Question about X2Gen MG15VT 15" LCD Monitor
Monitor w2gen mg15vt
When the computer is on and the on button for the monitor is pushed it lights green briefly.. color band appears.. then light goes to yellow and nothing appears on the screen. I have tried turning everything off and unplugging it but it doesnt help
  • joe problem Dec 28, 2007
    Mine is doing the same thing. I have the 19" monitor. Any solutions???
I had a somewhat similar problem. Mine was still under warranty. bad news is that x2gens parent company just filed for chapter 11. which is why their RMA website is unresponsive. I bought mine through a 3rd party retailer who refunded the entire purchase price of the monitor. HELL YEAH! Good luck unloading all ur x2gen stuff when it craps out cuz all warranties are essentially useless now.
Posted on Jan 04, 2008
Screen won't turn on
You can try to do the monitor self test.
Monitor Self Test:
1. Physically test the monitor autonomously from the computer.2. Switch both the monitor and the computer off, and then disconnect the VGA cable le from the computer.3. Turn the monitor on, pressing the power button for about three seconds. The self-test screen will come up .4. If the image is clear, bright, and shows red, green, and blue, the monitor is working properly. Video issues may be due to the video resolution in the computer, and not the monitor.5. If the image is not apparent and intense or the colors are not accurate, then the trouble is with the monitor or some of the (OSD) settings. In this case, test your particular monitor's information for OSD.
It is always important to check the color of your power light for so you can distinguish if the monitor is defective. Getting red lights on the the power panel states that the power section of the monitor is faulty.
Dec 03, 2011 | Emerson Televison & Video
Monitor suddenly went black.If on/off button pushed screensaver briefly flashes on but then back to black screen.Green power light is on but nothing on screen when using computer
Try to replace all bad capacitor on power inverter board and turn it on. Hope it will work perfectly.
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jun 28, 2011 | Hanns.G Corporation HW191D 19" LCD Monitor
When computer off monitor displays orange light.when i turn computer on green light briefly on than goes out. Monitor remains black'
This is not always a problem with the monitor. It could also be caused by a faulty display card in your computer. Try plugging your monitor into a working computer to determine where the problem lies.
Best wishes,
Graemevm
Jun 08, 2010 | Computers & Internet
No video output from my computer.
Are you using an ON-board graphics adapter or a separate VIDEO CARD? Some motherboards lets you set the video output to "DISABLE ONBOARD GRAPHICS" if you have installed a video card (BIOS). You may have plugged the monitor cable to the onboard D-sub connection instead of using the Video Card D-sub connector.
Normally a flashing green power light means the input it receives from the video output is too much. You may have set the resolution too high or the bit depth too high. Consult the monitor manual on the rates it can handle. To be safe, try starting the computer on safe mode just to check if it is indeed the problem. If it boots properly and you can see your desktop, then there's a chance that the setting was too much for the monitor to handle.
Hope this gives you an idea.
Mar 15, 2009 | SAMTRON 94B 19 inch LCD Monitor
Dell E151FPp LCD Monitor
Next time you reset, check both the monitor settings and your BIOS settings for wake up
Feb 24, 2008 | Gateway FPD2275W LCD Monitor
Monitor remains in standby
turn the monitor off and the computer off. unplug it from the wall. let set for 10 sec. make sure you have it in the right place and in all the way. turn computer back on, then the monitor.
Dec 18, 2007 | X2Gen MG15VT 15" LCD Monitor
Samsung color monitor
This problem may arise from monitor as well as from cpu.
First of all check it by unplugging the VGA monitor cable.
This will display the "Check Signal Cable" depending on the model of the monitor. But a message will appear rolling on the screen, if it is not a very old monitor.
If the message is appearing OK and green light is continuously on, that means ur monitor is working fine.
The problem may be with VGA cable or with the booting of CPU and probably the RAM. Recommended solution is to reconnect the RAM and then try, if u think u can do. Otherwise call a hardware engineer.
If there is no message and still the light is turning green and yellow. That means the problem is definintely in the monitor.
Thankyou,
Your well wisher
Nov 27, 2007 | SAMTRON 55V 15" CRT Monitor
Dell ultrasharp 15 inch flat panel lcd has no power and does not turn on at all
Disconnect the monitor from the computer, then turn it on. You should see three bands of color (red, green, and blue), which is the self-test feature of the monitor. If you can see all three colors, the monitor itself is probably OK, and it will mean that you need to check the connector on the monitor cable, the connector on the back of the videocard in the back of the computer, or reseat the videocard itself. One of the connectors could be damaged, or you could have a bent, broken, or missing pin within the connector. If a pin is bent and touching the shell of the connector, it can send the video signal to ground, making the monitor appear to be dead. BE VERY CAREFUL if you try to straighten the pin; they are fragile, and if you break the pin off completely, you will have even more problems to deal with... If one or two of the color bands are not visible, the LCD monitor is defective, and you'll have to decide whether it is cheaper to repair it, or simply to replace it... If you still can't locate the problem after checking the system as I've described, get another monitor to test the computer with. If the second monitor works properly, you most likely have a problem with the Dell LCD; if the problem still exists after switching monitors, then you most likely have a problem with the computer, and NOT with the Dell monitor...
Apr 01, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
It totally sounds like the backlight is toasted. If that is the case you will have to replace them. Normally if the power inverter is shot, the monitor will power up briefly at least and then shut off. If you can use a flash light and see some sort of image on the screen you know that your VGA chipset works however your backlight(s) are burnt out. If not, more than likely your power supply (power inverter chipset) is broken and needs to be replaced..
Mar 28, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
X2Gen MG15VT 15" LCD Monitor Logo
113 people viewed this question
Top X2Gen Computers & Internet Experts
jason
Sandy Moore
Sandy Moore
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
