Question about Refrigerators
We have a maytag plus side by side with ice maker and water dispenser. occasionally there is water on the floor in front of the unit but not underneath. what could be causing this?
  • 80 Answers
Check the water supply line to the door and see if there is a small hole in it.
John
Posted on Sep 28, 2009
Ice maker stopped working - filter is good, water to fridge is fine. arm is down, no obstructions. Water comes out of water dispenser great. However NO ice - no water in tray - unit is Maytag Model # MF...
Your ice maker uses one side of water control valve and dispenser will use the other. Try filling the tray with tap water and allow to freeze. If the ice maker cycles and drops the ice into ice bin but does not refill with water points to the water control valve. On most refrigerators the dual water control valve is found on the back of refrigerator and near floor. Try that and tell
I could not find that model number in the US Maytag database. It really does not matter as long as you can find the parts. If number is correct then you must live outside the USA. Lell me what you get and if you have questions I will be here to answer any questions you may have, Thanks, Sea Breeze
If helpful please rate this solution.
Oct 21, 2011 | Refrigerators
Water dispenser does not shut off
That is most likely a dual water control valve stuck open on back of refrigerator near floor. One side feeds ice maker and other side feeds the water dispenser. If the ice maker side began to leak slowly it would create quite a mess of ice flowing over ice maker and freeze every place it could inside the freezer. Part and Model Search If helpful Please Rate this solution, Thank You, Sea Breeze
sea_breeze_260.jpg Refrigerators
Freezers
Washers and Dryers
Oct 18, 2011 | Frigidaire Refrigerators
I have a Maytag Plus side by side with Ice maker and water dispenser in the door. I have replaced both water valves and still cannot get water to the ice maker. The water to the water dispenser in the door...
First you need to make sure the ice maker works. One way to test it is to manually put water into the ice maker and wait a few hours and see if it pushed the ice out. If it did not you need to find out why the ice maker does not work. There are many reasons for that; that would be a new chapter. If the ice maker does dispense the ice but does not turn on the valve you would need to find a loose connection. There is a way to test the "water fill" after removing the ice maker, but it is a little tricky. Then also, sometimes the fill tube inside the freezer freezes; that is another problem al together.
May 20, 2011 | Refrigerators
Occasional small puddle of water on floor in front of unit on door handle side. it is a 25 yr. old Amana no ice maker or water dispenser in door
there is a drain pan for condensation under the fridge. over this many years the is dust and lint that will fill the pan and displace the water on your floor. while your under there clean the coils. this will help get every year possible from your fridge
Jul 27, 2009 | Refrigerators
Maytag side by side, msd2456de will not make ice, I have water that dispenser works fine, I believe freezer is cold enough what could be the probem?
If water is not getting to the ice maker the fill ice maker with tap water. Wait until it freezes and dumps and then replace the dual water control valve on back near floor. Sea Breeze
Jul 20, 2009 | Maytag MTB1504A Top Freezer Refrigerator
My maytag MSD2556ae side by side refrigerator water/ice dispenser may be locked. Is there a method or code to unlock. The water dispenser started shooting water out with no warning and the dispenser light...
I have a Maytag model 2556 AE refridgerator. The ice maker works but the ice and water dispenser, the light and everything else on the front of the unit doesn't work. Is there a fuse that operates this or is there other problems? Thank you Bob
Jun 10, 2009 | Maytag Dual Cool 25 cu. ft. Side-by-Side...
Water dispenser quit working
Make sure that the water filter is the right one and that it is pushed all the way in. If that is correct than There should be two solenoids located behind the fridge at the bottom one is for your ice and one for water. Unplug unit and test the water solenoid with an ohm meter across the two terminals if it ohms out or beeps than your solenoid is bad.
Jan 01, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator leak
the water fill tube for i/m is on the back of ref. the tube you have is to the water dispenser. look in freezer floor, is it full of ice? if so, remove all ice and clear drain hole for evap. if not, reassemble what you took apart and inspect tube under ref. while someone runs water dispenser. find leak and repair.
May 20, 2008 | Maytag MZD2766GES Side by Side...
Frigidaire signaling water dispenser instead of ice maker
Sounds like the water solinoid valves are wired wrong.One activates The water dispenser.The other the ice maker.That, why every so often the water shoots out on the floor.The ice maker is telling the valve to open.
Dec 05, 2007 | Frigidaire FRS3R5EMB Side by Side...
Ice and water on bottom of freezer
sjlobo, sounds like your defrost drain pan is frozen over or has some gunk in it. When the unit goes into defrost the water is running onto the freezer floor and out the front. Remove the lower bin and check the drain hole. You may have to remove the freezer back panel. If you can, just use some very hot water and some sort of baster to unfreeze the drain. Check this first, Catriver..post back.
May 05, 2007 | Maytag MSD2758G Side by Side Refrigerator
Refrigerators Logo
71 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
