Question about Motorola Mobility Moto W233 Renew Cell Phone
What dose no files available to insert/attach mean
  • 7,993 Answers
It means that you wanted to attach a file to your message, but the system cannot find it, or you pointed to the wrong folder, or you made a mistake in the name.
Hope it helps.
Posted on Sep 28, 2009
Mu computer is windows 7 professional
Marie, If your computer is not equipped with a SD/Micro SD card Reader you will have to purchase one to simplify looking at it and copying it on computer. You can also use appropriate cable possibly to hook your camera up to computer.
Step 1/ Insert a USB card reader into an available USB port on your PC.
Step 2/ Insert the micro SD card into the card reader. Some card readers will only accept standard SD cards. If that's the case, insert your micro SD card into an SD card adapter and insert the adapter into the card reader.
Step 3/ Click "Open Folder to View Files" in the Auto Play window to launch Windows Explorer in the appropriate drive letter. Alternatively, press "Windows-E" and click the card reader's drive letter.
Step 4/ Drag and drop files to or from the micro SD card's drive letter to copy files. Alternatively, right-click and drag files and then select "Move Here" to move the files without keeping the files in the original location.
Step 5/ Select a file, press "Delete" and select "Yes" to delete files from the micro SD Card.
Step 6/ Right-click the micro SD card's drive letter and select "Eject." Once ejected, you may safely remove the card.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Transfer Pictures From MicroSD Card to PC
How to use card reader
Card Readers Adapters
Memory Card Readers
Aug 20, 2016 | Cameras
How to email photo taken with computer camera
If using windows any version it is very very easy to do.
Right click on the picture and scroll down to send to then choose mail recipient...
This should open your default email application. and just fill out the to address and send.
If that doesn't work it will depend on what your default email application is.
For Outlook you would just open New Email : and you have 2 options..Insert Picture or attach file..both of which will open a search box looking for where the picture (file is stored).
Google mail is a tad different but also same choices compose new email insert file or insert photo. Both of which you must direct to where the (picture, file is located)).
Or you can just drag and drop the photo into the body of your email and send.
Almost every email app has the same options...Insert Photo (image) or attach file.
Good Luck
Jul 05, 2015 | Dell Inspiron Computers & Internet
DONT HOW TO E MAIL A SCANNED DOCUMENT
  1. Step 1 Go to your e-mail program.
  2. Step 2 Click the New Mail, Write Message or similar button, depending on your application to create a new e-mail message.
  3. Step 3 Enter the address of the recipient in the To field.
  4. Step 4 Type a subject in the Subject field.
  5. Step 5 Add a message to the body of the e-mail as usual.
  6. Step 6 Click the Attachments button. Many programs have an icon of a paperclip for it. Also look for an Insert File or Insert Attachment option in the File menu.
  7. Step 7 Browse your files to find the attachment you want to send. You may need to click on a Browse or Find button to see your directory.
  8. Step 8 Click on the filename. If your program allows you to attach more than one file at once, hold down the Control key (or Shift key on a Mac) as you select another one.
  9. Step 9 Click the Attach Insert or Open button, depending on your e-mail program.
  10. Step 10 To send another file from a different location, click the Attachments but-ton again and repeat the steps.
  11. Step 11 Click the Send button when you're done.
May 28, 2010 | Lexmark X2500 All-In-One Printer
Pc cant desplay.when switch on the pc it comes on but nothing show on the screen.
If absolutely nothing comes up on the screen when you boot up at all the first thing you should do is check your cables to make sure that all of them are connected properly and that the video cables are screwed in properly with there attached thumb screws for a tight connection. If this dose not work my next suggestion would be to insert a copy of the windows install cd that came with your dell and see if any thing comes up(because if it dose it means that it is your screen settings and not a hardware failure) if this dose work I would suggest reinstalling. If not your video card has probably failed on you sorry but just to make sure of this what you should do is turn your computer around and look at the back of it here you should be able to find 4 lights each labeled a single letter from A-B, once you find them turn on the system and record the pattern of flashes, ie. "A A B C D A" and this will be your hardware error code you can call up dell and they will tell you exactly what is wrong with your system.
I hope this helped.
Thank you,
Norse
May 18, 2010 | Dell OptiPlex 170L PC Desktop
Can I email my projects if I am using MSN.Com email? how do I set that up in control panel?
  1. tep 1 Go to your e-mail program.
Nov 15, 2009 | Broderbund PrintMaster Platinum Version 18
How can i get a picture from one of my folders to email it to someone?
Most email programs have an 'insert' function. Click on it, then find the photo you want and click on it then OK. The image is then an attachment to the email.
Sep 29, 2009 | Computers & Internet
Cant attach file (avi.) to email
The fiel is most likely too big. Try compressing the file  before attaching, or use a large file send service (there are many free ones available). Regards -- Joe
Feb 03, 2009 | Yahoo Mail
I have a Maxtor media drive attached to my HP computer. I tried to open a file on it and it froze up and slowed the whole computer down. I can no longer access the drive. I tried to attach it to another...
hmmm..well..that may mean that the computer is still in access mode...turn it off..plug into original computer..insert installation cd in drive,,..run set up from cd..should ask for you to turn on the drive somewhere in that sequence..
Oct 13, 2008 | Computers & Internet
I don't not have the Instructions on how the bobben should be threaded in the bottom of my sewing machine. I have tried everything that i can think of but it well not thread. If it dose come up it dose not...
The manual for this sewing machine (Model 4562) is available and may be downloaded at no cost from Singer.  The Link to that page is: http://www.singerco.com/accessories/manuals.html
Inserting a wound bobbin is found on page 15.
Aug 09, 2008 | Singer 7462 Mechanical Sewing Machine
I don't seem to be able to send photos by Kodak Easyshare e-mail even though I am on line and the address is correct.
Ditch Kodak Easyshare and just use your email program:
Attachment basics When you send photos in e-mail, the photos go along for the ride as attachments, just like any other file you add to an e-mail.
To attach a photo in Outlook:
  1. Click New to open a Message window.
  2. Fill in the To and Subject boxes as usual and type any message you wish to accompany the photos.
  3. Click Insert File (the paperclip icon), locate your file through the Insert File box, click the file's name and then click the Insert button. If you wish to add multiple files from within the same folder, hold down the Ctrl key while clicking multiple files, then click the Insert button.
  4. Repeat Step 3 for any other files you wish to attach.
  5. Click Send.
In Outlook Express:
  1. Click Create Mail to open a New Message window.
  2. Fill in the To and Subject lines and type in your message.
  3. Click the Attach button, locate the file in the Insert Attachment box and click Attach. Use Ctrl-click to select multiple files.
  4. Click Send.
In Netscape Mail:
  1. Click New Message to open the Compose window.
  2. Fill in the To and Subject lines, and type in your message.
  3. Click the Attach button or, in Netscape 6, click in the empty Attachments box.
  4. Select your file in the Enter Files To Attach dialog and click Open.
  5. To attach multiple files, repeat Steps 3 and 4.
  6. Click Send.
Jul 26, 2008 | Computers & Internet
Motorola Mobility Moto W233 Renew Cell Phone Logo
49 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
