Question about HP PhotoSmart 7960 InkJet Printer
Printer has shut down and will not restart. I took the plug out of the outlet and replugged in but that made no difference.
Frequently power down
1. Power off the printer and computer and then disconnect the interface cable.
2. Power the computer back on.
3. Once the computer has booted, power the Brother machine back on.
- If the computer still reboots, restarts, shuts down, or enters hibernation mode, this problem is related to the power source for the Brother machine and computer. Continue to the next step.
4. If the Brother machine and computer are plugged into the same surge protector, uninterruptible power supply, or power backup device, power everything off.
5. Unplug the Brother machine power cord from the power device.
6. Plug the Brother machine power cord directly into a wall outlet or a different surge protector strip. You may need to use the reset button on the power device.
7. Power the Brother machine and computer back on.
Still having Problem Then follow Us For Brother Printer Support
Mar 23, 2014 | Brother MFC Office Equipment & Supplies
Lexmark x9575 all in one keeps restarting after slecting scan\copy and fax I have un-installed and re-installed the drivers + reset printer to default factory settings - no change
Try to unplug the power adapter from the printer. Then unplug and replug the power cord into the power outlet. Replug the power adapter into the printer. This will help reset the printer. Check if problem continues.
May 31, 2011 | Lexmark X9575 InkJet Printer
My printer will not switch off
Try to unplug the power supply from the printer. It's the rectangular black box behind the printer where the power cord plugs into. Replug after 30 seconds. That should give enough time for the printer to reset itself. You can also try to plug printer to a different known working power outlet. thanks.
Nov 12, 2010 | Lexmark Z615 InkJet Printer
Improper shut down
test the power outlets where the printer is connected to to be sure that its getting power supply ,you can comfirm this bu conecting another device to that same power outlet,this will comfirm to you if the oulet adapter fuse is blown or the printer power pack is blown .
Jan 12, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Printer does not power up.....
check out the power cord or replace the power cord with new one
Nov 27, 2009 | Office Equipment & Supplies
Freezer freezes and then thaws
check wiring into outlet and at breaker that feeds outlet. you may be losing high volts at or to the switch. if possible check power into the stat when the condition occurs. this will telll you if stat is bad or power into it aka the outlet is bad. you may be jiggling wires in the outlet enough to fix short term each time you replug to outlet or get a good heavy extension cord and plug in else where to seee if problem goes away.Good luck
Dec 06, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
HP ALL IN ONE OFFICEJET 5510 ALL IN ONE. I WAS PRINTING THEN IT JUST STOPPED. I TRYED SHUTTING DOWN, TURNING ON REPLUGING, SHUT COMPUTER STARTED AGAIN. WILL NOT TURN ON.
maybe the some wire inside got loose.......
ceck the wires connecting the printer
if it is under warranty perio u would eeter give it to the official shop.......
Oct 22, 2008 | Office Equipment & Supplies
At&t 1855
We took the phone off the wall...plugged it into a different outlet.  It worked.  Hung it back on the wall, replugged it in to the original outlet, and it still works.  Go figure.
Apr 17, 2008 | AT&T 1855 Phone
Set shuts down intertmittently
replace the lamp part # BP96-00826A. if the lamp code on the side of the set is different replace with that lamp. you will need a tech to reset the lamp hour meter in the factory mode.
Dec 31, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
HP PhotoSmart 7960 InkJet Printer Logo
41 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
