3M Microfilm Reader/Printer 35mm film repair
Hello Sir,
We have KIP 3M 630 Reader/Printer 35mm film aperture card reader printer Repair. We need printout of Drawing. Pl. suggest me how to get. Is it possible to repair this machine. or you can send new machine for Quotation for taking printout. My address:V.V.RAO-Design's Dept.
ASACO PVT. LTD. #92-93, 1st Floor Swapnalok Complex, SD Road, Secunderabad-3. AP INDIA Or
3m 630 microfilm printer and viewer, the paper is getting hung up and scorching the paper, and the light will not come on for viewing. Also bad image.
Posted on Mar 24, 2010
The library where I'm trying to use microfilm has a brand new LG reader. It, of course, has a flash drive port. I thought I was using it yesterday but got home to find the flash drive empty. I need a...
Hello -
As a librarian by profession, I suggest you ask one of the librarians for instruction in using your flash drive with that reader. The librarian will probably have one of the library aides instruct you.
In fact, the library may have a handout with instructions, which you can keep.
Best wishes.
Jan 31, 2018 | LG Televison & Video
Pictures are dark
First, check if you're taking the lens cap off. If you're taking it off, then check your exposure. See if your light meter responds to changes in illumination. If everything seems fine, then check if the aperture of the lens works as intended. Then, without a lens nor film in bulb mode, check for the mirror and shutter to work properly. If the light meter, aperture, mirror or shutter seem to flaw, then get your camera serviced by an experienced camera repair technician.
Jan 28, 2014 | Minolta Maxxum 5000 35mm SLR Camera
We have a Canon MP90 microfilm reader/printer. It works as a reader. However, it won't print. There is a code flashing on the front "P1". What does this mean? I have checked the toner...
the problem is the machine is not feeding paper. need to clean or replace the feed rollers. i have seen this happen quite a bit. the rollers are the same as a canon pc-6 copier and you can order them from PRECISIONROLLER.COM
Feb 22, 2011 | Canon Office Equipment & Supplies
Can't download pictures from camera to laptop. Never had a problem before. It states USB is not recognised, bought a new USB lead & it still doesn't work. USB card reader doesnt work on my laptop....
Let's go all the way back to your card reader not working when you plug it in. Are you sure? Sometimes you have to open "my computer" to find will be a removable drive.
Feb 06, 2010 | Cameras
My Nikon N75 35mm SLR hasn't had any problems in the past, but I finished a roll of film yesterday and loaded a new one, then similarly to what a couple other people have described on here, the screen said...
Make sure the lens is set on the largest aperture number and locked to that setting. The camea if it cannot control the aperture will display ERR and lockup the camera until it can control the aperture. Take the lens off and make sure to lock it onto the camera so you can hear the locking pin click. The ERR is a lens (wrong series lens if you changed lenses) or the lens is not locked on correctly, or the aperture is not set correctly. After this it is a repair issue.
Dec 31, 2009 | Nikon N75 35mm SLR Camera
FEE flashing above where # of pics is showing
Thank you for using FixYa for your problem
If you get an "E" after loading the film it means that the camera is still Empty and the film has not loaded properly. The most common cause is that the leader has not been pulled out enough past the red mark. I also like to place a sprocket hole on a sprocket tooth (I assume here that the N80 uses a sprocket drive system like other Nikons). When loaded properly the film should advance to frame #1.
Your "FEE" error is something else again and has nothing to do with the film. Apparently the film was properly loaded if you got that also. "FEE" is an aperture error which you get most commonly when you are in one of the auto modes (P or S) and you don't have the lens aperture set to the smallest aperture (largest number, usually f22). Set the aperture ring on the lens to the highest number.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Richard Scott
Technical Support
New Zealand
Dec 02, 2009 | Nikon N80 35mm SLR Camera
Card reader not working
Try reinstalling the usb driver, look to see if there is an updated driver for *********** board.
Jan 02, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Canon EOS Rebel K2 constant low battery indicator light
Canon also uses the low battery Icon as a generic error code. Try taking the lens off the camera. If this fixes the problem the lens needs a repair (most likely the aperture unit). If not then the camera needs the repair (either the shutter or dc-dc converter circuit).
Nov 18, 2008 | Canon EOS Rebel K2 with 28-90 lens 35mm...
630 EOS draining battery with unit off
Best way to handle this would be to get a manual and take apart the unit and monitor how much current the units drawing as when off Im thinking it shouldnt draw anything. Or call here and ask about a repair cost. Good luck Main support number1 800 828-4040
Apr 15, 2006 | Canon EOS 630 35mm SLR Camera
1,128 people viewed this question
