Question about Sport & Outdoor - Others
I am replacing the wear ring on my 2001 seadoo sportster. I am having issues getting the impellar off. I have removed the cone and oil. but the bolt that goes though the entire assembly will onlt move the impellar instead of breaking loose to remove. Any suggestions on how to remove the impellar
Where can i get a free manual to see how to replace the wear ring on my 2001 seadoo gtx di
Posted on Aug 21, 2010
  • 69 Answers
To remove the impeller properly you will need a couple of specific tools. They are:
Impeller Shaft Holder - Part Number 295 000 028
Impeller Remover Tool - Part Number 295 000 001
Firstly insert the Impeller Shaft Holder on
the impeller shaft flat end.
Using the two screws previously removed from venturi,
secure the Impeller Shaft Holder onto the housing.
You will then need to heat the impeller shaft end with a propane torch to approximately 150°C (300°F) to break the Loctite bond that secures the impeller to the bolt, before to remove impeller.
Important - Do not heat the impeller directly.
Install shaft holder in a vice.
You can then loosen the impeller using the Impeller Remover Tool.
Insert the special tool in impeller splines.
Rotate the Impeller Remover Tool counterclockwise
and unscrew completely the impeller.
CAUTION:
Never use any impact wrench to loosen the impeller.
To remove impeller, apply a rotating movement
and pull at same time. Slide impeller out of housing.
Finally remove the tool from impeller.
Posted on Apr 13, 2010
  • 85 Answers
Most likey righty loosey lefty tighty.
Posted on Oct 03, 2009
2000 buell blast leaking tranny oil where cable goes in,,is there a gasket there?
Hi, Anonymous no there is an o-ring sorry you can't find the first and best tool you ever bought for your Buell but despair not for a mere $10 you can download another one. For more information about your issue and free downloads that you will need please visit the websites below and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day. Harley Davidson Sportster Clutch Cable replacement Reducing Transmission...
Sportster Clutch Cable Replace
Buell Service Manuals PDF Download
TWIN Motorcycles Buell parts
2001 Buell Blast Owners Operators Owner Manual Factory 2001 eBay
Aug 21, 2013 | 2008 Buell Blast
Where is the cam sensor on a 2001 gmc 3500 serria 8.1
  1. Raise and suitably support the vehicle.
  2. If the vehicle is equipped with the underbody shield package, remove the steering linkage shield.
  3. Disconnect the camshaft position (CMP) sensor electrical connector (3).
  4. Remove the CMP sensor bolt (2).
  5. Remove the CMP sensor (1).
  6. Inspect the CMP sensor for wear, cracks or leakage if the sensor is not being replaced.
    Installation ProcedureImportant: Inspect the CMP sensor O-ring for wear or damage. If a problem is found, replace the O-ring. Lubricate the new O-ring with engine oil before installing.
  1. Install the CMP sensor (1).
    Important: The CMP sensor bolt has self-tapping threads, care must be taken, NOT to strip the threads when installing.
  2. Install the CMP sensor bolt (2). Tighten
    Tighten the bolt to 12N•m(106 lb in).
  3. Connect the CMP sensor electrical connector (3).
  4. Install the steering linkage shield, if equipped.
  5. Lower the vehicle.
  6. Sep 27, 2012 | 2000 GMC Savana
    Where are the crankshaft sensors on a 2001 cadillac deville sedan?
    The crankshaft position (CKP) sensor is a three wire sensor based on the magneto resistive principle. A magneto resistive sensor uses two magnetic pickups between a permanent magnet. As an element such as a reluctor wheel passes the magnets the resulting change in the magnetic field is used by the sensor electronics to produce a digital output pulse. This system uses two sensors within the same housing for the V6 engine, and two separate sensors for the V8 engine. The PCM supplies each sensor a 12-volt reference, low reference, and a signal circuit. The signal circuit returns a digital ON/OFF pulse 24 times per crankshaft revolution.
    Removal & Installation
    1. Raise and support the vehicle.
    2. Remove the air deflector.
    3. Remove the oil filter adaptor.
    4. Disconnect the crankshaft position sensor electrical connector.
    5. Remove the crankshaft sensor retaining bolt.
    6. Remove the crankshaft sensor.
    To install:
    NOTE Inspect the crankshaft sensor O-ring for wear or damage. If a problem is found, replace the O-ring.
