Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
The brushes spin fast until I put it down on the carpet
I have looked at the brushes and see nothing in the way. The brushes hardly spin when placed flat on the carpet.
    Problem Solver:
  • 33 Answers
Raise the bottom to level of the carpet , just so it hits, must be a lever in the back, its meant to sweep up debree to **** up, there is nothing yet to bring pile up
Posted on Sep 28, 2009
My soniclean vacuum runs but as soon as I put the vacuum to carpet or floor the it shuts off and the check brush light comes on. Nothing is blocking the brushes or stuck in the intake hole
Sounds like the belt for the brush is worn, stretched, or loose. Replace the belt. OR the brush is set to low or set for hard floor. Set the brush up to next mark until it works. Using it set to low can cause the brush belt to stretch over time. If it spins when not in contact with the floor- it is the belt.
May 31, 2017 | SONICLEAN Vacuums
Shark navigator freestyle just stopped picking up
Usually when a vacuum stops picking up it is because the brush roll isn't spinning or isn't spinning fast enough when vacuuming. It may spin fast when you look at it but not when you put it on the carpet. It takes a good tight belt and a good brushroll to vacuum properly.
Mar 08, 2017 | Shark Vacuums
The beater brush will no longer drive under a load on short pile carpet
Have you tried changing the height adjustment? There should be a knob or lever that allows you to adjust the height of the beater brush to accommodate different carpet lengths. Even with a new belt, the brush will not spin if the height is too low. Try adjusting it all the way up, then while it is running, adjust it down until there is some resistance. The beater brush should just barely scrape the top of your carpet.
Aug 30, 2015 | Riccar 8955 Upright Vacuum
Why are the brushes turning until they are placed on the carpet?
The brushes are not powered by a motor but by the exhaust of the vac motor. They must have lots of air to even turn at a slow RPM. You may have a lint blockage on the air which cuts the volume of air to the turbine that spins the brushes. Look for lint on the filter. I recall it was on the operators left side on the base of the machine towards the front.
Jul 06, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Riccar 8625 doesn't seem to beat carpet but the brush is turning
Your 8625 is well over 20 years old. If it's been over a year since you've replaced the belt start with a new belt. Belts lose elasticity and should be replaced at least once or twice per year. The brush roll will still spin and appear to be working fine but when you put the brush roll onto the carpet it will stop spinning fast enough to clean the carpets.
Jan 25, 2014 | Riccar 8650/8625 s Vacuum
5 BRUSHES DO NOT ROTATE WHEN IN CONTACT WITH CARPET
HI There,
When the brushes on a Hoover SteamVac stop spinning, it can be caused by several things. The most frequent problem is that there is debris in the brushes such as pet hair, or lint, that prevents the brushes from spinning. Usually if you remove the brushes and clean them thoroughly, this will fix the problem. This sounds to me like what is the problem on your machine, as you make it seem as if the brushes spin, but only stop spinnning when you put them down on the carpeting.
The brushes on your Hoover are driven by a turbine brush gear assembly, not a belt. Sometimes this part can go bad, but usually when it does, the brushes won't spin at all, even when they are not on carpeting.
Anyways, here a helpful guide that I've done that shows you step by step how you can diagnosis the problem with your brushes:
First, what you'll need to do is take the brush block out of the machine. To do this there are 4 clips on the brush block. You will need to turn the machine upside down, and pull down on the brush block to where it won't pull out any farther. There are 4 clips, 2 on top, and 2 on the rear of the brushes. (See picture I have circled one of the clips in red). Simply press these clips at the same time, and pull the brush block out of the machine.
I'd say that 60% of the time that I see this problem, the main issue is that the brushes just need to be cleaned. If you have pets in the home, a lot of the time the pet hair will just be lodged inside the brushes, will prevent them from spinning. Use a pressurized water hose with spray nozzle is ideal) and spray each brush with water to dislodge any pet hair. You should be able to get these brushes spinning when you spray them. Spray each brush until the brushes are spinning pretty fast. Re-insert the brushes into the machine, and test to see if the cleaning has fixed your problem. If the cleaning still fails to fix the problem, take the brushes back out of the machine.
Now look at the brush stem that goes into the turbine inside the machine. This is the green pole pictured in middle of the brush block. Examine this pole to determine if the top of it has broken off. It should exactly how the picture shows it. Make sure that the plastic has not broken.
If the pole has broken, you will simply need to replace the brush block. If the pole is not damaged, the next thing to try is to turn the machine on while you have the brushes out. Look inside the machine, where the pole goes into the turbine (also important, make sure the switch for the brushes is turned to "Rotating Brush Speed Hi), this female receptacle should spin when the machine is turned on. It is important the try this when the foot pedal is released, and the handle down, and not in the upright position, as there is an internal switch that shuts the brushes off when the machine is in the upright position.
If you notice that the female receptacle where the brush pole is inserted is spinning, then your turbine is fine. If this part is not spinning, then most likely you will need to replace your turbine.
If you find that your turbine needs to be replaced, I have written a step by step guide that shows you each step on how to replace your brush turbine gear. Here's a link to that repair if you need to do it:
http://www.fixya.com/support/r4530769-diagnosis_fix_hoover_steamvacs_when
Hope this helped you, please be sure to rate my repair or leave me feedback if you found this helpful, thanks so much!
Chris Jones
GoVacuum.com
May 01, 2010 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
The powerhead is weak, the brush turns until it is placed on carpet.
Empty the dirt collector. If there is insufficient air flow, the brushes will not spin.
-=/ Daft Tech /=-
Oct 25, 2009 | GE 106766 Bagged Canister Vacuum
I have a Bissell Pro Heat 2X carpet cleaner and the brushes spin, then stop. I turn it off and when I re-start, the brushes do not spin until I push foreward. The it spins and stops again. Both belts are...
The reason for the brushes to stop when it is above any surface is there is a switch in the handle that stops the brushes so it dont burn your motor up it may have a faulty switch.
Jul 14, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Hoover Tempo Widepath Blows Dirt Out Back on Hard Surfaces
lots of times switching to hard surface floors you need to slow down because the air flow that does the actual picking up of the dirt can't work as fast as the spinning brush so the brush is throwing the dirt out the back before the suction can pick it up. Try slowing down
Jun 11, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
81 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
