Question about Directv Plus DVR DTV Receiver / 100-Hours Video Recorder
DirecTv DVR Sensor not working
I'm having a problem with the DirecTv DVR R15 model that I have. Every now and then it appears that th sensor is not functional as it does not recieve the signal from my remote. The remote works fine as it is still able to control my HD Reciever. I know the box is ok too because I can navigate it using the buttons on the front. Has anyone had this problem? Do I need to replace the sensor? This started happening since the most recent software upgrade. Could this be a software problem?
  • cresean Jan 09, 2008
    totaly have the same problem. Remote will work with other receivers in the house and works with my other components.
    Started haveing this problem after the last upgrade. I have tried everything and have reset the receiver a couple of dozen times. That did help for a few days off and on, but now it doesnt work at all. I know it is the receiver because none of my other receiver remotes work with it either.
    Sorry I'm not more help. I have a feeling that a new receiver will have to be sent from direct tv. unless there is some other way of reseting it wich I doubt. I think your right with it being a sensor problem.
Sat on the phone with direct tv for about an hour.
we were unable to come up with any solution useing codes and reset option. The one thing that might help with your remote:
try pressing the select and mute button together untill the light blinks at the top. Then push 0001 or try 00001
Make sure to point the remote at the receiver.
This did not work for me and they sent me a new reciever.
They of course tried to charge me for the full price of the reciever which they will most certantly try with you.
It souds like you problem started happeing after the last upgrade which is when my problem started happening.
I gave them a little bit of attitude when they tried to charge me for a new receiver stateing that it was ther new upgrade that caused the problem and that if I had to pay for a new reciever I was gonna cancel with them and go with dishnetwork.
(they sent me a new receiver free of charge in 2 days)
They should have been willing to do this whithout any argument but they are trying to get money wherever thay can. Seems pretty unfair cosidering that you can get all this stuff for free when you first sign up.
Also dont let them tell you that it is the remote sensor. I went back and forth with this guy trying to explain to him that my remote worked fine with other devices includeing my other DVR.
He finnally agreed that it was the DVR sensor.
Hope this helps
Posted on Jan 15, 2008
    Problem Solver:
  • 26 Answers
Try reinstalling your update sounds like you missed some of the update
Sorry wish I could help youmore
Goodluck
Please rate
Why does my R15-100 DVR Plus not record 2 programs at same time. What can I do to fix it?
When we had the R15 (we have since upgraded) we could record two channels at once with no trouble. You have to have two satellite connections in the back (since it uses a separate tuner for each channel) and you cannot watch a third channel while recording two others - if you're going to watch, you have to watch one of the two shows you're recording.
May 16, 2014 | Directv Plus DVR DTV Receiver / 100-Hours...
Need to recover data from DirecTV R15 DVR receiver hard drive
First, sorry for the delay in respoding to your post. I did notice that you had a prior question about the Power Supply on an R15 DVR. Does the unit have a manufacture code of 500(found on the right hand front Flip Door of the DVR)? If so, I might be able to help you in repairing the Power Supply. As far as I know, getting your DVR up and running again is the only way to watch your previously recorded programs. As far as retreiving programs from your old Hard Drive via other methods, I probably won't be able to help you there. When I had both of my identical DVR 15 500's apart for a parts swap to diagnos a failed Phototransistor(infra-red sensor for the remote control), I also tried to swap out the Hard Drives. This is what I found: When you swap a Hard Drive into another DVR, it won't play any of the programs previously recorded. However, if you record new programs on the swapped Hard Drive then they will be playable on this current setup. Now, if you swap the Hard Drive back to the original DVR it came out of, the programs will once again be accessible except for any that you might have recorded while the Hard Drive was in the other DVR. So, in conclusion, when programs are recorded on a particular DVR, it is encoded electronically to play back only in that DVR via communication from the Motherboard and the Hard Drive. I know, it sucks, but that is why I was asking if you are pretty sure the Power Supply is at fault. If so, I received info from this forum on how to fix the issue. Also, if the attempt fails, Ebay has some previously owned DVR's for sale and maybe you can get one for spare parts. Remember, the Power Board and Front Display Control Panel are the only interchangeable parts IF you want to view the programs on your DVR's Hard Drive. Let me know what your DVR does when you plug it in. That will go far in further diagnostics of your DVR.
