Question about Rainbow E series Canister Wet/Dry Vacuum
IT WILL NOT START - IT TRIES BUT DOES NOT TURN ON.
  • 430 Answers
Unplug the vac and spin the acorn nut on the separator in the water reservoir. If it spins freely and this vac has run for a few years you may need a fresh set of motor brushes. Do not attempt to run the vac if the motor hums or makes a burning smell. Worn brushes are normal and can often be replaced in an older Rainbow/ Rexair
Posted on Sep 28, 2009
Rug doctor pro won't start
if you are renting it return it and be sure that they know of the problem if you bought it call the number in the label on the back of the cleaner and check your warrantee it will be able to cover it as long as you are still in the time period that they gave you if you are renting one they should give you your money back or rent you another one for the same time at no cost to you
Mar 21, 2014 | Rug Doctor Vacuums
Henry hoover
Hi it can be the connector at the end of the Henry cable inside the cable rewind unit happened to us!
Nov 14, 2012 | Numatic Henry Bagged Canister Vacuum
I have a 18 yr old Admiral DH359 demudifier. When I turn on the dial (switch) it gives a humming noise buy the blade does not rotate. After about a minute or two it shuts off because of condenser over...
The problem with your unit is the fan. The engine behind the blades have gotten spoilt hence its inability to roll the blades. Usually when the engine of a fan is spoilt as a result of the coil the engine still tries to move but due to the bad coil the engine hums but does not come to a start. The fan is meant to be the main component which regulates the temperature of the unit if the fan does not cool the unit then the unit will overheat and go off. Simplest solution is to extract the entire fan plus its engine and get ? replacement for it. If you have the required expertise to open and reassemble the unit you can do this yourself otherwise get an expert to carry it out for you. Hope this solution has been helpful?
Jun 23, 2011 | Vacuums
Will not start. replaced switch. What next?
1. Make sure that both safety switches are engaged (front and bag area).
2. The power cord can break internally where you won't see it. Look for damage or twists in the cord. With the vacuum turned on wiggle these areas between your hands and see if it tries to run. If so replace the cord. If not the he motor may need to be serviced
Apr 29, 2011 | Kirby G5 Bagged Upright Vacuum
Switch to turn vacuum on/off currently not working do not even here the click
The vacuum will need to be taken to the nearest Aerus Electrolux store for replacement. A rep can also pick it up and return it. If this is done, an estimate will be given to you over the phone. If the rep tries a demo spiel, FIRMLY tell him/her no.
http://www.aerushome.com/storelocator/
Jan 19, 2011 | Electrolux C101 Bagged Canister Vacuum
The product hisses all the time and emits and strange oder - is there a solution?
Sounds like a bad belt and it is burning as the motor tries to turn the brush. Does it smell like burning rubber?
Dec 04, 2010 | Vacuums
I got it wet and it went off dried it all in and out wont come on
Remove the sweeper head and try to turn the impeller by hand in either direction--it should turn easily. If not, then the motor bearings are probably in need of replacement. Check around the motor for a circuit breaker--push to reset. With the switch on, try wiggling the cord near the plug end--if the motor tries to turn on at times, replace the plug by cutting behind the plug an inch or so, stripping the outer covering back about 1-1/2 inch, and the wire ends insulation back about 5/8 inch. This should prepare the cord for installing the replacement plug (from your nearest home center or hardware store). The instructions that come with better plugs may show a little different process than what is described here. Hope some of this helps!
Nov 02, 2010 | Kirby G4 Bagged Upright Vacuum
Miele 5000 vacuum cleaner stopped during use. no lights on
could be your retractable cord assembly's contacts..
push the power on while pulling out the cord. see if it tries to start.
Oct 07, 2009 | Miele S558 Red Velvet Bagged Canister...
Tries to start but won't
SOUNDS LIKE YOU NEED TO REPLACE THE VACUUM'S DRIVE MOTOR.
Jul 10, 2009 | Kenmore Canister Vacuum Vacuum
Roomba can't make a turn and stops working
make sure the wheels are not clogged with something like hair or carpet strands if that don't work it sounds like your right turn sensor might be bad.call the roomba people or go to roomba.com and look for your model and find troubleshooting
Apr 28, 2009 | iRobot Roomba 410 Robotic Vacuum
Rainbow E series Canister Wet/Dry Vacuum Logo
214 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
Jax Planet
Jax Planet
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
