Question about Kodak EASYSHARE M1063 Digital Camera
My camera will not turn on, I have changed the battery and it still does not work
''change the battery'' message
Cross check that the batteries u inserted are compatible with the camera.
Hope this helped sir..
Jan 05, 2010 | Canon PowerShot A550 Digital Camera
Camera will not work, have changed the batteries, getting nothing
Things to check first are battery contact points, and micro switches that are located on the battery and memory card doors. Details on what needs to be checked may be seen here. It won't work for every case, but it's worth a try.
Dec 29, 2009 | Canon PowerShot A75 Digital Camera
My FUJIFILM A850 won't turn on. Changed batteries, but still won't come on, was working fine before this
Replace your batteries with 2700mAh rechargeable batteries! Normal batteries it's not working for me! after i replace with Sony and Varta 2700 Ni-MH it's was working! My camera it's turn on every time!
Oct 05, 2009 | Fuji FinePix A850 Digital Camera
Fuji FinePix S9000 battery change clears date/time.
Hi
I started having a similar problem with my Fuji FinePix F10 after about 3 1/2 years of problem-free use. Another poster had some really helpful advice which I thought I'd pass on. It seems there is an internal battery or capacitor which basically fails after a while, meaning date/time settings etc are lost when the battery is removed. (Some people claim this is a motherboard/chip problem instead - seems to be contentious!) So the camera is faulty, but the problem can be worked around.
The advice I found, which worked for my camera, was this:
- Turn off camera and leave off for approx 15 seconds before opening battery door.
- Change battery quickly (within a few seconds).
- Close battery door and leave camera off for approx 15 secs before turning back on.
This retained all settings when I tested it multiple times. I imagine it might not work if changing over a totally dead battery though.
Hope it helps!
F
Sep 28, 2009 | Fuji FinePix S9000 Zoom Digital Camera
Nikon Coolpix L11 digital camera won't turn on
if u have cheap batterys in it it might be that try puting some duracellor some good batterys.
Jan 15, 2009 | Nikon Coolpix L11 Digital Camera
Sir my sonyDSC-40 Camera dot't power on. In power butten pressing time only one time bliking green LED.
Turn off the camera, remove the battery pack. Allow the camera to remain without power for 30 seconds. Reinsert the the battery pack. Turn on the camera.
Please make sure the Battery is fully charged before performing this steps.
Also try changing the Batteries of the Camera. "AA" NiMH, "AA" Alkaline, "AA"
Nickel-Metal Manganese are the compatible Battries for the Camera. Hope it works!
Dec 01, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Battery Problem
These cameras have a internal battery that holds data for the camera to keep its settings. These batteries can be replaced but the camera has to be disassimboled to change it they should be able to be changed at a local camera shop pretty cheap.
Mar 21, 2008 | Nikon COOLPIX L12 Digital Camera
Short battery life?
I had a smiler problem with Alkali batteries. Thereafter I started using rechargeable batteries and also changed the setting to Ni-MH. Its working fine now.
Feb 26, 2008 | Nikon COOLPIX L10 Digital Camera
My camera turns on but then shuts off
Did you place a new battery in? Well, try doing that.
Aug 15, 2007 | Canon PowerShot A510 Digital Camera
My camera died for no reason!
most probably the camera must be fall down and some internal circuit is short circuited which is swiching off the camera. sangita
Apr 28, 2007 | Canon PowerShot A75 Digital Camera
Kodak EASYSHARE M1063 Digital Camera Logo
51 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
