Question about Dacor DMT2420 1200 Watts Microwave Oven
Fan/ heating element won't turn on
The microwave has power, the lights turn on and the timer counts down but the fan/ heating element never kicks on to start cooking the food. It just went past the warranty.
  • hikerchick Jan 21, 2008
    Hi, My Dacor microwave just went past it's year. I was using it, opened the door to check my food and when I went to turn it back on the fan and unit will not start. The light, time and control panel work. What was your solution.
    Thank you,
    Kim
  • lacostarua Nov 07, 2008
    I have the exact same problem with the exact same model Dacor microwave. I am two months past the warranty and my microwave mid-cooking a lean cuisine just stopped cooking. The turntable stopped spinning, fan stopped...yet the clock/timer continued to count down. I am VERY frustrated since I did not purchase an extended warranty on this.
  • 833 Answers
You may have a bad internal fuse or thermosensor. Take off the key panel. look for fuses. Also the sensor is black, about the diameter of a dime and 3/8 inch thick with two wires...attached to the oven wall. Check for continuity. Quick check, remove wires, connect with a paper clip tape up and try. Do not run with the sensor out of the circuit except to test.
Posted on Dec 19, 2007
Microwave timer works but will motor will not run/cook.
If everything works on the unit, but you do not receive any heat or possibly the turntable does not turn you have a faulty magnetron (controls heat) and a faulty motor (controls turntable). You would require service on the unit, if parts are available. Some microwaves are so small in cubic foot size, that manufacturer's do not have parts available for purchase/repairs.
Dec 24, 2012 | Frigidaire FMV156DC Microwave Oven
Mbbs 01 thermador micro oven: timer counts down, lights go on, but no heat, no fan and turntable does not turn. is it a fuse?
Key clue is table does not move---All microwaves with a table have a lever switch that is engaged when door closes--only can get at from inside the unit----it prevents the unit from operation if door not closed.
What happens from closing door a lot is the switch with a lever arm can come loose or even if snapped into a plastic holder break out of the holder.
IF this it is not too expensive a repair.
Jun 16, 2012 | Thermador MBBS Microwave Oven
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
Food won't heat up
Hello, I had the same problem, and just fixed mine. Start by turning on your microwave (on mine, the light turned on and timer worked, but the fan nor the plate turned)... push the door upward and see if the microwave turns on... (mine did). so far so good. open the door and take the upper hinge cap off with flat head screwdrive. take the door off and place a small washer on the bottom hinge, put the door back on. your microwave should be good now. essentially, the door just needs to be pushed up a bit so it will work.
good luck, hope that works for you...
Jun 01, 2010 | Frigidaire FMV156DC Microwave Oven
Frigidare FMV156DCG Overheated?
I have the same problem....I think its the door switch because if you lift up on the door handle while you've got the timer counting down, it should start the microwave hum....
Apr 26, 2009 | Electrolux Microwave Ovens
Just quit working...but not everything.
Hi , open the cover with philips screw driver , b sure unplug it first , If you have continuety tester check the fuse if open replace it , are available in electronics center brings that sample and insert it.
Apr 16, 2008 | Kenmore 62702 Microwave Oven
No fan, turntable or heat, but counts downs
The 'Clock, is Machanical just like an ordinary kitchen timer The reast of it is electronic, and at that age time for a new one.
Jun 26, 2007 | GE JE1640WA/GA Microwave Oven
Dacor DMT2420 1200 Watts Microwave Oven Logo
232 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
