.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 10, 2009 | Compaq Presario 700 470024-192 Notebook
Laptop VISTA basic will not recognize 3.5" Nexxtech enclosure as mass storage device
run diskmgmt.msc there it will show all disk drives. if it detects usb mass storage and the hd is not showing. soulds liek hd is bad or jumper set wrong
Apr 28, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Computers & Internet Logo
75 people viewed this question
Top Hitachi Computers & Internet Experts
AJMAL KHAN
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
