Question about Samsung Televison & Video
My dvd player keeps saying the word "protect" then it shuts right off each time I press the on button
  • 3,741 Answers
In your unit there is a fuse its got weak.it needs to be replaced.or the power to the fuse on the circuit board is getting short.check out the fuse on the board.it needs replacement.it shows word "PROTECT" that is for fuse replacement message.the cost of fuse is $3 .its easily available at local electronics hardware shop.
dont try to ON the unit again n again if the fuse blows then if you turn it ON the main board can blow out.and that will be cvostly issue.
This will help. Thanks please keep updated.please do rate the solution if helped.thank you for using fixya.
Posted on Sep 28, 2009
When I turn the DVD player on it says "protection" on the screen and automatically shuts off. Can I fix this myself?
WHEN YOU TURN ON YOURN DVD PLAYER USE THE REMOTE AND PRESS MENU THEN GO TO STTINGS THEN SECURITY SETTING THEN REMOVE PROTECTION
Jan 17, 2013 | Televison & Video
Logik lpd850 port' dvd returns to load disk after a minute or so
push down the button to open the lid, keep it pressed down. right next to it it a tiny button that detects whether the lid is shut. tape a little piece of folded paper onto it and then it thinks the lid is always shut. it just means you have to switch it off to remove the CD
Oct 09, 2009 | Televison & Video
Dvd won't play or eject
If you want to get the dvd out
you can try this:
First turn of you dvd player at the mains, Then power it up, But the moment it powers up press the eject button a few times so it doesn't start to load. If it doesn't work the first time try it one more time since you may not get the hang of it at first.
then you dvd should eject.
With dvd players like this, corrupt, copied or really scratched dvds may make your dvd player do this.
Regards
Jul 25, 2009 | NexxTech DP3222 DVD Player
My dvd home theatre system ht tx75 keeps shutting down
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 28, 2009 | Samsung HT-TX72 Theater System
Picture is split -- says P-SCAN. It's stuck
that means it is stuck on progressive scan.  If your tv is not able to handle progressive scan, you need to change it back or reset the player.
The DVD player may be set to Progressive Scan Mode. You will need to change it to Video Mode by using the remote control. Point the remote control directly at the DVD player, and then press the PSCAN button 2-3 times. If you are still encountering problems with the DVD player, reset the unit back to the default setting.
To Reset,
Make sure you do not have a disk in the tray. Using the DVD player remote control: 1) Press the “Setup” button. 2) On the “Down” arrow, press it three times. 3) On the “Right’ arrow, press it once. 4) On the “Down” arrow, press it three times. 5) On the “Right” arrow, press it once, then press “Enter”. 6) Press the Setup button. *The default setting will take affect as soon as you press the setup button (step 6).
Hope it helps..please rate!
Mar 07, 2009 | Coby DVD-224 DVD Player
DVD Recorder Screen keeps saying HOLD and not switching on
CHILD LOCK:
The Child Lock Deactivates All Buttons On The Unit & Remote Control.
To Deactivate Press & Hold (OK) & (RETURN) Simultaneously Until "X HOLD" Disappears.
Oct 28, 2008 | Panasonic DMR-EH50 DVD Recorder
My dvd is locked, I dont have the manual so I don't know how to unlock it
* Turn the player On
* Open using the remote
* Press Setup
* Press volume buttons Up, Down, Up, Down
* Press Right button
* You will see a number appear in the top right hand corner of your screen, Keep pressing Right until the number 255 appears.
* Press Setup to exit
* Your player will now be region free
Feb 22, 2008 | Goldstar GBV241 DVD Player/VCR
How to set time and date
Turn on. Goto channel 3 or 4. Press DVD/VCR button until display says VCR. Press TV/VCR button until the display says VCR. Press SETUP button. Select SYSTEM SETUP. Select CLOCK SET. Edit time and date. Press SETUP button.
Jan 07, 2008 | Toshiba SD-V394 DVD Player/VCR
How to shut off closed caption on my dvd
There is a "subtitle" button to the right of the "3" button. Press that until it says subtitle or caption off.
Dec 29, 2007 | Durabrand DVD-1002 DVD Player
Cd player.....toshiba se-r0094
I have been having the same problemm, how can i solve this?,,thanks, Reg!
Nov 07, 2007 | Audio Players & Recorders
Televison & Video Logo
19 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