Nov 28, 2011 | Directv Plus DVR DTV Receiver / 100-Hours...
II just want to ask a question about a TIVO DVR.
You can buy a used DirecTV with Tivo. You probably had a Hughes SD-DVR40 or SD-DVR80 before. The used model needs to be transferable to your account (which means it can't be leased, it has to have no outstanding charges on the previous account, etc). And you have to buy a new DirecTV card.
If you are in the San Francisco Bay Area or in San Jose, write to tivorepair@gmail.com and they should be able to help you out.
May 17, 2010 | Directv HD DVR TiVo DTV Receiver /...
DirecTV receiver R15 won't respond to remote RC23
Well, I took the DVR apart and found the power board completely intact, no bulging capacitors. However, the Mother Board had a 220uf/50volt cap that was bulging, so I replaced it. By the way, 'DigiKey' is the only place to go for electronic parts. They'll hook you up! The DVR still wouldn't respond to the remote. Darn it!
So I took both of my DVR's apart and swapped out the Front Board (the one with the Photoamplifier in it) and the DVR would now respond to the remote. OK, so now what do I do. I still have one DVR with a bad Front Board. I started to look on ebay for an old used R15 500 that I could swap parts from...remember, I own my eqipment and the goal is to preserve what I have recorded on the Hard Drive. R15's were going for around $50 -$80. Then I got to thinking. I still had an old non-DVR Direct TV Receiver in my closet I never planned to use again. My thought was: even though it wasen't the exact model receiver, it did use the same remote, so the frquency that the Photoamplifier worked at should be compatible.
So I took apart this receiver unsoldered the Photoaplifier. I then removed the Photoamplifier from my malfunctioning DVR and installed the part from my unused Receiver and it fixed it. So long story short(too late for that) the Photoamplifier was faulty. I tried doing some cross checking and a company in China called Raytron makes the part. The failed part did not have a part # and Raytron has several different Photoamplifiers that operate at different frequencies. This made it impossible to find the right part without schematics or knowing what the freqency is. So at least we now know what caused the non responce to the remote.
Jan 31, 2010 | Directv RC23 Remote Control
R15 DVR locked in record
2 months ago my R15-500 stopped working. The "Record"(yellow) light was dim on the front of the DVR and a lightly audible clicking noise could be heard from inside the DVR. So I searched the internet and found this FIXYA site. I disassembled the DVR as instructed and removed the power board. Sure enough the Capacitors were bulging on top. I replaced all of the capacitors on the power supply output, I think 6 altogether. I reassembled the unit and it worked great.
Jul 23, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Philips DSR708/R
My recommendation to you is to look into the Dish DVR. I have it in my home and it is excellent.
Can you use any other DVR......sure.
May 29, 2009 | Philips DIRECTV R15
My Directv DVR receiver will not stay on it is blinking yellow??
Unplug it from the power for about 30 minutes and then try again. If it still doesn't work I would call DirecTV and discuss getting it replaced.
Mar 17, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Directv DVR Plus R15 Receiver won't power on
sounds like the receiver has gone bad. if you have tried it in numerous rooms/outlets and its not the electrical cord (its plugged in tightly at the back if its detachable) sounds like the receiver needs replaced. if you have the protection plan it MAY be covered under this and MAY be replaced for free. contact directv at 800-531-5000
Feb 15, 2009 | Philips DIRECTV R15
Programing Bose Universal remote to DirecTV R15
Check Direct's code info in their info packet.
It should be in there.
Apr 26, 2008 | Bose Cinemate Digital Home Theater System...
Directv Plus DVR DTV Receiver / 100-Hours Video Recorder Logo
339 people viewed this question
Top Directv Televison & Video Experts
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
