Question about Lexmark JetPrinter X1185 All-In-One InkJet
Printer will not let ink to work. Need to fine Lexmark Control Program or Solution Center. Where is it?
I replaced the black 100xl ink cartridge in my printer, it is almost full, and was working fine before, now it will not print and only gives me blank sheets. the colored cartridges work fine just not the...
Try to do the Deep Clean Printhead function on your printer. On the printer touchscreen, touch Ink Levels > More Options > Deep Clean Printhead. Your printer will then print a test page forcing ink through the cartridge nozzles and clean them. Try to print a document again to verify that the problem is fixed.
If that doesn't help, please contact the Lexmark Technical Support Center or point your browser to http://bit.ly/lFKDzs for online technical assistance.
Sep 12, 2011 | Lexmark Prospect Pro205 Wireless...
I have a Lexmark x4690 and the printer keeps telling me I have an alignment problem. I say ok to doing the alignment but when the paper feeds through there is no ink on the page. Also, if I try to print...
The error could be due to the cartridges in the printer. Please follow steps below to identify and fix the problem:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove both cartridges from the carrier. Check the encoder strip (transparent strip behind the cartridge carrier) and make sure it is not unseated from its position.
4. Close the printer cover.
5. Unplug and re-plug the printer into the power outlet to reset it.
6. When the printer turns on, check for any errors. If alignment error is displayed on the screen, please contact Lexmark Technical Support Center for additional assistance. If no error appears, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 10, 2011 | Lexmark X4690 Wireless InkJet Printer
My Lexmark was working fine for approx. over 2 years, now when I tried to scan, it tells me to contact you through the web to have service center download, I did, and the download button does not appear...
You can download the complete driver for the Lexmark X2650 printer by visiting the Lexmark website at http://bit.ly/pyI1gr. Select your operating system > click on FILTER > click on the complete driver. Execute the file to update the existing printer driver installed on your computer.
Jul 28, 2011 | Lexmark X2650 All-In-One InkJet Printer
I recently replaced my ink cartridges for my Lexmark X2500 with brand new ones, Lexmark brand, I inserted them and followed instructions and now it still tells me that it can not print that I need new...
  • Open up the "Printer Solution Center." If there is no icon on your desktop for your Lexmark printer, click on the "Start" menu button, which is located at the bottom left-hand corner of the screen. Click on "All Programs," and then look for "Lexmark." Select the "Printer Solution Center.
    Choose "Install a new printer cartridge" under the "Maintenance" tab.
  • Click on "Next" until you see the "Print the Alignment page" option, then choose "Print."
  • Repeat steps 1,2 and 3 if the ink level gauge still isn't showing sufficient ink.
  • Apr 13, 2011 | Lexmark X2500 All-In-One Printer
    Related t my Lexmark E232, I'm using a compatible toner but it put excess of ink in the papers. Then I bough a new original Lexmark toner, and when I put in the printer on two lights, from top the second...
    Inspect the overall paper path for signs of spilled toner.Gently clean the contaminated areas with a soft cloth or compressed air.
    If you need further assistance please contact Lexmark Technical Support Center.
    Jan 24, 2011 | Lexmark E232 Laser Printer
    How do i reset me lexmark 5070 printer after i used a refill for ink
  • Launch "Printer Solution Center." You should have installed this program when you installed your Lexmark printer. Click on the Start button and selecting "All Programs." The menu command or shortcut for this program is located under the "Lexmark" folder. Click on it. If you do not see this program for some reason, insert the installation CD (provided in the printer box) into the CD/DVD-ROM drive. Follow the on-screen prompts to install the program.
    Step 2
    Click on the tab that says "Maintenance" on the top menu.
    Step 3
    Click on the button titled "Install a new printer cartridge."
    Step 4
    Hit "Next" to launch "Print the Alignment page" window.
    Step 5
    Hit the "Print" button. This will reset your ink cartridges. You should be able to see a correct reading of the ink levels on your Lexmark printer.
    Step 6
    Repeat this process until you successfully reset the ink cartridges. Sometimes, it may require multiple attempts to complete this task
    if you want to know how to reset the complete thing then...
    Resetting a Lexmark printer
    You will firstly need to switch off your printer. Then simultaneously press the RETURN and READY keys while switching the printer on. This will take you to the Diagnostics Mode. The display unit will show the message 'Performing self test'. Choose 'Maintenance count'. Reset the count to make it zero. Then select the RETURN key and go back Diagnostics Mode. Then you can reset the printer to go back to the normal mode.
    hope this works for you...
  • Aug 07, 2010 | Lexmark X5070 ALL-IN-ONE InkJet Printer
    Lost my manual, need to change the ink cartridge, help
    1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
    2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
    3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
    4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
    5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
    Apr 24, 2010 | Lexmark C533DN InkJet Printer
    I have a Lexmark 5200 printer. Worked fine with
    There is a conflict with the Lexmark printer control program from XP with Vista. either download and install the new program from Lexmark or try running the device in compatabiltity mode. The Lexmark XP drivers will not work with Vista and they posted updates to most of thier application software on thier website.
    Sep 08, 2009 | Office Equipment & Supplies
    Printer quit!
    You need to try to flush the print heads once or twice, then test print again.
    1. Go to Start > Control Panel, and go to Printers (or similar)
    2. Find your printer in there, right-click it and choose Properties
    3. You may now have to look for Printer Preferences or similar and go to it
    4. You'll now have to look for some sort of Lexmark control panel where it will have options to do a head clean. Do that. Sorry you'll have to look for it because it varies across systems.
    If that doesn't help, go to Start > Programs, and look for Lexmark and see if there's some sort of control panel or diagnostics program in there.
    Hope this helps!
    nLinked
    Computer Support Services
    Jun 06, 2009 | Lexmark Office Equipment & Supplies
    Refilling cartridges
    Joe,
    You should have received control program software with your printer. If installed, the icon should be on your desktop or it may be in your programs list. You can also get the software from the Lexmark web site.
    Anyway, you probably need to reset the cartridge using the control program. It's not difficult. Just follow the prompts.
    May 16, 2009 | Lexmark X3650 Printer
    Lexmark JetPrinter X1185 All-In-One InkJet Logo
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
