Question about Kitchen Appliances - Others
Sharp SPC 373 transmittting temp 179 for a month
After 5 years of good temp. readings now the sensor only sends 179 degrees. I changed the batteries in the senor and the clock/receiver, still nothing. Can anyone help fix, or help me find a replacement?? Model SPS373 fcc id QL5C18WA, made by M.Z. Berger Co. Ltd, made in China (shocker). Please help, I really like this weather station
Unfortunately I have the same Sharp atomic clock with the same bad remote temp transmitter and having the same 179 result displayed. Can't find a replacement anywhere.
Posted on Oct 17, 2010
I put new batteries in Transmitter and never got any temp reading.The unit is less than 2 years old and is not working. Is there anything I can do?
  • Remove all batteries
  • Install new batteries in transmitter
  • Wait for transmitter to initialize and begin transmitting temperature data
  • Install known-good batteries in receiver
  • Observe outdoor temperature reading
If this doesn't work, the transmitter or receiver or both may be defective. I find in very cold weather the transmitter stops sending the temperature.
Dec 08, 2016 | Measuring Tools & Sensors
I have a model #WS-9037un-it with a model TX29Uremote transmitter. When I removed batteries there was a reading on it when I put in new batteries no temp. waited several hours.
  • Install known-good batteries in the transmitter. Wait for transmitter to initialize and begin sending temperature data
  • At the receiver, install known-good batteries. You should see outdoor temperature displayed
Dec 07, 2016 | Measuring Tools & Sensors
Need a out side temp sensor for a sharp wireless thermo clock it is a sharp SPC 373
DO YOU HAVE A MANUEL ,,OR GOOGLE THE MODEL AND MAKE AND CONTACT SHARP CUSTOMER SERVICE IF IS ISN'T TO OLD THEY'LL PROBABLY SEND YOU ONE OR TELL YOU WHERE TO GET IT!!
Jan 21, 2016 | Sharp Atomic Wall Clock, Silver/Titanium...
My acurite model75321a1 does not tell out side temperature
I checked my Acurite instruction file and found it rather vague about this issue but based on my experience with a similar system I found that battery changes have to be made at the transmitter first, allowing time for the transmitter to begin sending temperature data. Also, the Acurite instructions suggest use of lithium batteries in the transmitter where extreme low temperatures are encountered. My experience has been that the transmitter stops working at low temperatures so the reading comes and goes depending upon the weather. Currently it is 20 degrees F outside headed for 5.
Feb 01, 2015 | Measuring Tools & Sensors
Can't get outside temp on my atomic clock
If you still have the instructions read up on pairing the transmitter to the clock. You'll need to do that every time you change batteries on the outside transmitter. If you don't have those instructions , go to the clock's web page to get the manual for your model of clock.
Sep 23, 2014 | Home
Thermo clock RAR312 not picking up outdoor transmitter temperature. Replaced battery but still nothing.
take a paper clip and reset the reset button located in the battery compartment. Then, try each of the 3 channels until you get a reading in the outside temp field. Wait a good couple of minutes at each channel setting before determining the units are not pairing. Do this with the units side by side for signal acquisition, then once acquired, move the remote sensor outdoors. Hope this helps!
Sep 24, 2010 | Office Equipment & Supplies
The outside temp sender won't work. We put new batteries in it, but it does not send a signal. It will not put an outside temp on the clock.
Simple, the instructions state that when changing the batteries on the outside temp. sensor, you must also change the batteries on the main clock unit. I had same problem when I changed the sensor batteries until I pulled the batteries from the clock and it reset fine. ( Sensor batteries first, then clock batteries. ) The clock will reset to atomic time overnight so don't worry if it doesn't read correctly at first.
Aug 18, 2009 | SkyScan 86709 Atomic Wall Clock
Sharp Atomic Clock spc 373 won't display correct time/zone
To change the time zone press the "time" button, on the front the space that shows the date will change to show the time zone. With the time zone showing press the "up" or "down" button to get to the correct time zone.
Sep 23, 2008 | Zapf Chou Chou 716212
Remote Sensor
make sure your time is set and the atomic clock time is recieved, then leaving the rear cover off of the transmitter, push the "tx" button not the "c/f" that is just for centegrade or ferenhight. you will see the red light on the front of reciever flash in a few seconds. The temp should display on your clock screen. If not, did the red l.e.d. light on transmitter flash. If not, its not sending data to clock. I have to reset and hit transmit every time I replace batteries on transmitter. Had no problems for over 2 years of using outside. If your not getting a reading with transmitter sitting next to clock after hitting "tx" button you may have defective transmitter.
Jan 13, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
Kitchen Appliances - Others Logo
382 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
