Question about Worx 16" Electric Lawn Mower
Won't start I have checked all cords and different outlets and it just won't start....Model WG712
    Scholar:
  • 135 Answers
You may have a switch problem in the handle or the little voltage box may be burnt out. That'll be a little feature creature about 1 inch square and one corner is angled and it has four little legs on it, One of those legs is opposite to the other three. You may have to replace that. But make sure you have 120 volts going to the motor before you purchase anything. Be very careful how you remove the wires from that little box. Mark them with a little drawing if you have to and make sure you put the proper colors back where you took them from. Good luck
Posted on Oct 09, 2009
MIne Whirlpool duet is having probloms please help me with it!
see this causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 05, 2012 | Indesit W 123 Front Load Washer
Kenmore Elite Model 110.42926 202 after setting the desired cycle will not start when you push the start button
Oct 05, 2012 | Kenmore Elite 45986 Front Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
Sep 28, 2012 | Washing Machines
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Have a Sylvania 6727DF TV and it won't turn on tried different outlet different remote checked the transistors I can't find what's wrong even the ohm's r weak on the cord
Contact any experienced service technician. Its main power regulator section has the fault. The work is a skilled one, and not a user repairable fault.
Aug 26, 2012 | Sylvania 6727DF TV
My nc6400 won't power up even when connected to a power adapter. How can I fix this?
Since you already tried another power cord (assuming that it was a working cord and for the exact same model). Then I would say your motherboard is dead.
Aug 17, 2012 | HP Compaq nc6400 Notebook
Oreck xl won't start
This could be for various reasons. Check the power cord and try a different outlet first. See if the power cord is loose or damaged. Next check the brushroll and belt that those are in working order. If you smelt burning or electrical fire or your vacuum made an odd noise before stopping it may be the motor going bad. If your power cord is good and the brushroll and belt good, it is probably your motor going bad.
Replacement Oreck Vacuum Cleaner Motor
GoodVac
800-775-6586
Jun 20, 2012 | Oreck Vacuums
Friend gifted working dryer. the black cord did not match my outlet. Changed to grey dryer cord. Five wires coming from inside dryer yellow red two blue and one white. I have the red and yellow to...
The blue wires defiantly go on the outside...their are so many dryers i can not remember all details of each one off hand reply with the model number and i will check the wiring diagram and see exactly which wire goes where but even without referring to a diagram i know the blue wires go on the outside
GENE
Sep 14, 2011 | Dryers
My washing machine won't star
Thanks for choosing FixYa and welcome. If you have a washer that won't start, here are some probable causes to your problem. First, make sure to check your breaker box for a tripped breaker. If nothing is tripped, you will want to make sure the washer is getting power first. You need to check the wall outlet and the power cord. You can properly test both of them with a voltage meter to make sure they are getting correct power. Wiggle the cord and see if you can get it started. You could have a break or loose wire in the cord causing your washer to not start. If it starts, you still need to change out the power cord. If the outlet is not getting power, you will need to conduct a test on that to determine the cause. You may have a bad wire or a loose wire. If you have power to the outlet and cord, make sure your fuse has not blown. You need to check your timer switch next. It may be bad or not working properly. Refer to your manual for the correct procedure. Try the washer on different cycles to see if it will start. It is possible that you have a bad lid switch. It can cause the washer to not start if it is bad. You could have a defective motor as well. If the motor has not been working correctly or making noises and other sounds, there is a good chance it has finally died out. Always make sure that the part is getting power before you change it. A voltage meter is an ideal tool to keep around the house. If a part is not getting power, even with a new part, it will not work. Make sure you test everything before making a decision. Always determine the cause by testing and not guessing.
Jul 10, 2011 | Kenmore 24032\24036 Top Load Washer
Worx 16" Electric Lawn Mower Logo
884 people viewed this question
Top Worx Garden Experts
Tim Whalen
john milligan
Jay Finke
Jay Finke
Are you a Worx Garden Expert? Answer questions, earn points and help others
