Question about Lexmark X7550 InkJet Printer
I have a x7550 and I want to rifill the ink, I did the black, but it says low on Ink! do you know why this is?
My x7550 wont print pictures.....says its printing and ink level goes down, but photo paper comes out blank
It could be that your cartridges need some cleaning. From the printer operator panel, scroll to the Maintenance menu and select Clean Cartridges. Your printer will then print a test page forcing ink through the cartridges nozzles and clean them.
After doing the clean cartridge function, try to print another photo to determine if the problem is fixed.
Hope this helps.
Apr 30, 2012 | Lexmark X7550 InkJet Printer
Prints colours but not black. new cartridges
the inkjets can get clogged up with old ink,with some inket rifils there is a solvent which disolves the dried ink,with some solvent in a saucer,sit the cartridgeuntil the solvent changes colour then the ink is getting though the jets
Aug 11, 2010 | Brother Office Equipment & Supplies
I rifil canon Fax -JX 201. 1st time It Good worked. But 2nd Refill icant get photocopy; But it say "No ink" .How to Reset that error
by refilling the ink crg. you probably destroy head electronics. Buy new one ORIGINAL, and try then.If you must refill ink be carefull, rather buy new reffiled ink, where the chip is resetted.
Hope that helps!
Aug 10, 2010 | Canon FAX-JX200
Lexmark X7550 starts up and immediately goes to the "load ink cartridge" tutorial screen when the ink cartridges have already been changed out for brand new ones. I need to send faxes and this problem...
From how you're describing things, I think it's more complicated than I think. Maybe a firmware update is needed. But I would suggest you contact Lexmark Technical Support to further investigate the problem before doing any firmware update. I hope I can assist you more on this matter.
Jun 30, 2010 | Lexmark X7550 InkJet Printer
I want to know what ink does it need. What to buy for my Lexmark X7500 series
I have the same printer and I go to Office Depot, the cheapest around, and you get rewards. Lexmark 41 Print Cartridge is the color and Lexmark 42 Print cartridge is the black.
May 15, 2010 | Lexmark X7550 InkJet Printer
I have refilled the ink cartridge on my lexmark x7550, but it does not register, why?
Hi there
Lexmarks not work when you refill the cartridges up. they have a fuse inside the cartridges that blow when they go low, this is down to Lexmark not let them refill so you have to buy there inks.
All the best Pineworks
May 03, 2010 | Lexmark X7550 InkJet Printer
HP C4500 ink consumption
Dear Sir,
Now a days all HP ink catridges available at low price that means ink quantity is also low.So if you print heavy coloured pages it will deffinately consumes more ink.So print in gray scale or black and white consumes low ink. Compare to gray scale,black and white printing consumes very low ink. So print in black and white is the better choice.
good luck
Aug 08, 2009 | Office Equipment & Supplies
Black catridge desnot recoganized"
I have solved this problem,power butten and Reset button press holde a some seccends and when restart printer
Jan 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Sep 29, 2008 | HP Deskjet 6940 InkJet Printer
Lexmark X7550 InkJet Printer Logo
106 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
