Question about Dryers
The dryer belt squeals when in operation. Where is it located so I can lube it with a belt lube? It's an Atlantis MDE6200AYW model.
  • 61 Answers
The belt pulley need to be lubed
Posted on Sep 29, 2009
Dryer runs for a short period then starts to sqeal from the back and when you stop it and open the door you can smell a burning smell .
sounds like a bad belt and or pulley. If you take the top of the dryer off you can use a piece of candle wax to lube the belt and see if that makes the squealing stop to verify the belt/pulley as the source of the squeal. If so, you can but a new belt and pulley kit for about $30 and replace yours. Good Luck!
Oct 11, 2014 | Kenmore Dryers
Maytag atlantis mde6200ayw
be with you in a bit
Sep 12, 2013 | Dryers
My maytag atlantis model #MDE6200ayw Serial #40504320zy is not getting hot. Everything else seems to be working fine. One thing i did have to do was change the prog back to the 3 prong as i just moved into...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | Dryers
Kenmore series 80 Gas Dryer, in back of the dryer there is a fan at the bottom that squeals when I turn the dryer on. Is this easy to replace or oil to resolve the squealing. Suggestions are...
that fan runs off the motor shaft and can be lubed with some spray lube,, be sure that its not the belt thats squealing, check it for cracks, and bare spots
Jul 06, 2011 | Dryers
My motor is makeing a sqeeling sound, it turns easy enough but squeels can u wd 40??
I don't work on gas dryers normally but, It may not be your motor making the squealing noise, it is probably your drum rollers making the noise.
You need to lube the shaft of the drum rollers with a good grade of machine oil like 3 in One oil...while you are at it you can lube the motor also if you feel that is necessary...
I would not use WD-40 to lube the motor or drum rollers it does not have the "staying power" that 3 in One oil has and you will be re lubing again soon, also it can creep its way into the motor and cause an electrical short to the motor.
Nov 12, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDE6200AYW loose dryer paddle
You might have to remove the back, then the top, but it looks like the paddles are either held on buy a screw from the outside of the drum or they just have clips that lock them to the drum. Once the back is removed, you should be able to see how the top is held on. I think it is screwed or has clips for the back and then you slide it forward to unlock the front tabs. You can follow this if you don;t get a reply
from someone who has worked on this model#. Hope you get it apart ok and fixed by yourself.
Mar 14, 2009 | Microsoft Windows XP Home Edition
Maytag Atlantis Dryer squeals
Try Repairclinic.com for help and parts. You are going to need heat resistant grease, and probably snap ring pliers.
Feb 28, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Disable buzzer on Maytag Atlantis MDE6200AYW
it could be done by taking the control panel off and maybe diconnecting the buzzer other than that what I have researched there is no other way sorry
Feb 18, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag dryer belt replacement
maytag.gif Diagram E
Style: Flat with ribs
Installation Tips: Flat side of belt against drum
Jan 03, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
219 people viewed this question
Top Dryers Experts
