Question about Mitsubishi WS-55809 55" Rear Projection Television
The picture is concave and appears distorted. Sometimes it clicks back, actually makes a click and looks normal...or it clicks to look concave again. Its been going on for a few months now.
    President:
  • 788 Answers
Your symptom sounds like at least one intermitant connection on your convergence IC.
On Mitsubishi's you can sometimes rework the solder connections on each of these IC’s, although, if the convergence does not fix itself from time to time, you most likely do not have a bad solder connection. You will have a faulty IC. I recommend replacing them both at the same time because the chips legs can fall off due to the heat of the IC. If you have a good low wattage soldering iron ~ 45W (available at radio shack) you can perform the repair yourself, and this will most likely take care of the entire issue.
I like to remove the board that the IC’s are on so that I can unsolder the connections and clean then up using solder wick (this is also available from radio shack). Removing the board is not a real issue as the connectors are all labeled with an alpha number, so that you can connect them back real easy. There are three in the middle towards the front that I like to mark with a sharpie as they are the red green and blue convergence coil connections (they are all the same size in a row). Just mark them with slashes, like I, II, III, or something like that. If you mix them up it is not a big issue, you can test swapping them around until the picture lines up.
Please be sure to remove the entire white heat sink compound on the heat sinkThe picture is concave and appears distorted. - 2.gif and apply an even coating over the back of the new IC’s. You should also bolt them down before you solder them in so that you have them at the correct height.
There are two very large IC’s that control the convergence in a big screen set. They are secured to a very large aluminum heat sink. I think that the IC numbers will be IC8001, 80002.
The IC’s are large and black, you cannot miss them. They will usually have an STKXXX-XXX number on them.
This repair from a good technician will normally run from $250.00 - $300.00, and sometimes more depending on your area.
There are several schools of thought on the replacement of parts and I firmly believe that you get what you pay for, so don’t buy the cheapest IC’s that you can find. One company I worked for tried this and it only caused more work for the technicians, as we had to replace them with the more expensive ones in the end. I would think that you should be able to find these for around $60.00 each. If you can find the exact
Hitachi part, or Sanyo2.gif, even though the numbers on the front are the same, and they look exactly like the $10.00 ones, they are better and more reliable.
I usually order my parts from Andrews Electronics in
California, they will have the OEM components that you will need.
Their site is http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
You can also try http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
Posted on Sep 28, 2009
The picture projects the image with concave lines on the edges. I'll explain further: somehow the picture is distorted in a way that bends the four edges of the picture in a curved-concave manner so that...
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 26, 2009 | Mitsubishi VS-55705 55" Rear Projection...
Picture appears concave and shrunken and pulses in size
Replace Both of your STK convergence ICs STK392-570 If this is not number on your s use what it has on them. you can call MATs 1-800-628-1118 o Main STK is what is going bad when IC goes out all together TV will shut down and will not come on. So replace BOTH STKs ASAP! you will also need Heat sink compound to put on back of New ICs.
Aug 19, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Concave picture
sounds like the bulb is on its way out, they can be replaced for about 100 bucks.
Jul 25, 2009 | Philips 51PW9303 51" Rear Projection...
Screen has double images on both sides, picture looks concaved. tv goes back and forth in this mode from normal to concaved
IC chips are Failing, and or A few Resistors in the Convergence circuit. Commen problem for Projection sets!... OneGeo.
Jul 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Pc keeps loading and restarting again, it wont go past windows xp
I keep coming back to this, thinking about it, leaving and coming back to this. I have seen this before and the only thing that I could do to fix the issue was to do a Windows Repair using the original CD. The problem with this is it looks a little deciving and could be complicated. Put the CD in, accept the ULA and when it gives you the option to repair, hit R. Go through the prompts a little further. It will look like it is reinstalling Windows completely, but it is actually reloading just the system files that usually become curupt. When the system comes back up, it might look a little different, but all of your programs and files will still be there.
Mar 15, 2009 | Dell Dimension 4400 PC Desktop
Colors are distorted and picture is concave, how do i fix this?
*Screen Looks 3-D
*Colors wont align
Mar 08, 2009 | RCA P52926 52" Rear Projection Television
RCA-picture discolors, goes concaved
Sounds like a capacitor in the power supply is beginning to fail.Unless your good at this type of repair, I would call a tech to have it serviced. And I would also not use the set until the problem is corrected, or it could get real expensive to fix.
Feb 02, 2009 | RCA HD52W58 52" TV
Picture Problem
I have the same situation. Called my repairman, who knew exactly that it needed a "570 kit" . It will be repaired this week. Cost $360
Sep 26, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Faulty Lens?
Dear Swetnam
This is a internal circuit problem/defect and cannot be done on our own, so u should take it to SONY service centre. Avoid keeping the camera near hot temperatures zone. Sony is not tolerant to many physical factors.
Feb 07, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Mitsubishi WS-55809 55" Rear Projection Television Logo
171 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
