Question about Refrigerators
Ice maker won't fill - Refrigerators
  • 80 Answers
Check to see if the water tube is frozen that feeds the water to the ice maker. If so, you can take a hair dryer and thaw it out.
Also check and see when the ice maker is running that the water valve is activted to allow water to flow into the ice maker. Is the water supply line not getting water for some reason.
John
Posted on Sep 28, 2009
Ge profile PFSF6PKXEWW AFTER POWER OUTAGE ICE MAKER DOESMN'T WORK
If the ice maker is not filling with water after dropping the last harvest of ice cubes it will indicate a defective WR57X10091 Water Inlet Valve If you would like to try self diagnostics on your model click HERE and go to page 78, I will be here should you have questions, Thanks Sea Breeze
Jun 12, 2013 | Refrigerators
Kenmore
Can you check if the ice maker fill tube clogged with ice?
If the answer is Yes, it means that water valve is leaking, then you will need to replace water valve.
If not, try manually activate ice maker.
Jun 08, 2013 | Refrigerators
Lg in door ice maker, water won't fill in ice tray
I had that problem and water was also leaking. I tossed the ice and kept the door open for about 20 minutes when the door open alarm started to go off. It's working again. The error code on the door was 1f
Feb 01, 2013 | LG LFX25960ST Stainless Steel French Door...
Scotsman icemaker dce33 is making ice, but it is melting
Yes it could and also check dump valve it should not let water through during freeze cycle.
Oct 03, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Frigidaire plhs3teesbe model won't make ice
Hello - If your ice maker has stopped producing ice completely, you can try to check the following:
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Oct 03, 2012 | Frigidaire FRS3R5EMB Side by Side...
Freezer won't make ice cubes, but does provide cold water.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
Jul 08, 2012 | Frigidaire Refrigerators
Tfx20r ice maker won't fill
Try this fill the ice maker with tap water so we can decide if it is the ice maker or the water control valve. After the water freezes if the ice dumps and the ice maker does not refill with water then you will need to replace the=> WR57X10033 Water Control Valve If the ice maker does nothing after being filled with tap water and the water freezes then this would point to the=> WR30X10093 Ice Maker Assembly If you have questions I will be here to answer them for you, Thanks, Sea Breeze
Jul 06, 2012 | Refrigerators
GE TFX24E side by side refrigerator, ice maker won't fill with water.
Hi, I have a GE TFX24E refrigerator. The ice maker is not filling with water. I replaced teh water valve with no joy. If I pour a cup of water into the dispenser the ice maker will freeze and harvest the ice. Any ideas? Is there a replaceable water fill sensor?
Sep 03, 2011 | GE WR30X10093 Refrigerator Icemaker Kit
THE ICE MAKER SEEMS LIKE DOSENTT GET WATER
Remove the cover on the ice maker. Look on the main drive wheel for a missing tooth.
If that tooth is missing the water won't fill. Cheap part easy fix
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 07, 2011 | Frigidaire FRS3R5EMB Side by Side...
Ice tray won"t fill with
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Apr 26, 2011 | GALAXY Microsystems 25.4 cu. ft....
Refrigerators Logo
165 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
