Question about Sony Televison & Video
How can remove the lamp houseing from tv 55sonywega
  • edocana Sep 28, 2009
    My sony No. kdfe55a20 and I dont see any side door on the ty Isee a fan on back of tv
    Have a 55sony wega Model,kdfe55a20 want to remove the lamp houseing Out of tha T.V. how can i do it cant see any side doos?
  • Sony Master
  • 497 Answers
Information on changing the Lamp is available beginning on page 76 of the manual included with your product.
Check these links to download the Manual.
http://www.docs.sony.com/release/KDFE55-60A20.pdf#page=78
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDFE55A20
Good Luck!!!!!!!!
Posted on Sep 28, 2009
  • 8,197 Answers
Make sure the tv has been un pluged for 15 mins befor you remove lamp. To remove lamp housing from tv you need to remove lamp door on side if tv. Then you need to turn the lamp housing 1/4 turn counter clock wise to remove. To install repeat steps opposite from removal. Also if you have the manual it will tell you in there, If not If I get the model # I can get it for you.
Good Luck
How do i replace burned out lamp
It's very simple, on the back of the TV you will find a square vented plastic cover held in by 4 screws. Remove the screws, you'll now see the lamp housing being held in by 1 or 2 screws. Remove the screw (or screws) you'll now see the lamp housing, it has a metal handle that pulls the lamp (and housing) straight out of it's slot. I purchased mine at Lamp Monsters on Amazon (Samsung Lamp with Housing BP96-01600A) for about $30.00. You will see them priced from 30 bucks up to and above $300 bucks! Good luck I hope this helps! TomD
Sep 27, 2014 | Panasonic PT-56LCZ70 56" HDTV
How do you replace a bulb in samsung projection tv hls5668wx
There is a video of the procedure here: http://www.samsung.com/us/support/owners/product/HL-S5686W . Make sure to get the exact matching lamp code number and type. This is listed on the right side of the TV and on the lamp case.
Then turn off the TV and let it cool for at least 30 minutes. Make sure not to touch the glass with your bare hands (particularly with the new lamp). Remove the single screw from the lamp cover and then remove the lamp cover. Remove the lamp cover duct by holding the locker and pulling it towards you. Next remove the screw holding the lamp in the housing. Separate the lamp from the housing by holding the handle and pulling it towards you. Reverse the process with the new lamp. Make sure the lamp cover is seated properly and the screw tightened to get the TV to come on.
I hope this helps.
Jan 30, 2011 | Samsung HL-S5686W 56" HDTV
How do i replace the lamp bulb in sony tv kdfe42a10
There are several online video tutorials that are available online. If you search some of the websites that seel the lamp, most have a tutorial.
You'll need...
1. a Phillips screwdriver
2. a 7mm (I believe) nut driver
3. Needlenose pliars
4. Gloves to keep acid from your skin getting on the lamp. The company I bought my lamp from provides cotton gloves (www.bulbsolutions.com)
Remove 3 screws from housing (2 on each side, and one that holds front of housing to the back of the housing)
Remove 2 mounting screws in corner of lamp that holds lamp securely to the lens.
Remove nut holding wiring harness to lamp
Remove screw holding wiring harness to lamp
Nov 08, 2010 | Sony KDF-E42A10 42 in. LCD Television
Can't see picture on my samsung tv...lamp, timer and standby light are blinking on the power button
You need to replace the lamp. Order the correct type and code number (from samsungparts.com or the store where you bought the TV). Before starting the replacement, make sure the TV has been off for at least 30 minutes and unplug the set. Remove the phillips screw that holds the lamp cover and then the lamp cover itself. Remove the two screws that hold the lamp to the housing. Pull the old lamp out by the handle. Put the old lamp in a safe place until you can properly dispose of it.
Handle your new lamp carefully (wear gloves to avoid skin oils on the lamp). Put the new lamp in the housing and close up the TV by reversing the above steps (secure screws, replace lamp cover).
I hope this helps.
Aug 14, 2010 | Samsung DLP HL-P5663W 56" TV
Removal of the lamp unit from the tv
sometimes lamp is replaced in the front of tv.If so the panel under picture pulls out revealing lamp housing which is held in with a couple screws.replace lamp housing assembly
Feb 22, 2010 | Panasonic PT-50DL54 50" Rear Projection...
How to install a SONY LAMP XL2400 into your TV
remove 2 screws from bottom back of tv(plillips) now carefully remove front cover.it unclips,sometimes you have to pry it off.take out screws from lamp cover,remove cover,take screws out of lamp, remove lamp.reverse process to put it back together.
Sep 19, 2009 | Televison & Video
How To change Sony XL-5100 Projector Lamp with housing
  • Installation is Quick and Easy:
    In most cases, replacing your projection lamp is quick and easy. However, it is recommended that you consult your owner's manual for more detailed instructions:
  • Unplug your TV from your power outlet
  • Allow the lamp to cool for at least one (1) hour before replacing it
  • Remove the Lamp unit cover (Usually located at the rear of the television)
  • Unscrew the lamp housing unit
  • Remove the old lamp housing unit and discard
  • Screw in the new lamp housing unit
  • Place the cover back onto your TV unit Caution: Do NOT touch the bulb directly with your fingers.
  • Jun 15, 2009 | Sony XL-5100 Projector Lamp for Grand WEGA...
    Where is the lamp housing unit & how do I remove it?
    The lamp is in the front of the TV. Pop off the gray cover, about the width of the screen, located just left of the power button. You will then see a bunch of warning labels on the left. Unscrew the one screw that is there and take that piece off. There's your lamp. Unscrew the screw on the right of the lamp and the lamp will slide out.
    Nov 05, 2008 | Panasonic PT-50LC14 50" Rear Projection...
    Tv lamp replacement
    I just did this myself. I'm a novice but it wasn't that hard. Your choices are to purchase a complete unit including the casing from a Sony repair shop for around $250, or just replace the lamp.
    I just replaced the lamp and saved $130.
    I just removed the screws from the side of the casing that protect the lamp. I disconnected the contact points and then popped open the housing.
    Remove the screws and the nut that attach to the lamp. Wear gloves when you handle the new lamp so you don't shorten the lifespan of the bulb.
    re-attach all the screws and slide it back in.
    It took me the longest to have line up the contact points when sliding it back into the TV. Make sure all the connections are snug and keep at it. Don't give up! I'll admit I was tempted!
    Oct 27, 2007 | Sony KDS-R50XBR1 50" HDTV
    Lamp location
    No, that was wrong advice. On this model, there is a large door on the right side (as you face the screen) of the TV at the bottom. Remove several screws to take the cover off. Inside, looking along the back of the TV (not toward the screen), you'll see what looks like a wire bail (handle) on a square inset piece about 3 inches square. Remove the screws and pull on the wire bail and the lamp housing will come out with the lamp contained inside. Make sure you unplug the TV before doing any of this. If you are replacing the entire housing with a new lamp you can just plug in the new housing and replace the screws and cover. If you are placing a new bulb in the existing housing you take off 4 small screws and remove the metal cage from the housing, remove and replace the bulb the same way the original is in there, put it back together, and you're done.
    Sep 17, 2007 | Zenith E44W46LCD 44" Rear Projection...
    Televison & Video Logo
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
