Question about HP OfficeJet 6110 All-In-One InkJet Printer
The power does not come on. I plug the power supply into the back of the printer and the orange light comes on under the display to the left of the cancel button. It will not power up when pressing any buttons and the computer does not know it is there when usb is attached.
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Posted on Oct 18, 2008
siawolf
  • 749 Answers
SOURCE: HP Pavilion A767C Computer. Power
I would check your fans first , a failed cpu fan will cause the computer to overheat and not start.then cables, add-in cards and memory to be sure ones not halfway in it's slot.. then i would suspect the power supply, they can be missing power on a rail and still have a light on the back. you can buy a power supply tester at tigerdirect for 20 dollars. once all this is checked , i would look to the motherboard..
hope this helps in the decision making process..
Regards.
Posted on Oct 29, 2008
jtuckerj
  • 59 Answers
SOURCE: HP computer doesn't turn on
Your power supply is bad--you will need to replace. I suggest looking at tigerdiect for a replacement.
Posted on Dec 12, 2008
greg_margo
  • 1959 Answers
SOURCE: Compaq Presario laptop C300 - issues (orange light)
Sometimes when a PC gets stuck in hibernation mode, the only way to reset it is to remove the CMOS battery for 10 minutes and replacing it. It resembles a large watch battery and is usually located near the center of the motherboard.
Posted on Dec 16, 2009
Jack_Dawson
  • 287 Answers
SOURCE: orange light comes on then off, battery not
1. Try to charge your battery for atleast 6 Hours.
2. Check your battery, whether it's in good condition!
3. If not replace it with the compatible one!
Posted on Jan 02, 2010
After about fifteen minuetsof playing it turns it self off it also feels warm to the touch
Solid green or solid orange light: Your power supply is working.
Flashing orange, solid red, or no light: Your power supply may need to be replaced. Try the following solutions:
  1. Try plugging your console's power supply into a different electrical outlet. Do not use a surge protector.
  2. If the power supply light is solid red or flashing orange, unplug the power supply and let it cool for 30 minutes. Then, plug the power supply back into the outlet.
There is no crack or damage done to it right?
Also try plugging it into the wall dirteclty no surge or power strip and let it lay flat
Nov 19, 2013 | Microsoft Cpa09-010a Ac Adapter Xbox360...
X9575 won't power on
Check with Lexmark to see if there is a reset button for unit
Aug 22, 2017 | Lexmark X9575 InkJet Printer
When tv is off, after some time standby light flashes then switches to orange (as displayed when tv is on). Does this for hours, TV then comes on without prompting. TV is brand new but does this daily.
The problems u describing are causes by the tv power supply board.That the board,where the power a/c cord plug into it.This tv is brand new take ur warrenty repair for the power supply board or take it back where u bought it get a tv replacenent.
Jan 03, 2011 | Grundig GU22DVDPX 22 in. LCD TV
My Dimension 5150 box will not turn on! Just blinks, looks like an orange light. Monitor comes on then goes off to orange...
- disconnect the power cable of the box from the back of the tower and press and hold down the power button for 10 seconds (remaining power will be depleted).
- Now try using a different wall outlet.
- Check the diagnostic lights to see if the specific problem is identified (the computer has four diagnostic lights labeled "1," "2," "3," and "4" on the front panel). Also, see "Power Problems" in your computer Owner's Manual and/or Service Manual.
http://support.dell.com/support/edocs/systems/dim5150/en/sm/tshoot1.htm#wp1120147
Nov 03, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Powerless Canon W8400
Hi Wynstrom, just curious, I'm having the exact same issue. Did you ever find out what the problem was? I would love to know if you did.
Sep 22, 2009 | Canon imagePROGRAF W8400 InkJet Printer
Pan. toughbook c-29 light will turn/flash on but hd won't startup or screen
sounds like a capacitor issue with the boards secondary supply side to me, recommend you dis assymble and check capacitors with low esr meter to determine which way to start trouble shooting power delivery issue. Obviously your getting power to the plug but have you LOAD tested the power supply? Try another one to see?
Feb 11, 2008 | Panasonic Toughbook 48 Notebook
Canon Pixma MP150 Error code E 42
Had exact same problem. Scanner light should come on at power up. Found ribbon cable connecting scanner unit to base had come unplugged from socket on circuit board. The ribbon cable is one of three found near back hinge of scanner and is hidden underneath the other two. It should drape over the edge of circuit board and then plug into small recepticle on inner side of board. I plugged it in and printer works again. Hope this helps.
Nov 04, 2007 | Canon PIXMA MP150 All-In-One InkJet...
MY PRINTER JUST STOPPED WORKING
Sounds like the printer will not pass its power on self test.
Possible a power supply related problem.
Contact the manufacturer to determine if it is still under waranty.
Oct 12, 2007 | Epson Stylus CX6400 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
37 people viewed this question
Seeker5211
Seeker5211
