Question about Gladiator Freezer GAFZ21XXRK
Gladiator 21 cubic ft. The bottom is freezing perfect. The back of the ref is hot to the touch around 95 degrees, the temp in the unit is about 50 degrees what could be the problem
    Problem Solver:
  • 33 Answers
It may be to enclosed, to close to wall, try moving it, also clean under it every 2 months, coild attract dust like mad
Posted on Sep 28, 2009
Frigidaire Freezer acting goofy
Make sure everything is clean of debris and I would personally see if you could cool the area around the unit. Maybe use a fan or turn the air down in that room. Humidity and hot temps kill a unit's sealed system.
Jul 24, 2012 | Frigidaire 21 cu. ft. / 595 liter Upright...
New fridge freezer isgetting very hot on both
This heat is normal. The refrigerator you have in your kitchen will have the condenser coils which get very hot on the bottom or back of the frig. A deep freeze has the condenser coils inside the walls of the freezer. Hot temps are normal when it is running.
Try to leave an inch or so of space around it for air flow and that will help.
Apr 24, 2010 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Gladiator ref is not cooling properly
Check to see if there is cold air coming from the freezer to the refridgerator side through the vent holes The compressor maybe getting weak or the freon charge maybe low. Does the unit run a long time before it shuts off? 50 degrees is not cold enough for a freezer. You should be around 32 or less.
John
Sep 28, 2009 | Gladiator Freezer GAFZ21XXRK
Freezer outside walls are very hot. Not maintaining temp
Hi, The walls are getting hot because that is where the condesor coils are. The condensor coils are where the heat is disperst that is trap as the coolant pumps through the evaporator coils inside. The fact that it is holding 0 degrees is a good sign. Is this freezer in a garage?
Check the door seals to make sure no heat is getting into the freezer other then when the door is opened.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 24, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Won't freeze
Is the compressor running the whole time? If so may have a problem with a refridgerant leak....check the compressor in the rear of unit, feel if its hot....may be as simple as a relay.
Jun 17, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer Not Freezing Food
there is a circulation fan and also a vent. Either the fan is blowing, or there is a cloged vent.
Feb 11, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Gladiator Freezer GAFZ21XXRK Logo
196 people viewed this question
Top Gladiator Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Gladiator Freezer Expert? Answer questions, earn points and help others
