Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Does this oven have its own fuse that can be replaced? My wife was baking something and we heard a pop like a can of biscuits exploding. The oven was dead at that point so went outside and re-set the breaker. Now the oven does not heat up even after setting the clock. The cooktop still heats normally however. I am guessing it is the element though.
  • 142 Answers
Sound like elementht blew and took your breaker out theres not normally a internel fuse......
Posted on Sep 28, 2009
My wife was heating the oven to 400 degrees for baking. As she walked away, she heard a pop sound. The control panel was off. I checked the breaker and it was OK. While I was in the oven, I checked the...
it sounds like something shorted in the clock assy. check the elements to see if they are damaged,sometimes they blow apart and also take out the clock assy.when you change the bulb anywhere you want to make sure the power is off to it,shut off the light switch and when you open the door hold in the door switch or just unplug it or kill the breaker,you can try to get the rest of the bulb out with a pair of needlenose plyers,next time send the model number and i can look up your machine to help you find out how much the part is and part number.
May 14, 2011 | Frigidaire 30 in. Electric Gallery Pro...
My wife heard a loud pop while baking, the oven will no longer bake, the stove top still works so does the clock ect. Elements are fine just don't warm up. I have a kenmore 790, is there a internal fuse...
Check the baking element, sometimes these will make a popping sound if they burn into. Also a lot of your components are behind the knob/clock area.
Feb 25, 2010 | Ovens
Bake element
It may have also Blown the Fuse, to the element, in the stove itself.
Feb 12, 2010 | Dacor ECD230 Epicure Electric Double Oven
My oven inside glass door exploded tonight while
Very rare, in 35 years I replace maybe 2 to 5 a year out of 1500 to 2000 repairs a year on all major appliances. Make sure you replace it with the exact glass from the manufacturer, usuing your model number. Do not replace with glass from a glass shop.
Jan 29, 2010 | Ovens
I have a frigidaire oven model number GLEF378CSB - won't heat up
Make sure your getting 240 volts to the unit if not it's the board...sorry. More then likely it's the board.
Jan 10, 2010 | Ovens
Bake or broil does not work
if an element itself had shorted it would not stop the other from working and you could inspect each element and see blistering as evidence.the pop you heard has to be in common with both elements but not the cook top[burners]so thats going to be the wiring in the back of range, or switching,[thermostat,clock timer or oven selector switch,depends on which model you have]you will have to pull range and remove back pannels.you will find an obivous burn't connection.too repair all new connections must be clean and tight,or will burn again.
Jan 24, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Temperature in oven is way off
Jim,
A couple of questions... What makes you think the oven is off that far? If you have a set on the shelf dial type thermometer, throw it away. They are never accurate and generally read 50+ degree too low. I recommend the "biscuit test". Which is simply a cheap can of "hit on the edge of a counter top to open" biscuits and see how they bake with the instructions on the can. Make sure you allow the oven to preheat for 20-30 minutes (always but especially for this test).
To change the oven setting press BAKE, then run the temp up to 550 then immediately press and hold the bake pad for 10-20 seconds. The display should read 0 (zero) you can then use the up down arrow pads to adjust, hit bake pad again and then "clear" when done to lock it in but, you can only go up or down 35 degrees. If it is truly off by more than that you would need to change the main oven control board and oven sensor.
Dec 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven blew a fuse
The POP sound normally indicates a short circuit fault (as opposed to overload) you need to have it looked at by a competent person.
Nov 17, 2008 | Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
198 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
