Question about Epson Stylus NX400 InkJet Printer
Unable to scan from Epson TX110 but can print
Printing works fine, but every time I try to scan the following message, "Unable to create a work folder on the current disk, therefore the work folder will be returned to the default location". I have tried to copy the install folder from the cd to my hard drive, as suggested by someone else on this site, but am still having no luck. I am trying to install on my imac, OS X 10.5
  • petal_1976 Jan 07, 2010
    No, haven't solved it and have made it worse by trying to download software. Now it won't scan or print :( I am waiting for my neighbour, (very good with these sorts of problems) to fix it. If he does, then I'll let you know how. My mum also had same problem (not being able to scan) but one day when I was there and she was showing me, the bloody thing worked!!!!!
"unable to create a work folder on the current disk"
possible solutions:
-highlight the application then do "command+i" permission should be set to read/write.
-run repair disk utility. check for any permission errors.
-try a different admin acoount then reinstall the software
-call Mac - honestly it's an OS issue
Posted on Aug 09, 2010
Having exactly the same problem with an Epson SX515W. Did you solve it?
Posted on Jan 03, 2010
My epson office tx600fw printer is very slow since I start using Windows 8.1 how can I restore its original speed
Steps to Troubleshoot Epson Printer Slow-to-Print Problem?
Learn to troubleshoot Epson Printer Slow-to-Print Problem as not all printers are created equal. Print speed may vary depending on system configuration, print mode and document complexity. Processing time on the computer system is not included in the print speed. The several factors where printing is slow are mentioned below:
    ·Printer driver settings
    ·Size of the data being sent to printer
    ·Windows spooling error You can also get in touch with Epson Printer Technical Support for further query or simply follow the steps to troubleshoot the slow-print issue.
    Steps to fix Epson Printer Slow-to-print issue:
    Step1: Observe the data cable
    Check whether the data cable is less than 1.8 meters in length and is connected directly to computer system. Use of long cable and connecting through third party such as USB hub can cause communication and print delays.
    Step2: Paper type
    Check that paper type you have selected in the printer driver matches the paper loaded in the printer and selected paper print is also appropriate
    Step3: Some general tips
    Click on icon shown for general information on how to remedy slow printing
    Step4: High Speed enabled
    Check for high speed if it is enabled in the printer driver. Depending on the driver the setting may only be available on certain quality and paper selections.
    Step5: Enable High Speed
    Open the printer driver from printers, printer and faxes or Devices and Printers folder and check whether the high speed is enabled in speed and progress
    Step6: Other Settings
    Check for other settings as well in speed & progress for better printing speed
    Step7: Spool folder
    Create new folder of spool on the hard drive and point the driver to it
    Step8: Carry a test
    Print a test page form general tab of your Epson driver
    Step9: Perform
    If printing is still slow try reducing the size of the data sent to printer
    You still have doubts to execute the above mentioned steps you can contact via Epson Printer Customer Support Phone Number USA Toll-Free 1-800-213-8289 UK @+44-800-046-5291(toll-free) to receive immediate and instant solution. The trained technicians are present 24*7 to deliver you high speed printing printer machine.
Epson Printer Customer Support Phone Number 18002138289 Help
Feb 11, 2015 | Epson Stylus Office Equipment & Supplies
I have an epson stylus TX110 and it was printing fine today, but then as is sent a job from adobe it prepared to print (made usual noises) but then didnt take any paper and just went quiet. I've tried...
Try purging your temp files. If it's a usb connection try a different usb port. Since it can print from scan and do a test nozzle print then it's not getting data from the pc to the printer. If a different port doesn't work either, and if purging your temp files doesn't work try it on a different computer if possible. You may need to reinstall the driver for it.
oh and make sure you don't end up with one of those 'oh duh' moments :) ... check both ends of the cable to make sure it didn't become loose or unplugged :)
Jun 05, 2011 | Epson Stylus Photo R1900 InkJet Printer
"Unable to print" message. Funny thing though I
Follow this procedures
Go to START MENU
Select Commad prompt and right click & runs as administrator (For Windows Vista or Windows).
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer also turn off your printer and switch it on.
It will work fine right now
I hope it helps you
Feb 26, 2011 | Brother MFC 210C All-In-One InkJet Printer
My Epson TX110 has a problem with printing. I have added new Epson certified printer cartridges but is saying that it still does not recognise the cartridges. Can you help - I have shaken the cartriges and...
did you mix the standard capacity cart and high capacity cart?
Try using all the same capacity cart... but most of the time, it's the ink cart chipset that is faulty... regardless whether it;s new or used.. the chipset is a small eprom located at the bottom front of the ink cart..
May 20, 2010 | Office Equipment & Supplies
Epson workforce 500 will not scan
All is well! I just followed some other person's solution (at a more responsive forum!) by downloading the latest .exe files from Epson and now everything is working just fine. thanks for answering my post above....ha, ha, ha. :)
Jan 21, 2010 | AcerPower Sn PC Desktop
Mac OSX 10.4.11 Error when installing the Epson NX400
If you're running the install program from the install disk CD, it may be attempting to create a work folder on the CD instead of your hard drive. I would drag a copy of the install program onto your hard drive first and then launch the copy on your hard drive.
Let me know if that solves your install woes...
best of luck on this.
K
Jul 24, 2009 | Epson Stylus NX400 InkJet Printer
Scanner error message. Will print from PC fine
The Scanner has died. If you Know someone else who has the same model but is not printing but scanning fine you can swop over the scanners. This solution don't work 100% of the time but i have fixed a few this way.
Apr 01, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus NX400 InkJet Printer Logo
2,106 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
