Question about HP LaserJet 4100n Printer
Tray 1- load plain letter
Hi
I have a problem with my HP 4100n. When I try to print I am getting the message...tray 1 load plain letter. I have tried a cold re-set, have checked printer preferences on PC and have got those on LETTER (following an answer on your problem page to someone elses problem) but STILL I cannot get the printer to automatically take from tray 2 or 3.
Orange light keeps flashing too. Any ideas? I would be most grateful! :-)
Thanks
Linda
  • malps Dec 23, 2007
    Thanks for these solutions! Rushing off now for Christmas- but will give all of them a whirl as soon as I am back! Will let you know but in the meantime- have a good one!
  • malps May 22, 2008
    Thanks for that! It is working fine now thanks! :-)
    All the best
    Linda
  • HP Master
  • 1,113 Answers
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Posted on Dec 18, 2007
  • Soulvisitor
    Soulvisitor Dec 23, 2007
    update no left right...Squeeze the blue tab located on the right side of the tray and move it to the correct position based on the paper size required
  • 4 Answers
Dell 4100cn Color Laser Printer Error 024-965 - Load Tray 1
Cause:
The "Paper Tray Inserted" sensor buttons are not being depressed by the Paper Tray so the Printer thinks no Tray is inserted even if the Tray is properly inserted.
If you pull out the paper tray and look at the Paper Tray opening, you will see three white vertical sensor buttons along the left-hand side at the mouth of the aperture where the paper tray slides in. These three white vertically aligned push button sensors tell the printer that the Paper Tray is inserted when the paper Tray is
properly pushed all the way in and aligned. It also signals to the printer by noting which button is depressed whether the tray is a Letter Size or Legal Size tray that has been inserted. These buttons which are fully visible as soon as the tray is slid out can move out of place and even fall into the wall of the Tray slot preventing the buttons from sensing the tray.
Solution:
Click it back into place. There should be no play and the buttons themselves should be the only thing that move and then only in an in and out manner. They should move out toward you when the Tray is removed and be pushed in when the tray in slid into the paper tray feedering slot. A pair of needle-nose pliers may be necessary to draw the button module out of the tray slot wall if it has fallen in. Once it is STIFFLY repositioned and the Paper Tray reinserted, reset the printer by opening and quickly reshutting the printer cartridge compartment. This action will recalibrate the printer, shut off the amber error light and resume the current printing job if one was in progress.
Posted on Aug 25, 2018
  • 398 Answers
Hello Linda,
The most common problem with the 4000 and 4100 series printers is the fact that the paper trays have a hard time maintaining the physical paper backstop, it will move out of place and therefore change the printer's paper size settings, most likely shifting into the A4 size. Please make sure the backstop is locked into the "LETTER" position, then reload the paper back into the tray. The tray 1 error appears because the printer can't find any Letter size paper in the trays. Once you fix the tray #2 and /or tray #3 issue the error message about tray 1 will go away!
Good Luck!
Rich Lilja
Posted on Aug 02, 2014
All i did was go to printers and printer preferences and made it print from tray 2 manually and tell it to print plain paper.
Posted on May 22, 2008
How do I change the default on my HP P30005dn to Tray 2?
Normal default on HP is tray 2, however if you do not have that tray set for plain paper letter size the printer will default to whichever tray has letter plain paper installed. You should also check your print driver default settings to ensure that tray 2 is set as default tray.
Aug 14, 2014 | HP LaserJet P3005dn Printer
My HP 4100N printer often automatically selects to print from tray 1 (the manual feed), when I want to print from tray 2 (the automatic feed). How do I set the default tray?
HP Laser Jet 4100 HP Not pulling paper from Tray 2
Action: The 4100 will look at tray 1 first then tray 2 If tray 1 is empty it will pull from tray 2 if the papersize matches the job otherwise back to tray 1 and ask for the paper. Your machine likely thinks the paper in tray 2 is not the size you want. For instance you have LETTER in tray2 But the machine thinks it is legal. The LJ 4100 detects the paper size in tray 2 automatically. If you print a configuration page: MENU them INFORMATION then ITEM then CONFIGURATION PAGE then SELECT. The page will print and show what size paper the machine thinks is in Tray 2 if it says LEGAL and you have LETTER you need to Check The Paper Backstop in TRAY 2. The back stop sets the length of the paper if it is not at Letter (8 1/2 x 11) the machine will not detect LETTER. Even if it just a little bit off or between positions.
