Question about Hampton Bay 24002 Ceiling Fan
Change the bulb to my ceiling fan and now the fan and light does not work?
  • 48 Answers
There is a small brass tab inside the socket that gets compressed by some bulbs...when you change the bulb it doesnt spring back out towards the bulb base like its supposed to. to fix it u need a small plastic screwdriver or a wooden fingernail tool...ask your wife she probably has a dozen of em...SHUT OFF THE POWER as a precaution...not by turning off the switch but at the breaker panel...then remove the bulb and gently insert the tool in the bulb base and pull the little brass tab towards you about 1/4 of a inch...reinsert the bulb and turn power back on. This should solve your problem.
Posted on Sep 28, 2009
SOURCE: How to Change light bulb (yes, really...)
Finally, we got it. As some of these solutions suggest, the trick is to hold the metal rim while turning the glass globe to the left. It took two of us, one holding the rim and the other turning, but voila, there it is.
Posted on Mar 23, 2008
SOURCE: minka aire concept II ceiling fan bulb replacement
I found that the minka website has the installation manuals online.
www.minkagroup.net/http://www.minkagroup.net/minkaairemanuals.asp The glass cover on a Concept I fans turns counterclockwise. I had to use rubber gloves to get a good grip on the light cover.
Posted on May 03, 2008
SOURCE: changing light bulbs in Hampton Bay model AC 527 Ceiling fan
I have the same fan
Only try to turn the glass cover in the opposite direction that is posted for close. You will want to do this after the light has cooled. It tends to sieze when it lense heats up.
Good Luck
Posted on Aug 23, 2008
SOURCE: hampton bay ceiling fan , model # 55295
I had the exact same problem. To solve it, I had a friend hold the area of the fan that the globe screws into. I wore rubber dish gloves to get a good grip and pushed up slightly on the globe as I turned counter-clockwise. My friend held the other part and turned clockwise a little as well. It took a lot of pressure for it to finally come loose and then we just turned it about another 90 degrees and the globe slips right out of the groove.
I couldn't believe how hard this was to do.
Posted on Feb 14, 2009
SOURCE: hampton bay model 55295 fan works, light doesn't
Did someone give you advice on this? My fan is doing the same thing. Fan works fine, but the light does not. Looks like the electricity is not making it down to the ballast - trying to figure out how I can repair it.
Posted on Nov 25, 2011
How to fix ceiling fan light
Make sure the light wire is connected to the receiver & bottom of fan.You should set the light to the on position when using the remote and leave it that way.
Sep 10, 2015 | Hunter 52" Ceiling Fan With Light And...
Minks aire mojo ceiling fan light will not come on
Try changing the bulb. Make sure the bulb is touching the connector in the bulb socket.
Aug 15, 2014 | Minka Aire Ceiling Fan
Minka Aire Ceiling Fan light wont come on
Probably needs a new remote receiver.Contact Minka Aire @ 1-800-307-3267
Apr 30, 2013 | Minka Aire Ceiling Fan
Hunter ceiling fan fan is working but lights are not
Make sure light wire is connected at the ceiling & at the bottom. Otherwise it's probably the receiver. 1-888-830-1326 ( Hunter parts )
Jan 05, 2013 | Hunter 52" Ceiling Fan With Light And...
Lights flicker on ceiling fan: We have 4 cfl bulbs in a ceiling fan light fixture that have recently started to flicker. They've been there for a while without the problem, so it's not a matter of a new...
It is not a ceiling fan or wiring problem. It is your bulbs. Normal CFL bulbs do not work in dimmers or with remotes. Remotes work on RF signals and cause interference with the bulbs. You may also notice a buzzing sound and the lights may not go out when you turn off the switch. It is a fire hazard, can invalidate your warranty on the bulbs and will shorten their life. Try changing the bulbs to the new dimmable CFL's and see if it helps. It should eliminate your problem altogether.
Mar 15, 2010 | Hampton Bay 52 In. White Redington...
Como Fan MInka Aire light bulb burned out
remove the cover and unscrew the bulb. get a replacement especially designed for a ceiling fan.
Sep 07, 2009 | Minka F603-WH Ceiling Fan
Fan works, light doesn't on Hunter ceiling fan
I would begin by testing each bulb in a different socket somewhere in the house.
Apr 06, 2009 | Hunter 27187 Remote Control
Hampton bay model 55295 fan works, light doesn't
May 27, 2008 | Hampton Bay (261025) Dual Mount Ceiling...
Change light bulb
I have a fan just like that one to change a light bulb all you have to do is unscrew it from the fan itself and if that dosnt work then unscrew the plastic cover or unscrew a screw on the plastic cover
Dec 30, 2007 | Madison Avenue 04889 Hampton Bay Ceiling...
Hampton Bay 24002 Ceiling Fan Logo
119 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
