Question about Toshiba Satellite A35-S159 Notebook
Toshiba A35 S159
When running my computer with the ac adapter plugged into the wall. After 45 minutes the battery capacity meter in my system tray shows battery remaining 99% instead of full power. I am assuming this means its running off the battery not the ac adapter. Or the battery is not charging. I have jiggled the ac adapter wires on the adapter and on the outside of the computer where it attaches, and nothing changes.
On some occasions it has gone down to 50% (while the ac adapter is plugged in) and I shut off and search for an outlet that will get it charging again.
Is this a computer problem with the ac adapter, or the dc jack or a electrical outlet problem?
Any help will be appreciated.
  • cadreamin2 Sep 28, 2009
    What about the fact that if you are running on AC adapter you should be running full power. Then all of a sudden it switches to the battery while the ac adapter is still plugged into the wall...... meaning we are not trying to use the battery.....not it say
    its on battery and its 99% charged and begins to run out until it shuts down even though its plugged into the wall......
    Does that have to do with the battery being bad...shouldn't it just run on AC power?
    If I was going to clean the contacts of the battery
    is there a link that shows how to do this?
    Just a single mom here.
  • 558 Answers
You forgot the most important item in the whole equation the battery.How long will the computer stay on with the battery?One quick fix,try using a toothbruch to clean the contact on the battery and on the computer.This might work.I think the computer is fine. The battery might be bad,
Posted on Sep 28, 2009
Can't find hard drive on my toshiba satalite toshiba a35-s159
1) Make SURE you remove ALL power before removing the Harddrive.
Remove the AC adapter (Charger) and Battery.
2) http://www.irisvista.com/tech/laptops/toshiba-satellite-a35/complete-disassembly-1.htm
Page 3
Go down to Steps 19 and 20. Click on the photos to enlarge,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a35/complete-disassembly-3.htm
[ The page numbers are in white at the Bottom, and Top of the pages.
Page1::Page2::Page3::Page4::Find another model ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 17, 2012 | Toshiba Satellite A35-S159 Notebook
Toshiba Satellite A35 S159 AC PROBLEM Can a laptop run just on the ac without the battery? I just watched a video on youtube and the guy said if you want to save your battery you can take it out and run on...
Yet you need to set up what is called a hardware profile so that you can use the Laptop on either AC power only or on AC Power and Battery. Although it is normally used for docking it can still be used for the battery.
One profile for the office where the laptop is docked and the network adapter enabled, and a second profile can be created for use when you are working away from the office that disables the network adapter but enables the modem.
To set up hardware profiles in XP, complete the following steps:
  1. On the desktop, right click the My Computer icon and select Properties.
  2. From the Hardware tab, click the Hardware Profile button.
  3. Under the list of available hardware profile, select Docked Profile or Undocked Profile and click Copy.
  4. Type in a new name for the profile and Click OK.
  5. Select the new profile and click Properties. Select the check box beside This is a portable computer. Select the docking state for the profile. Click the option to Always include this profile when Windows starts. Click OK.
  6. You can now use Device Manager to enable and disable devices for a hardware profile.
Some people do say that if you totally discharge a rechargeable battery and then fully recharge it you will get a greater AmpHour from it but this will be negligible as all batteries have a standard number of Amps that it will deliver built into it, it may fall with age. Although rechargeable batteries don't just fail like normal dry cells they tend to fail over a period of time and fool us a bit.
LOL
Sep 28, 2009 | Toshiba Satellite A35-S1592 Notebook
I need to install drivers for a35-s159.The Toshiba support page no longer supports this model.I need the modem and Ethernet drivers according to my hardware mngr
Wow, I can't believe they removed it from their support page. bummer.
You can try a simple Windows Update.
It should detect the missing drivers.
Let me know if it doesn't.
Jun 15, 2009 | Toshiba Satellite A35-S159 Notebook
TOSHIBA
You can purchase it here. Click on system boards to view the boards available for your model.
Thanks and please take a moment to rate as fixya.
Dec 05, 2008 | Toshiba Satellite A35-S159 Notebook
A35-S159 TOSHIBA satellite
Toshiba no longer supports the A35-S159 laptop.I found my drivers here free! http://www.gzrcw.net/drivers/toshiba/Satellite/drivers_1176.html
Sep 26, 2008 | Toshiba Satellite A35-S159 Notebook
Toshiba Satellite A35-S159 Shut down
If it does the same thing when it's plugged in, it might be time for a trip to the service center.
Mar 21, 2008 | Toshiba Satellite A35-S159 Notebook
Will not power up
pull battery and cord. push on / off button for 60 sec. put battery back in and plugg in power and boot up.. something else to try is some one elses battery to boot up in.
Jan 07, 2008 | Toshiba Satellite A35-S159 Notebook
Automatic Shutdown
Sounds like your fan may be clogged up. I suggest you consult the documentation on how to remove the laptop cover and then clean the fan out. You will be surprised at all the crap in it.
Good luck.
Nov 24, 2007 | Toshiba Satellite A35-S159 Notebook
Toshiba A35-S159 Recovery and Applications/Drivers DVD
If what you really need is the recovery disk, you can call Toshiba for it but if you only need the drivers, you can go to support.toshiba.com or pcsupport.toshiba.com. For the graphics driver, if you know that you have intel chipsets, you can go to intel.com/support/chipsets  -  there please select your chipset family then click on the "download" under graphics for your
specific chipset then please select your operating system. Please restart your laptop after the download
and see if it works. Thank you.
Nov 23, 2007 | Toshiba Satellite A35-S159 Notebook
Toshiba Satellite A35-S159 Notebook Logo
209 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
