Question about Weaver 849433 (8x24) Binocular
I see 2 planes of vision on my 8x24 weaver binocular
  • 121 Answers
This is more common than you would think.. Here's how to set up a pair of binoculars to suit yourself.
Any good binocular will be able to do this and the reason is to allow you to adjust them for the difference in strenght between your two eyes. I wear glasses myself and sometimes contact lenses so it's good to be able to quickly adjust them.
1. turn the binoculars over so you are looking at the underside.
2. on the eyepieces can you see on one eye(usually the right eye) a little plus - minus marking. The eyepiece should be able to rotate a little to each side of this marking.
3. Set the rotating eyepiece to the middle setting.
4. Look through the binoculars as normal and bring the two sides together until you form the two circles that you see into one.
5. Pick an object app 10 meters away.
6 Presuming that the adjustable eyepiece is on the right hand side then close your right eye, look at the middle distance object you chose with your left eye and use the central focusing knob/wheel in the middle to bring your left eyepiece into focus.
7. Now, close your left eye and adjust the rotating right hand eyepiece while looking at the same object until your right eyepiece is in focus.
8. The binoculars should now be set for the differences in strenght of your eyes and you can use the middle focus control as normal.
Most binoculars have a soft rubber eyepiece that can be folded back for people who wear glasses but I, like most people I know who wear glasses, find it horribly uncomfortable.
This method allows you to set them for yourself and if someone else uses your binoculars you can quickly reset them for you.
Hope this helps...
- Oh yeah, sorry, forgot to mention.. This set up is so you can use them without wearing your glasses.. Much more comfortable!!
Posted on Oct 20, 2009
How do I find eyecups for Bausch and Lomb 8x24 binoculars
Any sporting goods store that carries that brand should be able to get you replacement cups. Otherwise the Bausch and Lomb website should get you to the right place.
Aug 23, 2014 | Optics
Where can i find a BAIGISH Sakura 10-70X50mm Night Vision Binoculars Scope user guide/manual online?
Dino Direct carries them and has a pretty good description for them but is not complete. If they opearte in the manner I think they do, hold down on the lever to power them- do not pump, just press and hold. Since there is no mention of a battery or cell, this is the usual alternate method to power them.
Otherwise the online information that is most complete is http://www.dinodirect.com/sakura-scope-10-70x50mm-binoculars-night-vision.html
Jan 12, 2012 | Optics
Unit does not turn,I think it needs a switch,looking for some place local for repair.Returned to weaver twice problem still exists
Jemenie!!! Apparently Weaver doesn't know what to do. Call the big boss and give a ear full.
It could be a bad switch, broken wire, bad image tube, faulty ccfl inverter, multiplier. Without some troubling shooting it, it is impossible to tell. stewbison
Feb 26, 2011 | Weaver NightView (849397) Monocular
My problem is that i have a Night Vision Binocular Rigel 2100 and i Cannot see nothing thru them is all black
Hello, did you install new batteries? Is the battery compartment terminerals clean? stewbison
Jan 21, 2011 | Night Owl Optics Rigel 2100 Pro Night...
I have Minolta Pocket 8x24/8.7, 40 year old binoculars. One side is "limp" and doesn't stay in position for viewing. Fix??
Most compact binoculars have a central bridge. The objective (big lens) end of the binocular hinge usually has a ball bearing in it. The other end may either have a blanking cap or a hub where the neck strap attaches. Removing this cap or hub will reveal a grub screw which tightens another ball bearing against the bridge. Take the appropriate part off the limp side and look for the grub screw. Tightening it will decrease the "limpness". Be careful, as these are sometimes set in place with a locktite of some kind. Best to release pressure first before tightening.
Jan 31, 2010 | Minolta Activa Pocket Binocular
On scope adjustment my older weaver 3x9 micro trac dosent have clicks just marks on the dial how much change in 1 mark movementscope is about 20 years old
Most of the older type scopes were rated at 4 clicks per inch at 100 meters.But to be sure you will have to test it. I generally do that at a 50 meter range and then it is 4 clicks per half inch.
Oct 11, 2009 | Weaver Rifle Scopes Grand Slam Silver...
Need battery
Check with; www.rugift.com they sell these russian NV and will probably have the batts or have a source. Good luck. :)
Dec 16, 2008 | Kalinka Baigish 21 Russian Night Vision...
Newcon Optik Night Vision Binoculars BN5
The lenses screw out, the electronics are in the body and this involves removing all the screws, including the ones behing the rubber casing. Why do you wish to strip them out?
Nov 06, 2008 | NewCon Optik BN-5 Binocular
Weaver T-36 scope fails to hold zero
"Iron Sights" in Tulsa, Ok does service work and has parts for the original El Paso type Weaver scopes.
They have did an excellent job on my old Weavers.
They are slow turnaround, but excellent work.
May 21, 2008 | Weaver Riflescopes T-Series Adjustable...
Binocular Double Vision
We can align yur binoculars for your for 25-30.00 plus 5.00 to ship back to you. Some units have handy set screws to make adjustments from outside the unit. Call me, wwwbinocularservice.com
Art
Mar 05, 2008 | Magpix B350 Binocular
Weaver 849433 (8x24) Binocular Logo
129 people viewed this question
Top Weaver Optics Experts
Mark Campeau
Level 1 Expert
freebyrd04
Level 1 Expert
colinat108
Are you a Weaver Optic Expert? Answer questions, earn points and help others
