Question about HP Compaq Presario CQ50-103NR Notebook PC
My daughter had her grandfather's laptop on the floor. She stood up pushing down on the laptop as she stood up. The are no visible cracks on the screen, but there are black lines on the screen. Can anything be done to fix this?
  • Chris Hingee
    Chris Hingee May 11, 2010
    Are the black lines random or are they vertical or horizontal and if so how wide are they?
  • 615 Answers
When a pressure placed on top if the computer (keypad) it may create a crake on the motherboard and that will cost to fix without opening the unit and checking it no one can tell…let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Posted on Sep 28, 2009
  • 5,603 Answers
Probably will have to replace the screen. Find a replacement screen on eBay and a dexterous electronics type to install it. There is a SLIGHT chance that one of the flourescent backlight tubes was broken, but likely the LCD panel has been damaged beyond repair.
  • 558 Answers
You might try tapping it gently on the back,sometimes this work.If not you might have to replace the screen,
good luck
  • 43 Answers
Yes, the screen can be replaced.
Good Luck
Dropped my HP D7 laptop. It slid out of my backpack from about 2 feet onto hardwood floor. On bootup, lights turn on for the keys and around the touchpad perimeter, and everything works fine with an HDMI...
You possibly cracked your screen or caused the ribbon cable to disconnect when you dropped it and just can't see what the error codes are saying. Is probably asking you if you'd like to start in safe mode with the beeps but you can't see it with a cracked screen or disconnected ribbon cable. Take it to a repair shop for a diagnosis.
Aug 29, 2014 | Computers & Internet
Binatone Kidzstar Ultimate Tablet screen smashed
I want to know the same too, it was dropped a few inches from the floor, which is carpeted, and it also had the case on it. My daughter is devestated, I want to know how and where to get the screen replaced and how much it will be ...
Jan 02, 2013 | GPS
Our daughter was not feeling well and lost her
It isnt hard at all to do. There are many walk throughs online to guide ya through. Just take your time and have patience. Other things you should look for (that i can think of) can only really be determined after you replace the lcd screen. Dropping a laptop like that can damage the hard drive and therefore losing data or your operating system.
Jul 21, 2010 | HP Computers & Internet
I have crack in my shower floor concrete, would like to fix it before laying tiles and hope it won't be visible after i am done with tiles. I had tiles before wich I am removing now and will instal new...
There is a tile backer, kinda of like fiberglass mesh, I have also seen a waffle looking plastic, that will go down over the crack in the floor and will not effect the tile one bit. You just tile over everything, no mastic, no set under this stuff, no fasteners, just tile over it like a normal floor, and the best part is, no crack! Hope this helps.
Jun 29, 2010 | Plumbing
Seatbelt cannot lock
try unbolting the female section from the car floor and beating it against the floor while it is upside down. My car had the same problem when my daughter dropped potato chip crumbs into the connetor. You can also try running hot water inside the latch (once it is out) incase someone spilled soda in the latch.
Mar 23, 2009 | 1997 Lexus ES 300
Unable to remove screen surround on Acer Aspire 6930
Walk into a Computer hardware shop. Of course they will have all the required tool to open the laptop up and fix the new screen.
Mar 17, 2009 | Acer Aspire 6930-6771 Laptop
Toshiba laptop cracked screen
you can use external monitor, but best option is to replace the cracked screen. Take a tour of toshiba service centre.
Thanks and Good Luck
Iqbal
Jun 26, 2008 | Toshiba Satellite L25-S119 Notebook
Linksys Range Expander...
Initially, it is possible that the WRE54G has not been configured to talk with WiFi AP/Router downstairs and all that is needed is to configure/set it up.
Setup (to be done in the same room where your WiFi AP/Router is installed and preferably with your daughter's laptop which can already connect to your network when it is near):
1. Download the LinkSys WRE54G Setup Wizard from the LinkSys site;
2. Use a LAN cable connection to the WRE54G Ehternet port (located underneath a flip lid in front panel) to one of your daughter's laptop;
3. Power up the LinkSys Expander;
4. Press the Range Expander’s Auto Configuration button for about five seconds. Normally this should be sufficient for the Expander to auto-detect and auto-configure itself;
5. Power off;
6. Move the Expander to your intended place of installation;
7. Again using your daughter's laptop, expand/install the downloaded LinkSys Setup Wizard. Soon as the program is running, follow the on screen instructions. Please don't forget to Save before exiting.
8. Move your daughter's laptop to its intended location and try the system.
Should you still need a User's Guide, it is available here.
Another possibility that we cannot discount is that the WRE54G is also not reaching your router downstairs. Perhaps what can be done is installing it not a floor down from your daughter's but halfway between your daughter's floor and your office downstairs.
Hope that this be of some help/idea. Pls post again how things turned out or should you need additional information.
Good luck and kind regards.
Nov 16, 2007 | Linksys Wireless-G Range Expander (WRE54G)
HP Compaq Presario CQ50-103NR Notebook PC Logo
74 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