    1. Lubricate the crankshaft sensor O-ring with clean engine oil.
      NOTE Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
    2. Install the crankshaft sensor and the retaining bolt. Tighten the retaining bolt between 10 Nm (89 inch lbs.).
    3. Connect the crankshaft position sensor electrical connector.
    4. Install the oil filter adaptor.
    5. Install the air deflector.
    6. Lower the vehicle.
    7. Operate the engine and inspect crankshaft sensor for engine oil leaks.
    8. Perform the CKP System Variation Learn Procedure.
    Hope helps.
    Sep 20, 2011 | 2001 Cadillac DeVille
    Taco pump M#fe2508e2f1f2l0a Will not pump. impellar was replaced, wear ring is grooved. could this be the problem?
    Most likely the motor. Could be electrical. If it makes a humming sound, it is probably the motor. If there is no sound and no action of any kind, it is probably electrical. If it turns on and sounds like it's working but no action, it maybe the wear ring.
    Mar 16, 2010 | Plumbing
    Grease leaking into drum under agitator cone
    Remove the agitator cone. There will likely be a removable plastic piece with an O-ring. Oil could be leaking out of the O-ring into the washer, and water could be leaking into the bearings. If there is damage to the O-ring replace it, or if there is a bunch of schmag that is compromising the seal, clean it out, and re-install everything. This solved the problem in my washer; hopefully it works for you.
    Sep 28, 2009 | GE Washing Machines
    Replaceing the wet end seal on my hot tub
    disconnect power take pump out remove front plate take back cover off motor use 7/16 wrench to hold shaft unless it has a place for a flat head screw driver at the back of the motor while holding shaft unscrew impellar counter clockwise take shaft seal off impellar make sure rubber gromet comes off with seal take back seal plate off motor by unscrewing bolts thru back of motor should be 4 knock out ceramic ring replace ceramic ring with rubber side toward plate reinstal back plate install seal on impeller with with flat side with rubber gromet toward back of impellar. screw impeller back on holding shaft if the shaft is rusty and pitted clean off with sand paper b4 reinstalling impellar lube up oring around front plate screw back tight and reinstal pump.
    Sep 18, 2009 | Jacuzzi Impeller, L - 3/4 H.P
    Change front crankshaft oil seal on 1966 jaguar s-type 3.8
    remove front crossmember remove sump remove crank pulley prise cone from end of crank remove key from crank carefully prise out seal runner checkthis for wear and replace if worn pull seal from timing case lips reasemble lubricating new seal tip lock crankshaft piece of wood to ease loosening and tightening pulley bolt
    Sep 03, 2009 | Jaguar S-Type Cars & Trucks
    How do I replace starter on 2000 sportster
    You must remove the primary to reach 2 bolts holding in the starter. This is a pretty big job, first completely loosen the clutch cable, remove the derby cover, disconnect clutch cable, remove inspection cover, drain primary fluid, loosen primary chain tension er, remove shifter linkage, remove primary cover ( use a Styrofoam board to place bolts in order due to different lenghts), remove ramp and ball assembly ( need snap ring plyers), using a tool to lock the clutch basket and primary drive remove bolts( I don't remember which but one removes left hand), you now can reach the bolts holding in the starter. As I stated this is a pretty big job and you should have a manuel before starting, if you don't want to buy one you can check one out at most library's. Reverse to install and remember LOCK TITE everything.
    Jun 07, 2009 | 2001 Harley Davidson FXSTD - FXSTDI Deuce
    GLD6200 NOISY
    The sound is almost always caused by a worn docking cone “O” ring on the main conduit. When the docking cone “O” ring wears, the mid level spray arm conduit is no longer constrained and it can vibrate against the docking cone, making the “growling” or vibrating sound. Use a plastic wire tie to quickly verify if the growling noise is coming from a worn “O” ring. Snug the mid
    spray arm coundit against the upper rack with the plastic wire tie. Run the dishwasher. If the noise goes away, you have verified the presence of a worn “O” ring. Remove the wire tie when the test is completed.
    The recommended repair for this problem is to replace the WD12X10059 (titanium) or WD12X10121 (grey) docking cone. These parts supercede to the full main conduit. It is not necessary to replace the full main conduit for this problem. Remove the docking cones from both the existing and new main conduits. Install the docking cone removed from the new
    main conduit on the existing conduit still installed in the dishwasher.
    Oct 25, 2007 | GE 24 in. GLD6200L Built-in Dishwasher
    Sport & Outdoor - Others Logo
    835 people viewed this question
    Top Sport & Outdoor - Others Experts
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
