When I attempt to install Office 2007 I get an error message- error 25004.config.Xml not specified; A valid config.xml file must be authored when deploying '(null)'. What does this mean?
-   Same error message but there is no current version of Microsoft Office working. Had computer problem, HP took back to fix but wiped out the MS Works office files so I purchased again. Maybe a hidden file is the issue?-   yallcavae463
Mar 03, 2009
-   i cannot seem to open all my docs and i am told that i should install windows 2007.. P M D.-   Samir Kamona
Mar 03, 2009
-   How do you do a system restore? I feel like I've tried everything and I can't get Office Pro 2007 re-loaded on my computer. I'm extremely frustrated. Thx, JW -   buddyluv3
Nov 17, 2008
-   I have this problem of "error 25004.config.xml not specified..." when trying to reinstall my office 2007. What can i do to fix the problem?
-   pospino
You need to uninstall any pre-release version of the Microsoft Office 2007 system .
it seems that if you have a version of the 2007 Microsoft Office Add-in or Microsoft Save as PDF or XPS installed, this may be the culprit. In both cases, by performing an uninstall on this add-in via the Control Panel, and then installing Expression Web, everything works okay. You can even re-install the Office 2007 add-in when you're done.
uninstall the microsoft office from the control panel in vista ... it
will ask for a particular file... have it access that particular file
by showing the path.. then something will happen... but still the
microsoft office will remain in the control panel.... now re-install
the microsoft office and it will get installed.... this is how it
worked for me. Arun Premsingh R, CEO, www.kenriche.com.
The way I fixed mine was by doing a system restore, and restoring it back to before I had installed Office 2007 the first time and then I installed it again, and that worked for me.
I used support.microsoft.com/kb/928218/ to manually uninstall Office 2007 Home and Student. Once I followed each of the steps in the article, rebooted my system; the program would install again, otherwise half way through it would stop with error 25004 message. Hopes this helps anyone!
Was this helpful?
Yes
No
Popular Solutions for Microsoft Office Professional
I would like you to help me with a product key for project professional 2007, it seems that I just...
(More)
I would like you to help me with a product key for project professional 2007, it seems that I just cannot find it.
Suddenly I am denied all aspects of creating a new publisher document and Restore doesnt fix...
(More)
Suddenly I am denied all aspects of creating a new publisher document and Restore doesnt fix problem. Microsoft will not accept the Product Key that I have.
when I try to use mail merge in 2007, and complete the merge, it only pulls in the first three and...
(More)
when I try to use mail merge in 2007, and complete the merge, it only pulls in the first three and last three records form my chosen database file. All files are the same so I believe that it is not the database and that it is the template doc in word. can you advise.. I did try to repair word 2007 by re-installing, but that did not work... possibly I have a conflict with another program installed....
My PC caught a virtumond virus. This was successfully removed but when trying to run any of the Microsoft Office 2007 programmes it comes up with error 25004 Config.xml not specified. A valid config.xml file must be authored when deploying '(null)' Attempts to reinstall the software meet with same error. What can I do??
does this mean? and how can I fix it
I am having the same problem as everyone else with this config.xml thing appearing when I am trying to install Office 2007 Home and Student. The first answer DOES NOT WORK because I never had any pre-release Office software on my system, so I would really appreciate if someone else could look for another solution to this. I solved this problem myself once, but I cannot remember how I did it or figure out how to do it again.
I bought a Dell Laptop which runs on Vista and came with a preinstalled MS office 2007. After a month it suddenly stopped working. I was trying to uninstall the program from Control Panel but a msg pops up saying, "This product installation has been corrupted. Run setup from CD, DVD, or other installation device." So when i try to reinstall it starts to, but a little more than halfway through I get an error that says, " Error 25004.config.xml. A valid config.xml file must be authored when deploying '(null)'.
My Office 07 will not open, so I was going to try to uninstall it and reinstall it, but when I go into Control Panel to uninstall Office 07 a window pops up saying, "This product installation has been corrupted. Run setup from CD, DVD, or other installation device." So when i try to reinstall it starts to, but a little more than halfway through I get an error that says, " Error 25004.config.xml. A valid config.xml file must be authored when deploying '(null)'. What can I do to get Office reinstalled on my computer?
