Question about Delta Faucet Delta RP17453 Pull-Down Diverter Tub Spout
My delta faucet pull down diverter tub spout is
I have a brand new delta faucet RP17453 pull down diverter tub spout not working properly. It won't divert water to the shower head. Need help.
  • 129 Answers
It sounds like it could be manufacture defect. Take it back for a new one.
Posted on Oct 05, 2009
I have a leak under my bathtub/shower it only leaks when the shower is on.It's not the drain or the pipe up to the shower head
There may be some leakage in pipe.Take the help of experts.Nowadays there are many leak detection services that can help in solving such problems.
find a leak in wall
Aug 02, 2012 | Delta Faucet Delta RP17453 Pull-Down...
I have water hammer when using shower only
Your Delta faucet is open and close the valve very quick. This will produce back pressure on pipes. You need an anti water hammer / back pressure suppressor to avoid this problem. You can find it in local market.
Regards
Mar 30, 2011 | Delta Faucet Delta RP17453 Pull-Down...
I have a Delta Tub/Spout Pull Down Diverter that has a pretty persistent drip. The HOT and COLD handles are turned off and seem to be as tight as they can be. After doing some research online I believe...
If your Delta RP17453 Pull-Down Diverter Tub Spout stops dripping after 5 minutes, your ok. If it never stops dripping, you need to replace delta faucet cartridge(s) behind the handle(s). This is were the water turns on and off and stops the water flow to the tub spout.
Delta faucets are some of the easiest to repair, and parts are usually available at any hardware store or home center. If you have a two handle faucet, replace both delta seats and springs and stems. If you have a single handle Delta faucet, replace the entire cartridge.
Jan 26, 2011 | Delta Faucet Delta RP17453 Pull-Down...
I have a Delta shower assembly with a pull-down diverter. When I engage the diverter for the shower, half the water seems to make up to the shower and the other half is forced through the back of the...
One of 2 things is happening. Either the o-ring is shot, or you have a hairline fracture of the plastic around the brass adapter. The o-ring is a #18, but if there's a crack in the plastic you'll need to replace the spout.
Oct 03, 2010 | Delta Faucet Delta RP17453 Pull-Down...
I have a garden tub w/o a shower attached. However, the fixture in the tub is the Delta pull down diverter (dont know why they would put that in a tub w/o a shower). Anyway, the diverter was pulled down...
If it was me... I would replace that spout...
the spout either is threaded on or it has a set screw on the bottom at the back that you loosen and then pull the spout off by pulling straight away from the wall...
Check and see if the spout has the hole for the set screw...if not then twist it counter clockwise and it will turn off...
then repalce the spout with a new one with out the diverter...
heatman101
Aug 05, 2010 | Delta Faucet Delta RP17453 Pull-Down...
Just installed a waterpic shower head, half the water comes out of faucet and half the shower head, any solutions?
If your tub spout has a knob that you lift to divert the water to the waterpic then replace it with a Delta service part #RP17453 pull down spout. It always sends 100% of the water to the shower head and will always snug tight to the wall.
May 24, 2010 | Water Pik & Wallmount Showerhead
Water sprays out the diverter
Remove hot/cold button in handle, remove screw/pull off handle. Remove the two screws in the wall plate/remove plate. Use a wrench to remove the diverter assembly. Get new diverter assy and reinstall eveything. You don't need to turn off the water.
Jun 09, 2009 | Delta Faucet #RP320 Divert Assembly
Delta Faucet Delta RP17453 Pull-Down Diverter Tub Spout Logo
1,306 people viewed this question
Top Delta Faucet Plumbing Experts
Donni Steen
Ed Mac
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
