Question about Brother BRTPT65 PT-65 Label Maker Printer
Brother p-touch labeler extends too much unused tape how to adjust waste
  • jfraser10 Sep 28, 2009
    I am asking for an answer
Democritus
  • 120 Answers
SOURCE: change cartridge Problem - Brother BRTPT65 P-Touch Model PT-65 Home and Hobby Label Maker Printer
Manual is here: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PT_65_65SB_65SCCP_65SL_65VP_EN_166.PDF
Your cassette appears empty or otherwise non-functional. Please see page 2 of the above manual.
Posted on Jul 11, 2008
SOURCE: ptouch 1100QL waste of tape issue
It isn't actually "before the actual letter comes out," as you said, but rather after. You have probably noticed that you must do a "feed" first or the cut won't clear the end of the label and you have to do it again. This just reflects the distance between the print head and the cutting bar.
There's no way to avoid this if you must have the one label you just printed right away and you don't have any more labels to make at the moment.
However, if you have several labels to make, you can economize by printing them one right after the other (without any "feeds" or cuts), then once you're all done, do a "feed" and cut. The labels will be close together, with little waste except at the ends, and you can cut them apart with a scissors.
Posted on May 26, 2009
paul7of9
  • 1189 Answers
SOURCE: too much tape
Hi, it seem your label maker is set to the last(amount) of labels printed. Go to: Print Labels, click; Number of Labels; clear to set to (1) Label. That should stop the run off of labels. Thanks paul70f9
Posted on Jan 04, 2010
komguy
  • 2306 Answers
SOURCE: Too much lead on each label. Wasting tape. How do
You can't adjust the lead since it is just the tape from the printhead to the cutter, the best way to save is to print several labels without cutting and use scissors to cut them apart after all are done. Otherwise it will advance to cut each time and leave the blank space from the head to the cutter blade.
Posted on Feb 05, 2010
SOURCE: Brother P touch label maker language settings? how
Tune machine off. Press and hold F and the delete button (2 buttons below the F). Whilst holding these down, turn the unit on by pressing and releasing the power button. Then release the F and delete buttons and the language option will appear.
Posted on Jul 20, 2010
Too much lead on each label. Wasting tape. How do you adjust?
Feb 05, 2010 | Brother P-Touch 1180 Label Printer
I need help to change the tape on my p-touch 55 brother labeller
Hello. here is the owner manual http://www.ptouchdirect.com/ptouch/manual/PT55.pdf
Just look at the section entitled "installing/changing the cassette tape". Regards, Joe
PS kindly rate my answer. Thank you.
Jan 24, 2010 | Brother P-Touch 1180 Label Printer
Ptouch 1100QL waste of tape issue
Apr 18, 2009 | Brother P-Touch 1180 Label Printer
P-touch 1000
The tab length is preset. You can't shorten it.
Jan 24, 2009 | Brother P-Touch 1180 Label Printer
Printed Tape Cuts Off Letters
I was having the ame issue. Found the solution on the user manual (posted online). Press Function, scroll to "Margin", press "Function", use arrows to select "#" or "##", then press Function again. Now it should print with a margin, thus not cutting off your letters. Mine was set to "-", which is basically no margin.
Dec 29, 2008 | Brother P-Touch 1180 Label Printer
LOADING TAPE INTO A BROTHERS P-TOUCH
I'm on my second machine since December. Neither P-Touch would feed the white tape, the other layers bunch up inside the machine. Called Brother, and they were no help (indeed not much interested in my problem), except to suggest I clean the rollers with alcohol/q-tip. This action did result in the tape feeding, but not properly as I now get an unusable label strip with all three layers, and printing on the clear layer backed by black layer. POS if you ask me; it is going back to the store.
Nov 17, 2008 | Brother P-Touch 1180 Label Printer
Brother P-touch labeling system PT-1750
You dont. This machine was designed to waste your money and raise Brothers profits.
Oct 04, 2007 | Brother PT-1750 Thermal Label Printer
Labeling system trouble-shooting
This is a duplicate post, click on the following like for the original: http://www.fixya.com/support/t133614-labeling_system_trouble_shooting
Feb 10, 2007 | Brother PT-65 Personal P-Touch Electronic...
Brother BRTPT65 PT-65 Label Maker Printer Logo
103 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
