Question about Goodman CKL42AR42 Air Conditioner
Air conditioning fan won't start unless I move the blades to give it a "jump start". Is this a capacitor problem?
    Problem Solver:
  • 17 Answers
This is a very common problem, especially if there was a recent power fluxuation. Your fan Capacitor is bad. the Capacitor gives the fan the needed power "boost" or torque to get it turning. your troubleshooting skills have already determined that the fan will work if given a :boost". The part will be less then $10.00 dollars. Call an a/c/ company and they should not charge you over $75.00
capacitors are rated by "uf" or micro farrads. yours will be 5 or 10.
Posted on Oct 27, 2009
  • 3,600 Answers
Yes it is you may want to try to oil the fan motor with WD 40 to see if it will turn without it but it is most likely time to replace the fan motor.
Posted on Sep 28, 2009
Blade won't move unless you manually spin it to get it started
I would check to see if mtr. has oil ports,if not oil mtr as best you can..Check for bad capacitor..If still having problems replace mtr
Dec 12, 2015 | Comfort Zone CZ700T 20-in High Velocity...
I have a central air condition carrier ,the problem is when the air condition staret the compresor staret but motor fan not I have to out side n push the blade then the motor star workign ,well I replace...
The capacitor starts the motor The capacitor has three terminals C common goes to the contactor HERM to the S terminal on the compressor brown wire with a white stripe from the fan motor goes to FAN
Aug 01, 2014 | Carrier Heating & Cooling
Air compressor on Heil air conditioner is humming but not kicking in
Capacitor Failure Symptoms are sometime harder to identify without the right tools and expertise. Capacitors can be found in several different sizes and shapes. There may be one or multiple capacitors included in your ac with regards to the design. While the most popular capacitors are the types found on circuit boards, the ones most associated with air conditioning will be the bigger capacitors that assist start and run your motors. There are several motors present in an conditioner and heater systems:
  1. Compressor Motor Run Capacitor: Here is the most popular capacitor that fails. Most of the time these are duel capacitors, which means that there are 2 capacitors built into one. A duel capacitor will have three terminals on the top where a single capacitor will simply have two terminals on top.
  2. Outside Fan Motor Run Capacitor: That is the smaller capacitor found with or part of the Compressor Motor Capacitor. It helps start and run the outside fan that blows air through the outside coils.
  3. Indoor Blower Motor Run Capacitor: Similar to the outdoor fan motor capacitor, it is a small, single (two terminals) capacitor that will help start and run the indoor blower motor.
  4. Start Capacitor: Some models include an auxiliary start capacitor that helps jump start the motors. Most are found on the compressor. These are less common.
You may need to get that checked out.
Air Conditioning
Oct 16, 2012 | Heating & Cooling
POWER TURNS ON AT THE CONDENSER MOTOR, BUT IT WON'T START RUNNING UNLESS I START SPINNING THE BLADE ON THE MOTOR WITH A SCREW DRIVER.
If it spins freely when it is not powered then the start capacitor has gone bad and replacing that will fix the problem...
If it does not spin freely and the bearings need oil then check out this tip on how to oil the bearings in the motor...
How to Oil Condenser Fan Motor with pictures
heatman101
Aug 06, 2011 | Carrier Heating & Cooling
I have a 5,200 BTU Maytag window AC. The fan will not start when turned on. The motor hums but will not turn. I lubricated the bearing so it will turn very easy. Is there a starting capacitor for that...
The motor could have or not have a capacitor. You will be able to know if you can look at the wiring diagram which will be on the unit under the case, or disassembling the electrical compartement. The capacitor will more than likely be in the electrical compartment. It will look like a battery, and will probably be a 3 post capacitor. The fan will be connected to "common" and "fan".
To check the capacitor you will need an ohm meter. Unwire the capacitor on the fan and common terminals, marking where the wires go before you pull them off. Take the leads of the ohm meter, turn the meter to its highest ohm setting and touch the two posts with the leads. If the capacitor is good, the needle of the ohm meter will jump up, and then back down. If the ohm meter does nothing the capacitor is open, if the ohm meter needle jumps all the way over and doesn't come back down, it is shorted.
Jun 20, 2011 | Maytag Chassis Built-In Air Conditioner...
Running but no cool air blowing
Problem #1:Outdoor condensing fan motor has stopped running. This problem could be caused by a bad motor run capacitor. If your motor capacitor is not the problem, then more than likely you need a new motor. Is the fan blade tight, stiff or hard to turn? If the fan blade is hard to turn then you probably need a new motor. Problem #2: Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season. Some compressors just have a hard time starting after sitting all winter long. Some compressors are locked up so bad that I can not start them and must tell my customer that they need a new compressor . Many times I can get the compressor started again without having to buy a new compressor or new air conditioning system by using the device that is called, "Super-Boost." I keep two or three of these on the truck. They have saved many of my customers from having to buy new air conditioning systems
Jun 15, 2011 | Weather King 10AJA3601AH Air Conditioner
The fan wouldn't start for the condenser unless I turned the blades with a stick so I replaced the start capacitor and it still won't start without turning the blades with a stick. It runs fine but...
This problem could be caused by a bad motor run capacitor. Please see our If your motor capacitor is not the problem, then more than likely you need a new motor.
Jun 13, 2011 | Ruud UBHC Air Conditioner
Goodman CKL42AR42 Air Conditioner Logo
394 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
