Question about Lexmark C510 Laser Printer
34 incorrect media
Could you tell me what does 34 incorrect media mean?
    Problem Solver:
  • 5 Answers
34 Incorrect Media message appears if the printer has detected a mismatch between the type of media requested by the user and the type of media actually loaded in the paper tray.
To attempt a resolution for this issue, please do the following:
  1. Press the green GO button on the printer operator panel. Printing will resume, but the printer must go through a POR (Power On Reset) in order to clear the message.
    NOTE: The printer does not automatically reprint the page that generated the error message.
  2. Verify that the media you are using is supported by your printer in terms of size, weight, and input source.
  3. Using the printer operator panel, verify that the type of media loaded in the paper tray matches the Paper Type setting in the Paper Menu. Detailed instructions for navigating through the printer menus and changing the media type setting are provided in the C510 User's Guide.
    • If the media type setting is incorrect and cannot be changed, there may be an issue with the media type sensor. Proceed to step 5.
  4. Using the printer's operator panel, verify that the paper loaded in the paper tray is the size listed under Paper Size in the Paper Menu. Detailed instructions for navigating through the printer menus and changing the paper size setting are provided in the C510 User's Guide.
    • If the paper size changes to an incorrect setting or cannot be changed, it is likely that the paper size guides in either the 250-sheet or the 530-sheet paper tray are not set correctly. Remove the media from the tray and verify the location of the media guides.
  5. Power the printer off and then back on again.
  6. Resend the print job to the printer.
  7. If the error persists, you will need to contact Lexmark Technical Support for assistance. Please obtain the printer serial number before contacting Lexmark. If possible, call from near the printer as this will allow for the most accurate possible diagnosis.
Hope this will help you please let me know if it worked and don't forget to vote..
Cheers
Posted on Dec 18, 2007
Error 34 short paper
Posted on Jan 14, 2009
I have replaced the drive belt on my delta 34-670 and the teeth on the rubber belt 100XL keeps stripping under the least amount of load. the drive belt keeps stripping on my delta 34-670
several possible reasons
build up of worn belt in the teeth of the gears
incorrect belt being used (wrong pitch belt being used -not genuine)
shafts being driven are not free to turn--seizing on the bearings, incorrect placement of rocker shafts /pushrods---valve springs bottoming out locking the shaft
incorrect tensioner actioner ( hydraulic tensioner not tensioning properly allowing the belt to flap in operation)
idler pulley problems ( bearings or misalignment of all pulleys
Nov 19, 2016 | Cars & Trucks
What is error code 34 and where may i locate a troubleshooting guide?
Do you mean Check 34? Fault 34? Either of these indicates a problem with zone 34, which the location should be displayed by your keypad, such as Kitchen Glass, or something of that nature.
Jul 30, 2014 | Honeywell 6160PX Custom Alpha Prox Keypad
T632 printer error : 34 short paper. What does that mean? Don't see 34 as a valid error code.
This error message means that the printer has determined that the length of the paper in the source specified on the second line of the display is too short to print the formatted data. For auto-size sensing trays, this error occurs if the guides are not in the correct position.
Please try to do the following
? Press Go to clear the message and continue printing. The printer does not automatically reprint the page that prompted the message.
? Make sure the Paper Size setting in the Paper Menu is correct for the size paper you are using. If MP Feeder Size is set to Universal, make sure your paper is large enough for the formatted data.
? Press Menu to open the Job Menu and cancel the current job. Please see also the media guidelines on the user manual p.29
For further assistance, please contact Lexmark Technical Support.
Aug 02, 2011 | Lexmark T632 Laser Printer
I have a 1995 isuzu pickup it giving me error codes 15 and 34 and I've already been to 3 repair shops and can't get it fixed can you give me some help
I have the manual for my 93 rodeo and code 15 says ENGINE COOLANT TEMPERATURE SENSOR-SENSOR SIGNAL SHORTED, GROUNDED OR OUT OF RANGE. Check your coolant sensor by the water neck-it sends a signal to your dash gauge (coolant temp)
Code 34 my book has 2 symptoms- if its a 3.1 liter engine it says MAP SENSOR-SIGNAL VOLTAGE LOW-CHECK INCORRECT IDLE SPEED, VACUUM LEAKS, LOOSE AIR DUCT, MAP SENSOR CIRCUIT
If its NOT a 3.1 liter engine, then code 34 is EGR TEMPERATURE SENSOR CIRCUIT-SHORTED
Hope this helps.
Mar 19, 2010 | 1995 Isuzu Pickup
Hi guys, can someone tell me the meaning of the codes 34 and 63 in an Oldsmobile Cutlass Supreme. .
Code 34 is for the mass airflow sensor and code 63 is EGR flow check. Hope this helps and good luck. If you go to autozone.com and register you will have access to a complete online repair manual. Hope this helps and good luck.
Jul 15, 2009 | 1988 Oldsmobile Cutlass Supreme
Error 34: Incorrect Media
Someone had set the paper type to "Transparency". I reset the paper type back to "Plain" and the printer started working again !
Jan 15, 2009 | Lexmark C522n Laser Printer
Messages are giving an incorrect time and day
I would suggest reading page 33 and 34 of your manual again
Jan 08, 2009 | Lands Phones
Temperature - Is fan supposed to constantly run or is it controlled by thermostat
You said ,Top half of Danby DKC645BLS refrigerator 10 degrees warmer than bottom half. Bottom half cooling to approx. 34 degrees.
Is it running all the time without cycling off and on as it should be doing?
Sorry to have to tell you this news.
But this would mean a bad thermostat or insufficient freon in the cooling system.
The same issue with the fact that one compartment is warm and the other is cool!
Let me know that service tells you!
Thank You
Huuum
Please remember toleave a rating
Oct 19, 2008 | Danby DKC645BLS Compact Beverage Cooler
Code 34 and 76
CODE 34 Open or shorted condition in the speed control vacuum or vent solenoid circuits.
Can't find any existing Code 76
Aug 02, 2008 | 1995 Dodge Neon
My ilo tells me to reformat it.!? How do I do that?!
Formatting is pretty easy. Go to a computer, plug it in, then right click and it should have an option to format. Unfortunatly, it will delete any saved information on it. Hope it Works
Jan 09, 2007 | iLO (2 GB) MP3 Player
Lexmark C510 Laser Printer Logo
1,676 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
