Question about Bosch Saws
I have a Bosch jig saw that I am having trouble getting blades in; I took the saw apart and now I can't get the saw back together. Help
  • David Ford
    David Ford May 11, 2010
    K what is the exact model number on the saw and I will try and find you a breakdown for reassembly.
  • 2,176 Answers
You can try to get a breakdown at Boschtools.com but you will need the exact model number and on the left side there is a link to download a breakdown. Let me know if you need more help and I will try and if I have answered your question would you please rate this response accordingly.
Posted on Oct 10, 2009
How to change blades on a bosch 1587avs
Turn the handle on the top counterclockwise like shown in the video.
But the handles break often, see the link for a parts breakdown
Bosch nbsp1587AVS nbspTop Handle Jig Saw
Feb 09, 2015 | Bosch 1587Avs Jig Saws
I have a bosch jigsaw the one you have to raise handle to remove the blade i took the front of it off when i put it back together it makes a loud clicking noise any help would be appreciated thanks
www.boschtools.com/Service/ProductServices/.../ServiceandSupport.asp
Take it back apart and see what is improperly installed and clicking .
Sep 14, 2014 | Bosch Saws
Jig saw b4300 blade replacement
This tool has no mechanism for the fixating ot the saw but only a short ***** part 53 its a fault in the manual , it simply replace the saw with a screwdriver. or simply the clamp ***** to release turn it loose and from the top you can replace the clamp *****
Bosch B4300 0601582535 Jig Saw Parts
Sep 05, 2013 | Bosch 1581AVSK Top Handle Jig Saw Kit
My saw blade isnt moving up and down. The jig saw sounds like its running just the blade isnt moving at all..... how do i fix it?
Unplug and Take the case apart. You will probably see that the gear moving the blade collet is stripped. Or, the gear fell out of place. Try putting it back together and see if it works.
Jul 08, 2011 | Saws
I have a bosch 1587 vs jig saw i got used. I don't know how to install a blade. I have never had one like this. I turned the top handle the way the diagram showed but I don't think something is working.
In most models at the blade shuck holder is a screw that thigh the blade,unscrew it and change your new balde .
Also Go to this LINK and find the part/diagram that can help you.
Please thumbs back if help is fine,thanks!.
Nov 02, 2010 | Bosch 1587avsp Vs Orbital Jigsaw
After changing the blade on a bosch 1587VS jig saw the blade turns sideways when sawing. How is this corrected? Thanks
I would recheck the installation of the blade and the tightness. If still a problem there is a spring under the lever that might have broke (they tend to do that) and is jamming the spindle. Let me know and I will help you with the breakdown for this tool
Jul 26, 2009 | Bosch Saws
What is the process to change a saw blade on Bosch GST 2000 jig saw SDS system
There is a lever on the handle, you have to pull it up and rotate it counter clockwise about 3 times (shouldn't take any more than that. The blade will be loose now,put in the new blade and turn the back lever clockwise until it clicks. The blade should be tight,push the lever down and move it into the slot in the handle.
I hope this helps
Apr 06, 2009 | Bosch Saws
Blade won't stay in jigsaw
It sounds like you need to replace the shaft.
Feb 22, 2009 | Bosch Saws
Blade wont stay in Bosch 1882VS jig saw
ARE YOU USING BOSCH BLADES IF NOT GET SOME THEY ARE MADE A LITTLE DIFFERENT THAN SOME OF THE OTHER BRANDS AND FIT A LITTLE BETTER , IF YOU ARE THEN DO NOT KNOW
Feb 22, 2009 | Bosch 1587AVSK 5.0 - AMP Top Handle Jig...
Saws Logo
102 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
