Question about Sharp Microwave Ovens
No power. but it is pluged in and checked breaker
  • 3,600 Answers
Try plugging a lamp intothe same socket and see if it comes on if it does the fuse in the micro wave has blown but there are up to 5 fuses on some models so I need a model and serial number to help you fix the problem.
Posted on Sep 28, 2009
I have a 2000 23ft comfort travel trailer, it is pluged into electrical, all lights work, but I do not get any power from outlet plugs. I checked breakers & fuses, no outlets work.
On my trailer the gfci is a seperate button in the fuse panel that shuts down the 120v outlets, all the lights run off the 12v so they continue to work, does your microwave and ac work?
Mar 02, 2015 | Microwave Ovens
CIRCUT BREAKER BLOWS WHEN PLUGED IN
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Mar 14, 2011 | Emerson MW8775W Microwave Oven
G.E. Spacemaker trips the breaker on the circuit it is pluged into if you open the door when it is running.
Check the door switches and the wires connected to them. I've seen at least one door switch that had bad contacts literally fall apart due to overheating. It's possible you have one that is broken and twists over to touch a grounded metal part when you open the door (also inspect the bracket that holds the switch for the same issue). The same switch doesn't trip the breaker when the oven is not running because there is no power going through it at that case.
Nov 27, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I pluged the microwave in it was working and when I pushed it back and when I looked at it it waqs not working any moren mdl # is 87449 kenmore counter top microwave
Check the outlet it is plugged into. Remove the microwave plug. If you don't have a voltage meter handly to test the voltage at the outlet or the continuity of the microwave plug, I would suggest you plug in a lamp from your living room into the outlet. If it doesn't work, either the outlet is a tripped (GFIC) Ground Fault Interuption Circuit outlet or the circuit breaker tripped in your electrical panel box or the microwave cord is damaged and caused a short and blew the fuse. To check these I would try plugging the light in and press the red reset button located on the wall outlet or flip tripped circuit breaker in panel. If it's a damaged cord or fuse, you can visit this web site for Sears parts www.searspartsdirect.com If you found any of these suggestions helpful, please rate my solutions. Thanks D. Lange
Apr 23, 2009 | Microwave Ovens
Triping breaker as soon as it is plugged in. can anyone tell me what usually is the cause of this problem when as soon as i plug the power cable in to the outlet, it would trip the breaker? no power to the...
try pluging it in on another outlet with an extension cord must be a diffent cerciut breaker if it happens again the microwave has a short. if not its that breaker or outlet.
Mar 31, 2009 | KitchenAid KCMC155J Convection/Microwave...
My GE spacesaver oven JVM230 quit, like a fuse blew. No over the stove light, no exhaust fan, nothing. I checked the circuit breaker and pluged in an appliance and it worked. The plug is okay. Jim
This is almost certainly a blown thermistor. This device is located at the air outlet on the microwave. This is a thermally sensitive resistor that cuts power if the unit overheats for safety. It can fail because of age also. Replace with the save value unit. You can get this part from electronics stores like Radio Shack.
Go to;
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JVM1640SJ
click on your model number. Then on the next page you can select diagrams to look at.
Mar 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave won't start
hi lola,
check your fusebox/ breaker panel first, also check the outlet it's pluged into if it's a GFI it may have tripped, if that's ok you may have a bad control board or transformer, either way if the unit is not in warranty it may cost more to fix it than to buy a new one, but you should contact a local appliance repair company to check it out to be sure.
Mar 20, 2008 | Goldstar MV-1526 Microwave Oven
Whirlpool MH3184XP-B 2 Black- Will not start, no power, no display
Downstream of the main 20 amp breaker in the upper right hand corner, is a miniture 4 amp fuse in an inline fuseholder. I replaced this and so far, so good
Aug 21, 2007 | Whirlpool MH3184XP Microwave Oven
Microwave Ovens Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
