Question about Sony PlayStation 2 (PS2) Console
I have old thick PS2. I cant see laser or gear thing. what do i do??????
    Champion:
  • 273 Answers
Go here and go to the very end.
www.powerfulguides.com/ps2
hope this helps : )
Posted on Sep 29, 2009
I can only play some games on my ps2 i cant play any of the Need for speed games. i tried deleting old saved files dealing with nfs and my system configuration. Still wont work. Any other ideas to get...
If you have the original PlayStation 2 console, there was a problem with it playing some of the newer games released for the ps2 after the slim was released. You can try using a laser lens cleaner to clean the laser, but the original ps2 just simply won't play some games.
Jul 03, 2010 | Sony PlayStation 2 (PS2) Console
Why dose my ps2 only read ps1 games
Since PS1 Games Have Less Compaction Than PS2 Games It Needs Full Use Of The Laser Sensor To Play The PS2 Game. If Its Dirty Open Up The PS2 And Clean The Laser Sensor With Rubbing Alcohol And A Cotton Swab. It May Also Be The Fact That You Knocked Something Loose And The PS2 Cant Run At Full Capacity. If The 2nd Thing Happened You Must Take It To Game Stop,Eb Games, Or Any Electronics Store And Have Them Fix It. Look For A Video On Youtube That Gives Details On How To Clean The Sensor.
Feb 28, 2010 | Sony PlayStation 2 (PS2) Console
GTA Vice City Error
I had this problem it's not from the ps2 it's from the disk. For some reason gta disks don't want to corporate with the slightest of scratches.
Mar 14, 2009 | Rockstar Games Grand Theft Auto: Vice City...
Running ps2 games on my ps3
could be laser problem. redlight mode laser controls ps2/dvd/cd reading. does it read bluray games?
Oct 31, 2008 | Sony PlayStation® 3 (60 GB) Console
Playstation 2
Well brntaffy first off a liitle more info is needed. when you say wont read disc have you tried any or all of the media formats the ps2 supports? music cd, dvd movie, ps1 games, ps2 cd, ps2 dvd. If it plays some formats but not others then the cd eye angle alignment is probably not correct. Is your ps2 a slim or the older thick model? if it is a new slim ps2 you can try the top lens instruction below, but if your ps2 is the older thick model, unless you are at least somewhat of a tech savy type you may not want to attemped any of the other stuff at all. regardless it could be any one or a combination of the following:
1. Most commonly the laser lens (or eye) needs to be cleaned.
before trying any of this yourself read everything first and then have a place to work setup.This place should be clean, good bright lighting, with plenty of room, where you won't get disturb before finishing. and oh yeah wash your hands.
top lens: (if you have a thick ps2 model you will need to remove the outer case(be careful of ribbon cable connection for reset and eject button assembly, if you cant figure out how to remove the button assembly,just set the outer case upside down right next to thebottom) and then remove the top plastic cover of the cd/dvd unit) NEVER touch the eye/lens with your finger- you have oils that will cause it to attract dust/dirt. With a q-tip very lightly soaked in isopropyl rubbing alcohol, use as little pressure as possible, using a circular motion either clockwise or counter clockwise (do not change direction), rub the top lens about 20 to 30 complete revolutions then (without the alcohol) repeat the same method using the dry end of the q-tip
I say this again unless you are a some what tech savy type of person you may not want to attemp anything further.
bottom lens: if you are going to try this or anything furthur, PLEASE BEFORE you disassemble anything!, you need to be prepared with a few items. an artists paint brush- as small and very fine bristles as you can find the length of the bristles should be at least a quarter inch or longer. a few small wooden toothpicks, a can of silicone lubricant , q-tips , a fine point sharpie, oh yeah a regular sized phillips screwdriver and a small phillips tech driver , depending on which one of the, 13 or so different, ps2 models you have, you might find a few other small tools that could come in handy (an allen wrench or that just right size flat blade screwdriver, ect.).
okay back to how to clean the bottom lens: you will need to remove the laser eye assembly. to do this the guide bar the laser eye assembly is attached to will need to be removed, first mark the possistion of the cd eye angle adjustment knob(s) with the sharpie there will be 1 or 2 knobs depending on what model you have, the knob(s) control the height of one end of the guide bar(s). This needs to be very accruate so when you reassemble, the cd eye angle alignment is as you found it, because if the angle isn't right you won't be able to play all the formats the ps2 supports. either a flat metal spring or a srew or something similar holding one end of the bar needs to come out. be very careful of the ribbon cable attached to the bottom of the cd eye assembly, if you look at the plastic connector the ribbon goes into, very gently use something small, a sharp toothpic or tiny flat blade tech driver, to release each side of the plastic connector. this will release the ribbon cable. Now that you are holding the laser eye assembly very very carefully using a toothpic to hold the floating eye up enough so you can get access to the second stationary lens undernieth with your paint brush, brush the bottom lens several times to get any dust.
Now put back together . use a fresh q-tip to apply silicone lubricant to to the guide bars and the worm gear. the worm gear is what moves the laser eye assembly back and forth. check the gear grooves for any foreign material dust lent ect. remember to get the alignment knobs back exactly how you marked them. do the top lens: instruction. reassemble dvd top cover and outer case.
Now if you have done everything just how I said and your ps2 is still not reading any format then you have a more serious problem that will take more time to explain than I have right now but if anyone request this or needs more detail in the above I will find time to explain further possible solutions! lol
hope this info is useful!
Sep 13, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 wont read any of my disc.....
Try cleaning it out using a CD cleaner or canned air. If that doesn't work, then you might need to purchase a new PS2. The disc drive might have gone out.
Thank you,
Agent Matt
Go Ahead. Use Us.
Apr 08, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 stuck on memory card screen
If its not an original disc, meaning if it was copied or burnt, then this will happen. However if it is in fact an original PS2 disc, then I'd suggest taking it out, cleaning and trying again.
Mar 21, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 won't read disc
how to clean my ps2 disc i used alchol
Mar 16, 2008 | Sony PlayStation 2 (PS2) Console
Everytime i turn on the ps2 it says disc can not be read but nothing is wrong with the disc
try a nother ps2 if the games work then im sorry to say you need to replace the laser ? try one thing first ie give laser eye a clean then gently push laser to the back of ps2 and try a gain
Mar 08, 2008 | Sony PlayStation 2 (PS2) Console
Ps2 probs
  • If you are using copy / pirate disks, the Ps2 Will not pick this up unless it is "chipped," which is very risky both in a way to harm the console and in a way to get you arrested as it is illegal.
  • If you've had the console a long time and not a problem like this before - The laser has probably burned out. No point in buying a new laser because you would be cheaper buying a new Ps2 Console
Jan 06, 2008 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