If it is set at LETTER then you may have bad switches in the machine that are operated by the tray. Or the arms on the tray that operate the switches are not moving properly. You will find the arms on the rt, side of the tray and feel them change position when you move the backstop.
Hope this helps helps. Please keep us updated and remember to rate this answer. TF
Oct 18, 2010 | HP LaserJet 4100n Printer
WHEN PRINTING - THE PRINTER SAYS TRAY 1 LOAD PLAIN PAPER, USE PLAIN EXEC INSTEAD? THE PRINTER IS LOADED WITH 8 1/2 X 11 LETTER SIZE PAPER.
You have the settinigs on the printer wrong. There are two things you need to do:
1. Open the tray and check that the paper guides are set to 8.5 x 11 (letter). There are both length and width guides in the paper tray, and EXEC size is quite a bit off from letter-it is more than 0.5 inch narrower than letter. It is also shorter than letter.
2. On the printer, use the settings button to navigate to the paper size. (The exact wording may vary; it's been a while since I worked on a 4050. It may be under print settings.) Once you find the paper size menu, configure tray 2-yes, I'm sure-to use letter size, any type. By the way, on HP lasers, tray 1 is the fold down tray on the front, tray 2 is the tray that will hold 500 sheets of paper and is the "drawer" that you load. Don't ask me why they use that numbering system.
Feb 11, 2010 | HP LaserJet 4050 Printer
Refurb 4345 envelope double prints
Measure the distance between them and let me knw what it is. Make sure to measure from the same point to the next same point. For example name on letter is "Att: Mr Ed" you will measure from the left bottom of the "A" on "Att:" to the left bottom of the next instance of "Att:"
Nov 15, 2009 | HP LaserJet 4345mfp All-In-One Printer
How do I realign my hp photosmart c4480 printer?
To align the print cartridges from the HP Photosmart Software
1. Load letter or A4 unused plain white paper into the input tray.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
2. In the HP Solution Center, click Settings.
3. In the Print Settings area, click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog
box. In the Print Properties dialog box, click the Features tab, and then click
Printer Services.
box. In the Print Properties dialog box, click the Features tab, and then click the
Printer Services button.
The Printer Toolbox appears.
4. Click the Device Services tab.
5. Click Align the Print Cartridges.
When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
press the button next to OK.
The product prints a print cartridge alignment sheet.
7. Load the page print side down on the right front corner of the glass, and then press
the button next to OK to scan the page.
When the On button stops flashing, the alignment is complete and the page can be
removed. Recycle or discard the page.
Jul 18, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Hp2210 message ''press enter to align cartridges'',
from user manual::
To align newly installed print cartridges
1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
The HP All-in-One prints a print cartridge alignment sheet.
NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print cartridge.
Contact HP Support. Go to www.hp.com/support. ....
2. Load the print cartridge alignment sheet print side down on the left front corner of the glass with the top of the page to the left.
3. Press the Scan button.
The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet
Score the solution and download the manual if you need it
Mar 24, 2009 | HP PSC 2210 All-In-One InkJet Printer
HP4050tn laser printer "Manually Feed HP Tough Letter"
Hi artroebridge:
Thsi printer is asking you to load tray 1. You need to check the paper source. Print a configuration page and see what your trays are set for,and also check your print properties for the correct tray configuration (what tray u want to print from)
Jan 09, 2009 | HP LaserJet 4050tn Printer
Printing problems - i can only print manual feed...
the manual tray is the is the one above the tray,
1-either your tray is set incorrectly must be set to Letter/Plain
priority is tray 2 not tray 1
tray one is the by-pass / manual
since this printer does not have a screen on it everything is setup through the PC.
print a configuration page and you will see all the settings
Aug 05, 2008 | HP LaserJet 1022 Printer
Tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Jan 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
HP LaserJet 4100n Printer Logo
7,380 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
