Question about Ricoh Aficio 1018D All-In-One Laser Printer
I hace ricoh aficio 1018d. it is hooked up to computer, but when i print it gives me the title of the document i want to print and then says handle error{showpage 100 720.... long paragraph of stuff. How can i get my documents to print properly?
SOURCE: aficio 1018d
sc 302
Posted on Jul 05, 2008
  • 5 Answers
SOURCE: printing error log
reset the print jobs then check the printing refeperences.
Posted on Feb 16, 2009
EmmettPinger
  • 63 Answers
SOURCE: Cant reset Z error at Printer Ricoh Aficio 1018D
Im assuming that you are referring to the Z as the jam light. In that case the operation panel will tell you what part of the machine is jammed by displaying a diagram and a letter that corresponds to a chart that you will see when you open the front door. make sure to open all the doors then close them to reset jam code (there is a hidden door on the right lower side called the A door) Good luck
Posted on May 03, 2009
SOURCE: Can MAC OSX 10.5.x use Ricoh Aficio 1018D?
this is an older model copier, however try going to www.savin.com and click downloads then drivers. there will be a tab for drivers, this is 10.5 though not snow leopard. Ricoh/Savin/gestetner and Lanier are all the same copier, but savin site has more mac info than Ricoh site. Usually I have better luck using already installed Mac drivers than Gutenprint, if you type in the ip it should give you a list of preinstalled Mac drivers. I believe the Ricoh 1018 corresponds to a Savin 2518 if that helps. Also use print daemon, not ipp. hope this helps somewhat as Macs are difficult with options and such on most printers. also must use PS3 for best results.
Posted on Jan 11, 2010
wheatlandsvc
  • 1110 Answers
SOURCE: error code SC471
SC471 is a Transfer Belt HP error. The transfer belt does not lift in the rear. The rear cam (G060 3894) slips past its locking tab on the square stepped shaft and slips off the side.
The fix: reposition the rear transfer belt lift cam to lock the tab into the square shaft. Secure the locking tab with a tie wrap.
Now this is the solution if you know what you are doing on this printer. I can not even begin to tell you in this forum how to dis-assemble the printer to get the transfer belt unit out and effect this repair. IKON is pretty pricy on labor. I would see if there is an independant guy locally that can do it. Inexpensive repair that I would charge $90 or less for. If you HAVE to call IKON then just make sure they do not try to tell you that you have to replace the transfer belt unit. This repair is all that is needed 90% of the time.
Good Luck and Thank You for using Fixya.
Posted on May 05, 2010
Testimonial: "fantastic advice and thanks for all the information. That was my exact problem. Thanks for the information. Much appreciated. "
Can you please help me, I have a Aficio 1018D copier / printer. Everything was working fine until a few days ago, when I am copyoing or printing documents the print comes out at an slight angle - the paper...
do you get the same problem if printing through the doc feeder and off the glass?
try using the bypass tray and not a cassette
let me know your answers
Feb 03, 2011 | Ricoh Aficio 1018 Printer
I have a problem with my ricoh aficio 1018d 'when it finish print one paper it guve me error that stil paper in section (b) when i turn off it work good
This problem is related to two things one is your exit sensor defective or your tray settings is not correct first you have to correct the tray settigs even thow problem exist you have to change the exit sensor or BICU
thanks
Dec 16, 2010 | Ricoh Aficio 1018D Copier
I have a problem with my ricoh aficio 1018d copier. It is printing very faint. let me how to go about it
after every 60 000 copies the drum must change, if the drum changed inspect laser module and clean if dirt
Sep 07, 2010 | Ricoh Aficio 1018D Copier
I have ricoh aficio 1018d can it fax or print and i cannot find connection points on machine
Sir,
You can fax or print with the aficio 1018d provided that you have the fax and printer options. these connection points are located at the back of the machine.
Mar 06, 2010 | Ricoh Aficio 1018D Copier
Can MAC OSX 10.5.x use Ricoh Aficio 1018D? Do you now alternativ drivers for ricoh aficio 1018D. HP LaserJet 5-Gutenprint v5.1.3 is o.k. for A4 but not for A3
Jan 09, 2010 | Ricoh Aficio 1018D Copier
Ricoh Aficio 1018D turn off Z problem
Something is jammed somewhere, turning the power off is not the reason that the jam indicator won't go out...you're missing something. Check all areas of the copier -just because the "Z" is lit doesn't mean that the remaining jam isn't somewhere else
Apr 05, 2009 | Ricoh Aficio 1018D All-In-One Laser...
Ricoh 1018d not print with lan conection
Hi Usama,
I had the same proplem as you when i installed pcl6 driver on my ricoh 1085
I solved but by uninstalling pcl6 driver and installing pcl5e
for your 1018d try this driver for windows XP D O W N L O A D H E R E
BTW.
about using 1085 as a scanner ,
I don't know what is "scanner interface drive board" ?
more help please.
Oct 23, 2008 | Ricoh Aficio 1085 Laser Printer
Ricoh aficio 1018 printer
yes you have to install the drivers and give the usb option for communication
Aug 05, 2008 | Ricoh Aficio 1018D All-In-One Laser...
Ricoh Aficio 1018D All-In-One Laser Printer Logo
29 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
