Question about 2wire Computers & Internet
My service provider has installed a gateway.2wire router
My service provider, SaskTel, installs the gateway 2wire routers that provides home internet wired and wireless services. On certain sites like kijiji, it takes forever to load up a page, typically a minute or two. watching the status bar on the bottom, most of the time it shows ''waiting for gateway.2wire.net''. What's wrong?
    Problem Solver:
  • 11 Answers
Hi try to do the following steps and revert back with results:
1. click on start>>click on run>>type "cmd" and hit enter.
2.In the black window that appears type tracert kijiji.com and hit enter, once it completes it will show the time in the middle column (eg:160ms).
3.Look and check if any value is greater than 240ms,if so then there is some latency problem which can be either due to the website or the Internet service provider.
Posted on Sep 28, 2009
How to install to att 2wire 2701hgb modem router
Plug power cord into back of modem and then into an electrical outlet. At this point you should see the lights on the front of the modem beginning to come on.
Check the front of the modem for a solid green DSL light. If the light is still blinking, allow a few more moments before proceeding to step 5. A blinking DSL light indicates a break in the network and will require the help of your service provider if it does not turn solid green.
Open your internet browser and type the default gateway into address bar. The default gateway will be provided by your service provider. Newer model 2Wire modems automatically direct you to the installation instructions when the browser is opened.
Click on "Run System Setup Wizard" in the lower right-hand corner. It may require the system password. This password will be provided by your service provider.
Select your timezone and click 'Next.'
Enter your ISP provided login information and click 'Next'. This should authenticate your credentials on the network and complete the installation.
Jan 02, 2013 | NetGear RangeMax Dual Band Wireless-N...
The dsl light keeps blinking red no Internet connection
for LED LIGHTS interpretation: refer to this link:http://www.sasktel.com/search/controller//Internet/2Wire-Gateway-2700-2701-LED-Status-Lights-Guide/_/R-Support_13750/Record-Support
NOTE: everything that says contact SASKTEL TECH SUPPORT refers to your Internet Service Provider
Qwest Technical Support at 1-800-247-7285
SASKTEL TECH SUPPORT Anywhere in Saskatchewan :1-800-773-2121
Outside Saskatchewan (anywhere in Canada and USA):1-888-773-2122
Anywhere else in the world:1-306-522-1820
AT&T ' Yahoo! High speed Internet
Call +1 877 722 3755 (877-SBC-DSL5)
Hope This helps
Aug 14, 2011 | 2wire 2700HG-B Router (2700HGB)
My dsl light is flashing and the 2wire router just clicks over and over again. All other lights are on and green except for the Internet light (because dsl is flashing). Router has been working perfectly...
Hope This helps
Jun 25, 2011 | 2wire (2701HG-B) Wireless Router
I have a 2wire gateway modem/router and i need to reset it, but i dont have the default password located on the bottom of the modem/router because it fell off. I need to find out what the default password...
Open your Internet browser.
Type http://gateway.2wire.net/setup into the browser's address line.
You should see your key on the setup page.
Back-Up Key Codes
In most cases, you will receive a key code from your ISP. This key code is used to activate the 2Wire gateway. If you did not receive a key code, you can use the key codes provided in the following table.
If your Internet Service Provider did not provide you with
a user name, password, or IP address to set up your
Internet connection, your broadband connection most
likely uses DHCP (Dynamic Host Configuration Protocol)
and you should use this key code.
52EU-2374-2262-22AT-B222
If your Internet Service Provider gave you a PPPoE
username and password to set up your Internet
connection, your broadband connection uses Point-to-
Point Protocol over Ethernet and you should use this key
code.
52EU-2374-6262-22AS-B22Y
If your Internet Service Provider assigned you an IP
address to set up your Internet connection, your
broadband connection uses static IP (Internet Protocol)
52EU-2374-2E66-22AS-B2TW
If your Internet Service Provider gave you a PPPoA
Point Protocol over ATM. In this case, you would use this
key code and Microsoft Dial-up Networking to connect to
the Internet.
52EU-2374-A222-22AS-B2QK
Apr 21, 2011 | Computers & Internet
How can i install my 2wire1701hg gateway routter i dont have cd to run the software
If you connect an RJ45 network cable from the router to a near by pc/laptop, open a web browser and type 192.168.1.254 into the address bar, you may be asked for a username/password if the router responds which is normally printed on a small label and stuck to the side of the router. Once you've got access it's just a question of entering the details provided to you by your ISP (Internet Service Provider). Manuals for the 1701hg can be found at this link and can be downloaded in pdf format.
Apr 12, 2011 | 2wire (1000-400108-001) Router
Cannot connect to web.
Follow this steps
1. Connect the provided power adapter from the gateway's POWER port to an electrical outlet. The POWER light on the front of the gateway should be green. 2. Connect the provided gray phone cable from the gateway's PHONE LINE port to the DSL filter jack labeled DSL/HPNA. 3. Connect the yellow Ethernet cable provided with the gateway from the LOCAL ETHERNET port on the gateway to your computer's Ethernet port
With your computer completely started, verify the POWER and ETHERNET indicator lights on the front of the 2Wire gateway are green. If they are not, see "Understanding the Indicator Lights" on page 15. The INTERNET indicator light will not turn green until the gateway software has been installed and an Internet connection has been established.
Mar 22, 2011 | 2wire Computers & Internet
I want to install a 1701HG gateway to my computer but after I installed I dont have access to the internet? what I have to do to make it work?
check first if you computer communicate with router, from router it can communicate with hub (internet provider) and check if your ip range act as router or a bridge.
Apr 10, 2010 | 2wire (1000-400108-001) Router
Cant get the broadband link up
The picture looks like it is a 2wire DSL modem. If this is service from AT&T/SBC you should have gotten filters to put between the phone and the wall jack make sure those are installed. Power off the 2wire modem ( unplug power )Then disconnect all computers and routers you may have from the 2wire router. Plug one computer in to the router then turn on the computer first then plug the power back into the 2wire router. Wait and see if you get an uplink. If not go to this webpage http://homeportal.gateway.2wire.net
The password is probably on the serial number sticker on the 2wire.
Once you are there click on Broadband Link icon. If it says connected you are good to go. If it does not then call the internet provider for registration of 2Wire router to the service
Aug 07, 2009 | 2wire HomePortal 1100 Router...
Need password for 2wire network
The best solution is to reset the router. The easiest way to do this is to find the reset button, usually on the back of the router there is a pin hole button. Use a pin or pencil to push the button.
Be warned, any special settings will be lost, but most installations of home network routers such as the 2Wire Router/Gateway is the default settings. If you have other than the default settings, then contact the person/organization that set up the 2Wire for you, such as your ISP/Internet provider.
Jan 03, 2009 | 2wire HomePortal 100 Network Adapter
2wire 2700HGV cannot detect wireless Linksys IP camera WVC54GC
Purchase a different router and return the 2wire to the ISP explaining it is not compatible with your equipment at home. You may need to provide them with the new router's MAC address.
Nov 21, 2008 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
162 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
