Question about Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
How do I play my games on tv using av cable? - Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
  • Sony Master
  • 441 Answers
The PSP system (model PSP-2001 and PSP-3001) includes a video-out port which allows users to connect and play the PSP system on an external display or television with AV inputs. It is important to note -- you can
Component AV Cables (model SCPH-98550)
The Component AV Cables connect to the Video Out Port on the bottom of the PSP-2001 or PSP-3001 systems and allow you to output video and audio signal to a television display. The AV Cables support photos, videos (including UMD movies), music, and games. Please note for games to output onto an external display, the display must support progressive scan.
Composite AV Cables (model SCPH-98548)
The AV Cables connect to the Video Out Port on the bottom of the PSP-2001 or PSP-3001 systems and allow you to output video and audio signal toa television display. The AV Cables support photos, videos (includingUMD movies), and music. However, output of games are only supported by PSP-3001.
Posted on Oct 03, 2009
  • 344 Answers
You have to switch your video output settings after you have the psp plugged in to the tv. If you do it before you have it plugged in you wont be able to see what you are doing, also be sure to switch it back to psp display before disconnecting the Tvl. You can buy the av cable on ebay for under $10
Posted on Sep 29, 2009
minteker
  • 52 Answers
SOURCE: NEED HELP ON PSP CONNECTION ON TV
Hi. From what I have read, you need a progressive scan TV (basically an HDTV), to be able to view games on your TV using the psp-2000 with cable.
The other alternative, only one I know of is:
http://www.playerschoicevideogames.com/pd_psp.cfm
Posted on Mar 19, 2008
larkin71
  • 38 Answers
try to search on you tube - kr2008 for more details on how to play psp games on an interlace,non-progressive crt tv using composite or component av cable.this is now possible and thanks in no small measure to the plugin that was develped for this purpose.hope this helps.
<object width="425" height="350"><param name="movie" value="http://www.youtube.com/v/_DFSfPkCd1Q"></param><embed src="http://www.youtube.com/v/_DFSfPkCd1Q" type="application/x-shockwave-flash" width="425" height="350"></embed></object>
Posted on May 05, 2008
  • 253 Answers
SOURCE: av connections not giving signal to tv
you have to manually change the output in the settings menu back to ANALOG Using an HDMI TV or monitor 1st, when you select RCA, or AV output and restart, it will work, but when you switch back, you have to change it (back to HDMI output) on the analog monitor, or use analog TV inputs, then reboot PS3 and connect HDMI.
I do not know why Sony did not make this switch automatic and self scanning on boot, but alas I have had the same issue, so I know this is your problem, not the AV cables.
Please give a fixya rating if you find this solves your problem, Thanks for the question
Posted on Apr 12, 2009
iCow
  • 41 Answers
SOURCE: I WANT TO FINE THE WAY TO CONNECT THE CABLES FROM PSP TO TV.
sorry you brought the wrong cable you need to get a av component cable e.g. : dse.co.nz
you can also purchase cables for psp 1000's
Posted on Jul 06, 2009
  • 1093 Answers
SOURCE: A big black rectangle covers most of the screen
It sounds like your GPU is overheating to fix it you need to stop the heat on the motherboard, you can do this yourself or you can send it in to get it fixed.
Posted on Jan 05, 2010
After connecting my ps2 to my Technika 26" tv/dvd combo using a red, green, blue AV component cable, I still cannot find how to tune in a channel to be able to play.
With the composite cable you so not need to retune a channel! You just need to select the correct AV channel from your remote......turn on the ps2 with a game playing and select AV on remote and keep pressing it till you get the Composite channel playing your ps2 game!
Oct 19, 2014 | Televison & Video
There are vertical lines on my tv when i am playing whit my sega master console
probably av cables..check them at console and at tv end...if still doin it..find new av cables ..good luck
Apr 16, 2014 | Sega Master System Console
I am trying to connect my NES to my 40" Dynex HD TV through the AV cables and the tv says no signal but i unhooked the HDMI cable and tried the AV cables for my xbox and the xbox worked fine. How can...
  • Well the XBox has it's own AV cable pack it uses. The AV cords you are using for the NES are a separate set that are apparently bad. So to play using the AV cords you just need to pick up a new $2usd pair or see if you have a pair laying around the house.
  • You do have a coak input on the back of your TV so if you have an old coax cord laying around the house you can use the RF bonx that cam with the NES. Hook the coax from the TV to the "OUTPUT" side of the RF box and then run the little RF cord to the NES. Then turn the TV to channel 3 or 4 and you can play it that way.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jun 21, 2011 | Video Game Consoles & Games
Sound Problems
u need a new av cable some things just come already defected from the manufacture
Jun 06, 2009 | Video Game Consoles & Games
Av connections not giving signal to tv
Apr 12, 2009 | Sony Playstation 3 (PS3) Console
PSP2000 SONY GAME
no you cant... the t.v screen cant support the games of psp.
Mar 11, 2009 | Sony PSP (Piano Black)
First you're going to need a slim psp, if you have it then you just plug the cables to the right places. To play games on your tv you need a tv with progressive scan and component inputs.
Mar 11, 2009 | Sony PlayStation Portable (PSP) Slim...
PSP WILLL NOT WORK ON TV
hi. about that, 1 question, is your tv non hd? if not. you can do almost anything on psp to the tv wit that, but not games. to play games, you will need to use a hd tv and another type of cble named. psp component cable.
you need those to two to play psp to the tv. what a drag isnt it?..
Aug 03, 2008 | Sony PlayStation Portable (PSP) Console
Playing psp game in tv using component av cable
i have connect the psp av cable but i can't play psp games plzz guys help!!!!!!!!!!!!!!!!!!!!!!
Apr 18, 2008 | Sony ACY-BR81/OB
Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
1,081 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
