Question about Garden
Looking for a wiring diagram for a 13hp powerfist
No spark when engine is turning over
  • 80 Answers
Check the gap setting of your points and make sure they are not gapped too far apart. Also you could have a bad condenser. If you have electronic ignition it will need to be replaced. If you have points, turn engine over and see if the points are opening up. If you have a meter you can check for voltage at the points as you crank the engine over.
John
Posted on Sep 28, 2009
My powerfist mig welder does not feed wire only clicks when trigger pressed and no voltage to wire feed motor what could be the problem
Don't know the welder, but often there is a protection fuse on the circuit board. Check this one.
Also look for broken wires around connections.
If the machine is clicking, then it will be a minor problem.
Disconnect from power when you check inside.
May 07, 2017 | Welding Tools
Honda engine 13hp no spark on plug
Start by changing plug. Make sure to ground plug to engine when testing for spark. After go after cable. If resistance is on you'll need to check magneto or coils
Dec 16, 2015 | 13 HP Engine GX390 OHV Horizontal Shaft
Spark plug wiring diagram for a 2003 chevy malibu
SPARK PLUG WIRE REPLACEMENT (ENGINE CONTROLS - 3.1L)
Removal Procedure
  1. Turn OFF the ignition.
  2. Notice: Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  3. Remove the spark plug wires 2, 4, and 6 from the engine left side spark plugs.
  4. Remove the spark plug wires from the retaining clips.
  6. Remove the spark plug wires 1, 3, and 5 from the engine right side spark plugs.
  7. Remove the spark plug wires from the retaining clip.
  9. Remove the spark plug wires from the ignition coils.
  10. Remove the spark plug wires from the engine.
  11. If you are replacing the spark plug wires, transfer any of the following components:
    • Spark plug wire conduit
    • Spark plug wire retaining clips
Installation Procedure
  1. Install the spark plug wires to the engine.
  2. Install the spark plug wires to the ignition coils.
  4. Install the spark plug wires 1, 3, and 5 to the engine right side spark plugs.
  5. Install the spark plug wires to the retaining clip.
  7. Install the spark plug wires 2, 4, and 6 to the engine left side spark plugs.
  8. Install the spark plug wires to the retaining clips.
v\:* { behavior : url(#default#VML); position:absolute; } v\:* { behavior : url(#default#VML); position:absolute; }
Aug 20, 2014 | Vehicle Parts & Accessories
Need wiring diagram for 2002 cub cadet model(2000) 13hp lawn tractor
if wont start look at fuse behind dash and the relay
Aug 18, 2014 | Garden
My 5700 watt 11 HP McCullough generator wont start. I'm getting good gas to the plug but no spark.
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
Oct 25, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
Run fuel line from truck tank to 13hp honda engine
This will work if the 13hp engine has its own fuel pump to draw fuel from the tank. Sounds like a good idea, use as mush steel line as possible to prevent line damage and associated leaks.
Apr 17, 2010 | Air Tools & Compressors
SPARK PLUG WIRING
i am looking for a diagram for 1996 ford f-150 for the spark plugs.
Jul 31, 2008 | 1996 Ford F150 Regular Cab
Garden Logo
541 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
