Question about Freezers
Was staying cold and then just stopped cooling. compressor sounds like it comes on but does not stay on feels like it is running and gets really hot have not found a fan
  • 358 Answers
Try replacing the compressor relay (no more than $30) ,but if still doing the same ; the compressor has a start problem and you might have to replaced it.
Posted on Sep 28, 2009
Compressor runs but wont cool
Make sure the compressor is running it should be vibrating and get warm after a few minutes. If it is indeed running the smaller tube to the compressor should be getting warm if not it could very well be the compressor has stopped pumping. If the fans are not running they could be controlled from the control board and will come on when the sensors on the evaporator get to a certain temperature. I does sound like the compressor is the problem.
Apr 04, 2014 | Samsung RFG297AAWP 28.5 Cu. Ft. French...
Product thawed to cold in freezer...
If you had the door open for that long you will need to unplug and allow the ice buildup that happens when door is left open to thaw. After this you need only to plug the refrigerator back into the power source.Let me know what happens It is not going to work correctly until this is done. Sea Breeze
Jun 15, 2013 | Frigidaire 20.6 cu. ft. / 583 liter...
On a up right freezer the red light comes on and stays on and everytihng defrost what could be wrong
I want you to feel the top of the compressor to see if hot or too hot to keep your hand on the top. Click Here for a photo of the=> FFU2124D System Components item 30 is the 216649315_Relay-and-Overload-Kit item number 55 is the=> 5304464438 Run Capacitor
If the compressor is too hot to keep your hand on top it may be the=> 216649315_Relay-and-Overload-Kit
Let me know if the compressor is hot and we will know the compressor is trying to start but cannot. Replacing these parts will possibly solve the problem of your freezer being on but not freezing everything, We need to make sure the compressor is running, Thanks Sea Breeze
Nov 28, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
I have a frigidaire Crown Series that cools but does not get cold enough to freeze, what should I check?
Feel the compressor to make sure it is not so hot you cannot keep your hand on the top. Doing this also confirms that the compressor is running. If the compressor is running continious and freezer is not freezing well like it should it may indicate a Freon leak and that will require you to be looking for a replacement freezer, Thanks Sea Breeze I just don't have much to offer on an older freezer because when constructed the people that made them use steel tubing and the steel tubing tends to rust allowing leaks to happen in places that cannot be reached or repaired, Let me know what you find.
Nov 20, 2012 | Frigidaire Freezers
My Frigidaire Freezer is not getting cold and my fridge temp is to warm. I am work so I cannot give you the model number, can you still help.
Hello Lisa,
Thanks so much for choosing my ad for your fridge problem. Even though you do not have model number I am not to worried about it. As I already know I feel your problem. Please read Below my solution and if you feel that this is the problem, then if you can rate my solution accordingly as well as some nice words, I would appreciate it very much. Feel free to save my information and call on me anytime for anything I can help you in my areas of expertize. Thanks, Mike.
I of course read your problem . A lot of times when fridge is running but not cooling it can be as simple as just cleaning the coil. Take off the bottom back panel. (make sure you unplug fridge) and once you get the panel off, look in there if you see the hoses/coils dirty, they need to be cleaned and use a shop vac to really clean it and sometimes I will use a can of that compressed air that people use for computers. ANYWAY, if it is at all dirty, it needs to have a good cleaning. IF your compressor motor is real hot, then it has overloaded. In other words, its working to hard because of the dirt build up. A lot of people say, hey my compressor is running, but its not getting cold. Most the time it is running, but not at full capacity because it is dirty the coils and vents etc... Now, you have to let the fridge compressor cool down completely after you have cleaned it real good, then plug back in fridge and keep an eye on temp to see if it gets cold like normal. IF not, then what needs to be checked or replaced is the starter relay and most likely the capacitor. that is the switches the plug right into the compressor. You trace the wires that go to the compressor, and you will notice it hooks into a couple parts that plug into the compressor, that is your starter relay and capacitor. This can be replaced yourself. But first lets try the good cleaning method. AS a note: even though the compressor is running and if it is cleaned and still does not cool, the starter relay and compressor could have gone out, and those parts are designed to kick start the compressor at higher amps to have compressor operate at full capacity. I hope this helps you. Mike from fixya.
Oct 24, 2011 | Freezers
Not getting cold enough on the inside... the exterior too hot to touch.. why could this be?
Compressor relay could be fried. Feel the compressor. If it is too hot to touch then check your relay. The relays contacts could be welded together making bot windings stay powered up and overheating the compressor causing compressor shutdown on overload.
Sep 02, 2011 | Whirlpool 14.8 cu. ft. / 419 liter Chest...
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Nov 10, 2009 | Amana Freezers
Compressor very hot on Kenmore 7.5 c.f. upright freezer. It is too hot to touch and smells like burning paint, but stayed cold inside. Wondering if this is a bad compressor and about how much it costs to...
Compressors will normally run hot to the touch, but should not have a burning smell. If the compressor does need to be replaced you would be better off getting a new freezer. Compressor replacement with the labor can run into more than a new freezer.
Aug 27, 2009 | Kenmore Freezers
Freezers Logo
56 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
