Question about Epson Stylus RX690 InkJet Printer
Error turn of the printer the turn it on
The printer was just fine later i had this error on the printer LCD "error turn of the printer the turn it on"
Error code 016-370 Restart printer If problem
Error code: 016-370
This is yet another error message asking you to restart the printer. You need to switch off the printer and then connect it via the USB cable. Press the hold and cancel buttons simultaneously. Then power on the printer again. On your LCD display you should typically see a message saying 'ready for download mode'. You will then need to initialize the firmware update process. LCD will change to the writing mode. 10 minutes later you will be prompted to start the printer again.
The firmware is available here:
http://support.dell.com/support/downloads/download.aspx?c=us&l=en&s=gen&releaseid=R148843&SystemID=PRN_LSR_3100CN&servicetag=&os=WLH&osl=en&deviceid=6673&devlib=0&typecnt=0&vercnt=1&catid=-1&impid=-1&formatcnt=0&libid=40&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=197745
May 02, 2011 | Dell 3100cn Laser Printer
Error 906 for mfp t642
  1. Turn off the printer and let it sit for at least 10 minutes.
  2. Then power the printer back on.
    • If the error does not return, try printing a few print jobs. If the error still does not return, continue using the printer as before but keep an eye on it for the next few days. If the error does not return, it may have been an isolated incident.
    • If the error does return, you can perform an NVRAM reset on the printer. Note: Please do this only as a last resort before requesting service. Resetting the NVRAM on the printer will cause the printer to return all customer-defined settings to the factory defaults. To perform an NVRAM reset:
      1. Turn off the printer.
      2. With the printer still off, press and hold the following three buttons: Select, Go, and the right arrow (>) Menu button. All three of these are located on the printer's LCD screen.
      3. While holding the three buttons down, power on the printer.
      4. Continue holding these buttons until you see Performing Self Test, Clearing NVRAM, or Restoring Factory Defaults on the printer's LCD screen. You can then release the buttons.
      5. If the error does not return on power up, continue using the printer but keep an eye on it for the next week or two.
        • If the error does not come back, the printer should be fine.
        • If the error does return, the engine/system board will most likely need to be replaced.
Jan 09, 2009 | Lexmark T642 Laser Printer
When turned on only copy button lit and a red exclamation lighton
Hi
Try unplugging it and check for specks of paper inside the printer, then try to replug it from outlet and turn it back on. try if it will copy then try printing. Hope this helps
Dec 12, 2008 | Epson Stylus RX500 All-In-One InkJet...
Wrong cartridge?
Doubled check the cartridge numbers and that they match what is on the printer. If no match get correct ones.
Oct 24, 2008 | HP PSC 1410v All-in-One Printer
Canon PIXMA MP450 "Servic Error 5100"
Try this... it worked on my MP450... Turn the printer on and open the lid, it shows the cartridges. Now let the cartridges settle to the left. You can notice that the cartridges run on a metal belt. It might be dirty, mine showed a black stripe on it. Take a cloth, a cleenex will be fine and clean it up. Move the cartridges to the right (force them with your hand) and clean the part of the belt left behind them. Now turn it off, close it up and turn it back on. It should work
Apr 02, 2008 | Canon Pixma MP450 All-In-One InkJet...
"Put in cartridge" error message
Issue: ERROR LCD: PUT IN CARTRIDGE
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Oct 20, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Error Message problem
Try to find anything that prevents the printer form moving the paper or print head. If everything is fine try reinstalling the printer driver.
If that does'nt work... get your printer serviced.
Oct 18, 2007 | HP PSC 2355 All-In-One InkJet Printer
Error message
Canon has a decent trouble shooting guide for this model: http://tinyurl.com/rgu6o Click on the Step-by-Step Troubleshooting link under Tech Support Unfortunately for this error code, all it says is this: Turn the machine off, and remove the power plug from the outlet. About ten minutes later, plug it in again, and turn the machine on. If the problem is not resolved, the machine may require servicing. Please contact your local Service Center.
Sep 14, 2006 | Canon Pixma MP500 All-In-One InkJet...
Epson Stylus RX690 InkJet Printer Logo
175 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
